Question about Mitsubishi WS-55511 55" Rear Projection Television
Mitsubishi WT42413 error code 23. It turns on for bout 4-5 min and shuts down! Not sure what to replace?
  • 4,889 Answers
Error 23 means a fault in the horizontal deflection circuit. Its part of the HV circuit that drives the CRT. Possible reason for shut down is an overload thats causing a protection fault. Note that this is a rather risky repair for someone without prior experience. So if that is the case you might wanna seek the assistance of a qualified tv repair tech.
Posted on Aug 26, 2010
I have a mitsubishi hd 1080 65315 model and the code is 23 what is the problem.
Mitsubishi TV Shutdown Troubleshooting - Stereo & Video ...
www.stereoandvideorepairco.com/.../MitsubishiShutdownTroubleshootin...
For example, the sequence: blink-blink, pause, blink-blink-blink, indicates an error codeof 23. This sequence repeats 5 times, so you can figure out if you are ...
Mitsubishi VS 50705 error code 23 - Service manual, repair and ...
forum.eserviceinfo.com/viewtopic.php?t=81051
Oct 24, 2010 - 10 posts - ‎4 authors Tv is old about 10 years. Shows error code 2-3 horizontal deflection failure. A few years back had a leaking crt, replaced the caps recomended ...
Oct 19, 2015 | Mitsubishi Televison & Video
Mitsubishi WS48413 makes a clicking sound and turns off right away
this is a V22 chassis circa 2003/2004
you could have an issue in 1 or multiple circuits. it is key if you can determine any error code. Error code is determined by blinking LEDs on front of unit after it shuts down. It will blink a certain number of times, pause then blink another certain number of times. It repeats this cycle 5 times.
12...no fault detected
21...X-Ray protect
22...short circuit protect
23...deflection circuit
Continuous flash...most likely DM circuit.
Dec 30, 2014 | Mitsubishi Televison & Video
Mitsubishi 65733
CONTACT MITSUBISHI TECH SUPPORT, THEY SHOULD BE ABLE TO GIVE YOU AN IDEA OF WHERE THE PROBLEM IS WHEN YOU TELL THEM THE ERROR CODE, THEN LOCATE A HONEST TV TECH FOR A ESTIMATE.
Feb 02, 2014 | Mitsubishi Televison & Video
When i turn my tv on the screen just stays black. You can hear the volume. I just replaced my bulb about a month ago. I took the bulb out again to see if it was blown and it wasnt. Does anyone know wh
send me a email slinteriors@yahoo.com and I will send you the info to retreve the error code to find out why the set is shutting down. Be sure to include the moodle number and symptoms with your email
Feb 10, 2013 | Mitsubishi WD-65C9 65" DLP HDTV
Mitsubishi ws65819 shut down in 3 second
The 23 error is horizontal deflection failure thats usually caused by one of the items shown in the following illustration thats highlighted in yellow.10_20_2012_11_55_10_pm.jpg
Oct 20, 2012 | Mitsubishi Televison & Video
I HAVE A MITSUBISHI 65 INCH MODEL WS-65411 AND HAS A CODE 23
This error code shows that you have a Horizontal failure occurring. It could be a intermittent solder connection on one or more of the yoke connectors. That is the most common issue with shut down due to Loss of Horizontal Deflection. If you are handy with a soldering Iron and confident in general TV knowledge, you can repair this. If not , do not attempted it. Call a Professional. If confident, unplug the set from power, remove the speaker Grills from the front. Then remove the Center Piece of the front panel. You should have access to the front plate. Remove the 6 screws holding in on and place it aside. If you look at the neck of the left CRT', you will see a 4 pin Plug Connector that goes from the High Voltage Board up to the Yoke . You will need to use a flash light and check the solder connection under that yoke plug. Most of the time it will look like it has been arching. Resolder each of the pins. then move to the center CRT and do the same. After that, repeat it again on the CRT to the right. Make sure that each of the pins you solder are not shorted or have Solder Splashes between the pins. Plug in the set and turn on. Hopefully you will not have the problem again. Reinstall the Front Panel Access plate, Center Piece and Speaker Grills.
Hope it does the job,
Sky Assoc
Feb 22, 2010 | Mitsubishi WS-65411 65" Rear Projection...
F-21 error means What?
F-21=LONG DRAIN If the drain time exceeds 8 minutes the water valves shut down. After 4 mins the Sd(slow drain) error will be displayed, 4 mins later the F/21 error code will be displayed.
Press PAUSE/CANCEL 2 times to clear display
Probable cause/Proceedure
Drain hose plugged/kinked
unplug washer/disconnect power
check electrical connections to pump
and make sure pump runs
check drain pump filter for strings,sand etc
plug in washer If this dont work
replace pump.
Dec 31, 2009 | Kenmore HE2 Plus Front Load Washer
Error code E39 for Mitsubishi Heavy Industry Ceiling cassett type
E39 Fault is thermister, Mitsubishi way of saying im not going to start because there is something wrong. Generlly it is compressor fault or short of gas. Im guessing if you turned the power out. Waited twenty seconds, turn it back on. Now if you go to the outdoor part. Wait exactly 3 mins. If you hear the compressor try to start and fail then it would more then likely be your compressor if you dont hear anything and the unit faults out it will either be a board or short of gas.
Either way If the unit is under five years old get a warrenty agent out to look at it.
Sorry I couldnt tell you for sure but MHI are very vague when it comes to fault codes
Mar 03, 2009 | Mitsubishi Heating & Cooling
Please help me, i have Error code 23 on Mitsubishi WS-55511
A 23 error is loss of horizontal deflection First thing to check is the solder joints around the Flyback and around the two transformers T5A31 and T5A32. If you resolder those three items then pull the Q5A31 HOT ( Horizontal output transistor ) from circuit. If you send me a email to slinteriors@yahoo.com I will walk you through how to test the various components in the Horizontal deflection circuit and help you get your set up and running again.
Jun 24, 2008 | Mitsubishi WS-55511 55" Rear Projection...
TV turns off right away relay clicks
1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Aug 19, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
177 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
