Question about Epson Aculaser C1100 Printer
'K toner low' but not lining up to replace. please advise
White lines when printing
Usualy white lines are a signal for you that is time to replace a toner cartirdge.
Your machine may inform you that you need to replace a toner cartridge, but sometimes the toner levels are low and the machine doesn't indicate that.
Another thing that you may try is to clean all toner cartridges using each corona wire.
If you need to replace your toner cartridge check this easy and helpful way to replace toner cartridge.
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
Printing problems,prints fine,but on the paper at each side there are black marks .like where the roller are
I would say this is a defective or low toner issue, If you have the old toner just pop it in and see if those lines go away, if so change your toner if not you may have a bad fuser that needs replacing... hope this helps and if so please mark as Fixya please... get paid to
Sep 14, 2011 | Dell 1720dn Laser Printer
Hl3040cn prints a black stripe down the page despite the drum being cleaned as advised by Brother.Peter
Hi
3 issues might be the problem.
1. The toner waste compartment is full. You need to clean the toner waste compartment located in the cartridge itself.
2. Roller drum inside the cartridge have lines normally starts on both ends of the drum. This due to bulky printing. Check and replace this parts inside the toner cartridge. Manual cleaning is not advisable because the result will still the same. If you have only toner cartridge, use the roller drum and replace in place of it.
3. Faulty Toner Cartridge that cause leaking the toner powder. If you purchase remanufactured toner cartridge or you refill the toner cartridge. It tends to worn out the parts. Normally starts as roller drum and follows with the other parts. Replace new original Toner Cartridge. When you refill the toner cartridge, you need to clean the waste compartment as well as it will later be full and overflow.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 15, 2011 | Brother HL3040CN Laser Printer
J2, toner low, but powder in toner cartg. Remove
All this means is that your toner is getting low and advising you before it is out completly the it needs replacing.
Dec 15, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Low toner advise keeps on after changing toner and/or printing
Have you tried to unplug your printer and plug it back in, that will force the printer to re-check all its settings and it should notice that the toner is now full.
May 27, 2009 | Dell 1110 Laser Printer
Received "Low Toner" message. Replaced toner with new Brother cartridge still have "low Toner" meaasge and [printer will not print.
Please check if you removed the Plastic Tapes which is placed in the side lock of the new Toner Cartridge.
Apr 24, 2009 | Office Equipment & Supplies
SC 366 on CL4000DN
cyan problem --check if cyan pcu is set properly or replace cuan pcu(drum)
Feb 05, 2009 | Ricoh CL4000DN Laser Printer
Samsung Lazer Printer CLP-300N will not print
clean the contacts on toner and in printer, shake the toner before putting it in. Reset printer via the html menu!
Feb 22, 2008 | Samsung CLP-300N Laser Printer
Xerox Phaser 6100 low toner
I was looking on http://office.support.xerox.com and I really hate there way of doing this. They advised that sometime below 30% you start to notice lines missing they advise (old School) to open the front panel remove the toner it solid across the front. if it is not to shake the toner to distribute the toner evenly again. They also advised that thier display panel doesn't always show when it is empty. I wish I could help more, but it sounds like they need to catch up alittle with thier printer warning.
Oct 15, 2007 | Xerox Phaser 6100/BD Laser Printer
Epson Aculaser C1100 Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
