Question about Sharp Twin Energy EC-12TWT4 Bagged Upright Vacuum
No problem with the vacuum. Works great. However, we misplaced the various attachments (extension tube, brushes, etc.) that go with the vacuum. Can you direct me to any dealer in the Cleveland, OH area that would sell those parts. If it helps, our zip codes are 44134, 44129, and other 441__ numbers.
    Problem Solver:
  • 7 Answers
I just found this site when looking for parts for my EC-12TWT4. I haven't dealt with them before however...
http://www.vacshopusa.com/sharp_parts_supplies.htm
Posted on Sep 25, 2010
Very low suction when I use the hose, but the carpet brush roller attachment works fine. Any ideas?
This style of vacuum has great airflow but does not have great suction, especially at the end of the hose but it still should have enough to pick up most soils. It may have a restriction in the suction tube or emptor. The disposable bag may be full or clogged, the outer bag could also be clogged.
May 04, 2016 | Kirby G4 Bagged Upright Vacuum
Where do you put attachments to make them work?
There is a button on the handle that releases the suction tube from the floor brush housing. Once the suction tube is released from the brush assembly, you can install the attachments on the suction tube.
Nov 15, 2015 | Dyson DC14 All floors Bagless Upright...
My powerhead shuts off after about 15 seconds of running. It will turn on again after a brief rest. What could be causing this?
sounds like it's overheating and tripping the breaker. When it shuts down try pressing the little red breaker button. Could be a restriction of the rotating brush or a short in the extension connector. Remove the bottom plate and visually check for a cord or string wound up in the rotating brush mechanism and check the extension tube and flex tube for obstructions... Try the head without the wand by just connecting it directly to the flex tube and see if this makes it work without shutting off. I'm betting on something binding the roller brush and causing it to overheat...
Apr 11, 2015 | Filter Queen Majestic Canister Vacuum
Fully charged no power
Could be a jam/blockage in the Power Head. To check, remove the Power Head and extension tube and try again. If the cleaner runs normally without the Power Head attached, then the problem is obviously in the Power Head. First step - remove the brush from the Power Head and check for jam/blockage. The rectangular hole directly behind the brush (through which the dust passes on it's way up the extension tube to the top of the cleaner) is relatively small and clogs easily (especially if you have a pet!), so you need to make sure that it is clear. If the cleaner doesn't run with the Power Head removed, then it is probably a problem with the main motor and would need more expert investigation!
Mar 29, 2014 | Dyson DC35 Handheld Vacuum
I need the attachments
I have attachments for the SC 505 Euro-Pro Shark Portable Steam Cleaner. My cap broke off of the water tank and I can't find one to replace it so I'm trying to sell off the pieces. Email me at rbvasanj@yahoo.com and let me know which ones you want. This is what I have. We can work out a price.
1. Nylon Detail Brush (x2)
2. Angle Concentrator/Brush Adapter
3.Extension Tubes (x2)
4.Window Squeegee
5.Floor Brush
6. Filling Flask
7. Shoulder Strap
May 05, 2011 | Euro-Pro Shark SC-505 Handheld Steam...
I have an old fantom thunder upright and need to take the bottom off it to see what is stuck in it. I don't know how to do this.
moz-screenshot.jpgI found a manual for the Fantom Stick Vac, model FS801 (your model may be different).
For "Cleaning Air Driven Turbo Brush", it says:
  1. Remove the turbo brush from the hose or extension tube.
  2. Slide locking latch forward, then tilt the top housing of the brush upwards. The top housing is hinged and will tilt up approximately 45 degrees only.
  3. There may be some dust, lint, hair, etc. on the turbine wheel. Remove as much of this as possible.
  4. You may also use the unit's hose with the crevice tool attached, and use the vacuum to remove any additional debris from the turbine.
  5. Ensure that the turbine wheel moves freely by rotating it with your finger. If the turbine does not rotate, call Customer Service for help.
  6. Once clean, close the top cover of the turbo brush and slide the locking latch towards the rear of the brush to lock.
There is also an image in the manual that might help. You can download the manual for free here.
Hope this helps!
Mar 03, 2011 | Vacuums
Suction from hose isnt strong enough. Vacuum
There is probably a clog on the U channel (little Gray tube that attaches to the Vac tubing). Pull it loose and look in side all the tubing.
Nov 16, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Suction only through attachment, but not without attachments
have you removed the bottom plate...as if you were going to change the belt....look for where the intake hose is under or near the roller brush...most likely that is where your clog is.
Mar 27, 2009 | Kenmore 34923 / 34925 Progressive Bagged...
Brushes
I'm no expert...i'm just waiting on someone to answer my question....but the unit has to be on the floor with the handled released b4 the roller move.
Aug 23, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Sharp Twin Energy EC-12TWT4 Bagged Upright Vacuum Logo
77 people viewed this question
Top Sharp Vacuums Experts
Mike
Are you a Sharp Vacuum Expert? Answer questions, earn points and help others
