Question about Plantronics Voyager 500A Deskphone Adapter for Voyager Series Bluetooth Headset [ Pla... Headset
PHONE WILL NOT LIFT OFF HOOK EITHER WHEN YOU REMOVE THE EARPIECE FROM THE CHARGER OR PUSH THE CALL BUTTON
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
It could be that the battery inside the headset is worn out, or the headset needs to be re-paired to the base unit, or the lifter is worn out. If you manually remove the handset receiver from the phone, and you power on and activate the headset, does sound come through ? If so, it may be the lifter. If not, it could be one of the other two scenarios. Here is a link for the 510S / 500A user guide to troubleshoot.
Voyager 510 User's Guide
Good luck from Headsets Direct!
Posted on Nov 23, 2011
Not working buttons
The home button do tend to break, the iphone 3 or 3gs are straight forward to replace the home button. Remove 2 screws from the end of your phone, 1 on either side of your charging socket. Lift the screen from the home button end as there are ribbon cables on the earpiece end of the screen. You then have access to replacing the home button but the iphone 4 and newer model are alot more difficult as the last thing to be removed is the screen and you have to remove the screen for access to the home button. It is a very cheap fix but if you don't know what your doing when taking apart your phone you could cause alot more damage. Have a look at a internet iphone repair video to see if you would be confident of doing the repair yourself. Before you start to take apart your phone make sure it is not under warranty as taking it apart will void any warranty.
Dec 29, 2013 | Apple iPhone Smartphone
Lost manual need to charge my earpiece
Need more information...what earpiece are you using? Does it have the same charging port as your phone? Chances are your earpiece charges through a micro-usb port. If this is the case, you can easily find a new charger that is of size micro-usb (that is the same size as the charger of most new cellphones).
Feb 28, 2011 | Cell Phones
Hi , there is problem with my phone volume. I can
First of all, a temporary solution is for you to use a earpiece. You plug it on your phone and you will be able to hear the callers clearly.
If your phones main speaker is working, then it is the earpiece speaker that is bad. All you have to do is to replace the speaker with a new one. There are two speakers on this phone, one in front, which is the part where you get to listen to your callers from, then another speaker that plays your audio files and receive your calls on speaker mode.
To disassemble the phone, follow the steps below:
  1. Remove your back cover, battery, sim and memory card. Six screws need to be removed,
  2. Run something like a credit card around the join of the battery compartment to release it from the rest of the phone.
  3. Now remove the two screws and you'll be able to lift away the metal plate with the identification sticker on.
  4. A ribbon connector needs to be detached. This attaches like a plug and socket. Just lever it up to unplug. You can now lift the circuit board away from the rest of the phone.
  5. Remove the eight screws you can see. These screws hold the slide part in place.
  6. You can now lift the slide part away from the rest of the phone. Four screws now need to be removed. The two on the left are covered with black stickers which can be easily removed.
  7. Now run your plastic tool all the way round the join of the front cover in order to release it.
  8. Three ribbons need to be disconnected. The two left and right attach like a plug and socket. Just lever each up to unplug. The ribbon in the middle has a different connection. To release it just flick the black latch up and pull the ribbon cable away from its socket. You can now lever the LCD screen out of the front cover.
  9. Then you see the earpiece and where it is connected to, just disconnect it, replace it with a new one, then you reverse the process to reassemble the phone back together.
Take care and good luck.
NB: When making a call, do not put it on speaker yet, then you increase the volume from the side of the phone where you have the volume button. If you do not hear the person calling you, then you replace the earpiece with the steps above.
Dec 20, 2010 | Samsung B3310 Cell Phone
Iphone 4 does not pair sennheiser vmx 100
To Pair the Sennheiser VMX 100 headset with your iPhone or other cell phone:
At the same time as you open the mic, you also need to push down on the bottom/volume-down button on the side of the earpiece and hold this down (at the same time as opening the mic) until the light flashes red and blue alternating. (Just to clarify, it is the button that has an arrow pointing toward the Sennheiser logo). If asked for a code, enter "0000" (four zeros).
This video shows the bluetooth earpiece connecting to an iPhone 4S running iOS 5.0 (not jailbroken). This is the standard way to pair these devices, but as a disclaimer:
If anything should happen to your phone or your Bluetooth earpiece, it is not my fault.
Nov 06, 2010 | Sennheiser VMX100 Bluetooth Headset...
My l6 fell and now the screen is blank what should I do
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
What you have to do is simple.
1. Remove the battery cover, battery and SIM
2. Use the screwdriver or tweezers to gently pry off the RF grommet located on the antenna cap (below)
  • Removing the antenna cover:
    3. Carefully use the flat end of the tweezers to release two latches on the top end of the antenna cover, then carefully lift the antenna cover away from the phone.
  • Removing the transceiver PC board shield:
    4.Using the T5 screwdriver, remove the 6 housing screws from the phone. Set the screws aside for re-use (see Figure 10).
    5.Lift the metal shield away from the phone.
  • Removing the housing:
    6. Insert the plastic shim between the front housing and the chassis assembly. Slide the plastic shim around the phone between the front housing and the phone to release the housing catches along the sides of the front housing
    7. Carefully lift the bottom end of the front housing over the phone. The earpiece will still be connecting the front cover to the rest of the phone at the top of the phone so be careful
  • Removing the earpiece speaker from the front housing:
    8. Use the plastic shim or tweezers to separate the earpiece speaker from the front housing
  • Removing the LCD screen:
    9. Use the tweezers to release the display module assembly latch located at the side of the display module
    10. Lift up the top edge of the display module
    11. Carefully thread the display flex cable through the slot in the chassis assembly and lift the display module away from the chassis
Replace the old screen with new an
d reverse the whole procedure for reassembly
Take care
Jun 18, 2010 | Motorola Mobility L6 Cellular Phone
Want to be able to lift panasonic kxtga270s cordless phone off
press the function button (lower left) arrow down to i"Initial Settings" , arrow right, arrow down to "Auto Talk" arrow down to "off" press "Save"
Aug 29, 2009 | Panasonic KX TGA270S Cordless Expansion...
PHONE DOESN'T TURN ON? I PUSH ON/OFF BUTTON ON TOP AND HOLD IT DOWN, IT IS CHARGED?
Pull the battery and clean the battery contacts with a pencil eraser... make sure that the matching contacts in the phone are not bent...
The reinstall the battery, hook up your charger and watch the display for "device attached" confirmation on the display. If you don't get a confirmation on the display, it either isn't attached properly, the charger isn't getting power or if it's a car charger, the fuse in the charger is blown.
If after ample time for a complete charge, it's not working, replace the battery.
If none of the above works, it may be time to swap out the phone...
K
Jul 30, 2009 | Nokia 6030 Cellular Phone
Samsung alias earpiece speaker
Possible the earpiece has gone bad. Can you test with another earpiece?
Remove battery and examine metal contact points for dirt. Can clean with a pencil eraser.
Jul 19, 2009 | Verizon Communications Samsung Alias Cell...
How do i change the earpiece on my samsung wep210?
YOu charge it with a samsung phone charger - and a small grey double ended attachment that should have come with it - this plugs into the bottom of the earpiece after pulling back the flap, and the phone charger bit goes into the other end. Alternativeley - there are lots of sites selling in-car chargers for these.
Jul 17, 2009 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Phone speaker inoperative
I still have this problem as I stated on the 24th April .
I am hoping someone will respond to it.
Batesie
Apr 24, 2008 | O2 Xda II mini
Plantronics Voyager 500A Deskphone Adapter for Voyager Series Bluetooth Headset [ Pla... Headset Logo
171 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
