Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
My freezer area works fine, but the fridge stops and starts working continually does anyone please have a solution
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
Freezer works fine, fridge compartment cools but has stopped cooling as good and has recently stopped cooling. did a manuel defrost on fridge and freezer worked fine afterwards, now doing the same thing...
Oncce the fridge was shut off and left for a while the cooling had come back . If frost is seen it is a good indication as the compressor is working with sufficient gas within.
If after about 6 hours you observe cooling it is possible that the defrost timer is faulty.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
replace the defrost timer, heater or thermostat one you have confirmed to eliminate one by one.
Mar 11, 2011 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
Can't get temp in fridge to go below 50 F. Freezer works fine and makes ice. It started when our area had a heat wave and the inside of our house was 85+ most of the day. The ice maker stopped working,...
Have you checked the evaporator fan(freezer fan), This problem is hard to detect because the fan spins but not fast enough to circulate the chilled air thru the freezer and refrigerator.
Aug 01, 2009 | Refrigerators
Freezer woks fine but the fridge not working
sounds as if the evaporaator fan inside the fridge between the fridge and freezer is out. This fan is located between the freezer and fridge in the same area as the control switch for the temp. This fan isn't hard to replace you just need to take care of the removal of the plastic cover. Once the cover is removed the fan is accessed easily. Take the model and serial number to an appliance parts house for the proper part. Good Luck
Dave
Jul 22, 2009 | Whirlpool ET4WSKXS Top Freezer...
Miele KFN8462S fridge freezer is displaying an F2 fault code.
F2 Is fridge evaporator sensor faulty it will require new sensor part no.7323301
Apr 01, 2009 | Miele KFN8462S Bottom Freezer Refrigerator
Fridge on Zanussi ZX56SI has stopped working but freezer fine
check in your frezzer on the back wall if its all frosted up u have a defrost problem u can unplug and let thaw fgor 4 or 5 hrs plug back in and wilkl work till u can have it serviced if no frost u might a bad fan or a damper control
Mar 18, 2009 | Zanussi ZX56 / 4 Bottom Freezer...
Freezer not working but fridge is
tratra72
You said,
I opened my freezer today and everything was defrosting. The fridge is working fine. I thought maybe did not shut properly so made sure it was closed and 8 hours later it is still not freezing. The fan is working but the air is refrigerator. HELP!!!
1.Try unplugging the fridge for 5 minutes and then restarting it! This may reset the system!
2.If the freezer is so full that the rear vents are blocked then this may happen. Because the fridge and the freezer share the air!
3. If not then the freezer and the fridge have different controls and the freezer control if faulty!
then you need service. ur site has good service companies in your are for our customers!
Bless You,
please give me a good rating before you sign off!
thank you
Sep 14, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
51 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
