Question about Delta Rockwelldelta 15" Drill Press Operators Manual Parts
We own an old Rockwell International Model 15 drill and tap machine. The chuck needs to be replaced. Where can I purchase one?
    Scholar:
  • 110 Answers
Click here for a site that WILL have everything you need for that old work horse. Hope you have a fat wallet.
Posted on Aug 26, 2010
Where can i find a 5/8 in. chuck for a Pit Bull CH-16NF Drill press
Take it to a local engineering sales shop. They are all basically the same and fit into the shaft with a morse taper. You just need the correct taper.
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p...
    • 4.5/5
    • 2 REVIEWS
    Email Signup. Never miss a sale and receive special online only offers.
  • King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for ... https://eastcoastpowertools.ca/chuck-drill-press-5-8-jt6-for-milling King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for Milling At East Coast Power Tools
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p... Help others make a decision about this product by sharing your experience.
  • Related searches for 5/8 in. chuck for a Drill press
  • Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 - Amazon.ca https://www.amazon.ca/Woodstock-D3455-Drill-Chuck-8-Inch/dp/B000HRXOLS This item: Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 CDN$ 47.71. In Stock. Ships from and sold by Amazon.ca. FREE Shipping. ... (Canadian Tire) Drill Press.
  • 5/8 Drill Chuck ' eBay 2q== www.ebay.com/bhp/5-8-drill-chuck Suitable for drill presses or lathes spindle accepts R8 shank. Chuck key and R8-JT33 arbor are also included in the package. Special quenching treated ...
  • 5/8" Drill Press Chuck [MAG-DPC58] - $29.99 : KMS Tools ... https://www.kmstools.com/5-8-drill-press-chuck-2990 KMS Tools & Equipment from Vancouver BC 5/8 ... Home > Metalworking > Lathes and Milling Machines > Chucks and Taper Adapters > 5/8" Drill Press Chuck 5 /8 ...
  • 1 32 5 8 Heavy Duty Drill Chuck with Chuck Key and R8 Arbor Amazon com
    Jun 05, 2016 | Drills
    How do I remove both pulleys from top of unidentified drill press?
    15" Rockwell Drill Press pulley removal? - The Garage Journal Board
    www.garagejournal.com > ... > The Tools > General Tool Discussion
    May 3, 2012 - 7 posts - ‎2 authors I have 15" Rockwell Bench top drill press 15-017 I think circa 1971. ... You have toremove the machine screw and the pulley and bearing ... Drill Press Pulley Problem
    Aug 31, 2013
    Old COMPANION bench top drill press disassembly?
    Mar 5, 2013
    More results from www.garagejournal.com
    Oct 23, 2015 | Drills
    113.24520 chuck replacement
    most drill press chucks are installed and locked on by a male / female taper fit. Tap chuck assy. downward with a soft hammer to remove. install new chuck tapping it upward.
    Oct 28, 2013 | Craftsman sears 15" 1/2 Heavy Duty Drill...
    Replace Keyed Chucks with Keyless Chucks
    Can't help with this other than suggest that you do not proceed, Keyless chucks can be problematic particularly if dust /debris from material being drilled finds its way into the chuck..
    Mar 30, 2017 | Drills
    Require a 10mm and a 13mm Male-fitting Keyless Chucks
    I suggest that you do not proceed, Keyless chucks can be problematic especially if dust /debris from material being drilled gets into the chuck. I have had to remove the Keyless chuck from my B&D drill and replace it with a keyed chuck- no problems since.
    Apr 04, 2017 | Drills
    12 volt black and decker keyless chuck will not close. Model CD120G
    Try giving the inside a spray with WD40 then try closing the chuck. Check that there is not a left handed screw in the center of the chuck that has become partialy unscrewed. The chuck can jam open and just need a strong gril to release it. If the outer sleve of the chuck is turning but nothiing happens then you will need to get the chuck replaced.
    Jun 10, 2012 | Black & Decker 18V Cordless Drill/Driver
    There is not a slot to drive the moris taper out This is an old Delta Rockwell dp600 is it threaded
    It is possible that this machine has a solid spindle but the chuck is held on the spindle with a tapered end like a Meddings drill. to remove the chuck you will have to make up an extractor out of 2 round bars with holes in them to fit between the shaft and the chuck with bolts though the bars to which you tighten which will force the chuck off the shaft with a little help from a hammer to shock it. It is not an easy job but I would only recommend doing this if you want to change the chuck.
    Jul 29, 2010 | Delta Rockwelldelta 17" Drill Press...
    Where can I buy a new chuck for my 15-091 dp?
    You cn find MANY chucks on eBay. You need to verify the size and the mounting which is LIKELY a Morse taper. ONLY buy new ones. There are some for as low as $8.
    Prefered brand is "Jacob's".
    Jul 16, 2010 | Delta rockwell 15" Vs6 Drill Press...
    Removal of chuck
    Harold, Have you tried looking from the top? Maybe you can put a rod into the spindle from the top and give it a tap. Al Kupchella
    Apr 10, 2010 | Turner Walker-turner Rockwell 20 Inch...
    Need to replace chuck on 1/2'' mastercraft hammer drill. Which chuck do I need??? model 54-2986
    took off the old chuck , measured, and took it with me to purchase a new one.
    Dec 09, 2009 | Drills
    Delta Rockwelldelta 15" Drill Press Operators Manual Parts Logo
    232 people viewed this question
    Top Delta Drills Experts
    DocZachary
    DocZachary
    Bill Boyd
    Are you a Delta Drill Expert? Answer questions, earn points and help others
