Question about Toshiba Satellite A105-S4074 Notebook
Toshiba Satellite A105-S1014 screen on power on is blank (no bios text either). Connecting an external monitor does not work either.
  • 60 Answers
SOURCE: Toshiba a105 screen goes blank
Sounds like GPU failure. unfortunately its nigh on impossible to replace without replacing the whole board which can be expensive. I saw a few on ebay for around £120.
Posted on Aug 14, 2007
tom19511
  • 1601 Answers
SOURCE: Toshiba Satellite P25-S5263 monitor problem
Sounds like the display adapter is either failing or has a bad driver.
Does it do the same in safe mode? If so its a bad display adapter,
If it does not do it , then it needs the corrupted or missing display driver.
Posted on Dec 29, 2007
Nitrotrike
  • 589 Answers
SOURCE: Toshiba Satellite A105-S1014 Sound Problem
Does it have that silly little volume knob on the side? Gets me every time :)
Posted on Jan 09, 2008
SOURCE: toshiba blank screen
i had the same problem and i replaced the inverter but that did not work then i replaced the backlight and no problems since then.
This seems to be a problem with alot of toshibas and i dont know why they install these useless backlights. Backlights are supposed to outlive the laptop.
I paid about 20 dollars for the backlight rather than pay $200 dollars for the whole LCD but it is a very tricky job so be very carefull.
Posted on Jun 17, 2008
dragon_sun25
  • 107 Answers
SOURCE: toshiba satellite a105 screen problem
You need a new lcd, The connectors are bad...
Posted on Dec 13, 2008
How do i repair toshiba satellite a105 ribbon cable repair
Have you tried hooking up an external monitor to it and seeing if it works? I would try that first to rule out a video card issue. If the external monitor works fine, here is a website with pictures on how to disassemble the laptop to replace the screen:
Toshiba Satellite A105 Laptop Disassembly Guide Cooling Fan Heatsink...
Jul 23, 2014 | Toshiba Computers & Internet
Cursor at times will jump to another place on screen is this a virus?
Possibly. Run Microsoft Essentials the free antivirus programme that appears to work and is free.
Sep 03, 2012 | Toshiba Satellite A105-S1014...
Black Screen on Toshiba Satellite A105 S1014
Blown or damaged graphics chip on motherboard, would take to specialist repair shop
Feb 09, 2010 | Computers & Internet
Toshiba screen is blank ans light on under F10 key.
Is the screen completely blank, or just dim? If it is dim, then most likely your lcd power inverter is bad, and needs to be replaced, which is the cheapest part to replace. If it is completely blank then you should try to hook up an external monitor to the laptop, and don't get any video, then most likely there is an issue with your motherboard or video card. The external monitor method sometimes needs you to press a combination of the Fn key and another F key in order to switch from your laptop lcd to an external monitor.
Feb 06, 2010 | Toshiba Satellite A105 Notebook
Toshiba Satellite Laptop refuses to allow Dual Monitors
I have an A105 set up on dual screens, and it works great. As I recall, you have to do the dual screen setup in the control panel, display, settings.
Mar 17, 2009 | Toshiba Satellite A105-S4074 Notebook
Toshiba satellite a105-s1014
try the computer with an external monitor, if it works correctly then it's the monitor that has broke and you need it replaced.
otherwise, if it does the same things on the external monitor...
I would check in order:
1)RAM memory
2)Motherboard
if the problem is only after windows boot, try changing the video driver, the problem might be caused by overheating video Chip, but that should freeze the system too...try also to remove the dust from all the heatsinks with canned air...
Jan 18, 2009 | Toshiba Satellite A105 Notebook
Have you tried connecting to an external monitor? Try that. If the picture is perfect on the external monitor then the VGA port is OK but there is a problem with communications between the system board and the screen connector.
Hope this helps. Kindly leave a rating.
Mar 05, 2008 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite A105 PC Notebook
When you turn it on, do you hear any activity? Motors start working, fan spinning, etc…? Try to connect an external monitor and start the laptop. Check if you can get any video on the external monitor. If the external monitor is dead too, try to remove the battery and start the laptop from the AC adapter. It also might be a bad memory module or a bad connection between the memory and the motherboard. Try to reseat the memory module, move it to the second slot. If you have two memory modules, try to remove them one by one and turn on the laptop. Also, try to remove the hard drive and see if you can boot it to Toshiba screen without the hard drive installed.
There is no special button to reseat the BIOS settings. To do it, you’ll have to access the BIOS using F2 button on the laptop start up, but as you have no video, you cannot access the BIOS and set it to defaults.
I
Dec 27, 2007 | Toshiba Satellite A105 Notebook
Oct 16, 2007 | Toshiba Satellite A105-S4074 Notebook
Toshiba Satellite A105-S4074 Notebook Logo
49 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
