Question about Panasonic KX-TG4500 Phone
The display and the battery light are flickering on my KX-TG4500 base unit, but the phone seems to be working. What is causing the flicking and how do I stop it?
We had a similar problem, but our unit eventually stopped working. We were able to fix by replacing the power adapter. The easiest way to test if this is the problem is to use one of the power adapters from the handsets (they use the same one). If that solves the problem, you just need a new power cord/adapter.
Posted on Oct 05, 2010
  • 1 more comment
  • OahuLasik Apr 28, 2011
    Problem solved!! Thank YOU!!! We have gone through 3 phones and dozens batteries!! I figured there had to be a good explanation for the unit to just stop working.
  • snnnapshot Aug 01, 2011
    I have already ordered a new base, but wont be delivered till tomorrow. I tried this fix and it worked. It apparently WAS the adapter plug. At least I will have a backup system now. But still wish I had seen this prior to ordering. Thanks a lot for the info.
  • rtk9667 Aug 12, 2011
    Thank you so much for your suggestion. I thought I would have to buy a whole new phone system for our office. I replaced the power adapter after I read the suggestion on the FixYa site and it worked. Thank You! Thank You! Thank You!
Panasonic KX-TG6711E Cordless phone
Have you check another phone jack in the home? sometimes it is a bad jack that cause it not to work
May 13, 2014 | Panasonic KX-TG4500 Phone
Kx-tg4500 base unit. The backlight is lit but flashes. No words appear wont answer or ring. Cordless phones say cannot connect to base unit
Hi I have seen this may times and it has to do with the main controller in the unit, unfortunately this means that it must be repaired or replaced, i recommend the latter, as in reality to repair this unit is uneconomic in my experience, sorry about that but now at least you know. However if you do wish to attempt a repair, it obviously will not hurt, to contact a local or head office from Panasonic and ask for a referral to an authorised service center, now take the unit there and ONLY ask first for a "Quote" as to prospective costings and go from there.
Sep 29, 2011 | Panasonic KX-TG4500 Phone
I have two KX-tg4500 bases & I need them to be able to "talk" to each other! They are both currently registered as number 0 - how do I renumber one of them to register it to the other base?
only one can be base! you can try to make one the base and then try to pair the other as client however be prepared that the base is not set to be client
good luck
rene
Jun 08, 2011 | Panasonic KX-TG4500 Phone
I work for the Western Regional Day Report Center in Huntington, WV and we are using one of you Panasonic KX-TG4500 phones and Line 1 will light up when a call comes in, but WILL NOT RING. Now lines...
Check to see if the ringing volume is turned down,
On the base unit press the menu button and scroll to ringer settings using the up and down arrow keys, press the enter key.
Scroll down to ring group and press enter.
Press the left or right arrow keys to select the line desired.
press the down arrow key to move to Ext #.
Enter in the disired extension number starting with the base as Ext 0.
press enter to save.
Apr 05, 2010 | Panasonic KX-TG4500 Phone
Phone flashing,no phonelines
you got to regester handset at base unit
Oct 02, 2009 | Panasonic KX-TG4500 Phone
Our phone its not working
If the other phones are not working, then I assume the base unit does not have power to it. So check the power supply to make sure it has proper voltage with a volt meter, I think there's a battery pack underneath also to check. Otherwise, you can contact the retailer where you bought for repair instructions.
Sep 03, 2009 | Panasonic KX-TG5632 Phone
I have the kx-tg 4500 4 line base unit phone. Line one flashes but does not ring or display caller. The other lines work fine. The handsets show no activity ie they don't even flash if a call comes in on...
I had the same problem once, turned off the base unit from power cord and the phone line and all connected handset units, then turned it back on & it worked.
Aug 05, 2009 | Panasonic KX-TG4500 Phone
Panasonic base unit went dead
THROW IT AWAY.  I HAVE THE SAME PROBLEM AND PANASONIC AFTER SALES "SERVICE" PEOPLE  HAVE BEEN COMPLETELY USELESS!
Mar 10, 2009 | Panasonic KX-TG4500 Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Panasonic KX-TG4500 Phone Logo
535 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
