Question about Lexmark X5470 All-In-One InkJet Printer
I replaced the color cartridge in my Lexmark Z2300 printer and get the response "Color Cartridge Replacement Required" I tried uninstalling and reinstalling the printer but nothing changed
Computer wont recognize printer,power light flashing
The flashing of the power light indicates a problem in the cartridge/s. Try to remove your cartridges from the printer > close the printer cover > unplug and re-plug the printer into the power source to reset > when the printer turns on, reinsert one cartridge first > check the behavior of the power light. If power light does not blink, open the printer cover again and reinsert the other cartridge. Replace whichever cartridge is causing the power light to blink with a new genuine Lexmark supply.
Dec 22, 2011 | Lexmark Z2300 InkJet Printer
I just installed two refilled lexmark cartridges color and black yet printer is reading black cartridge missing and color cartridge missing. I am unable to print
Refilled cartridges become unreliable and can damage your printer - you will need to try an original Lexmark cartridge before considering replacing your printer.
Sep 05, 2011 | Lexmark Z2300 InkJet Printer
Won't work without color cartridge
take out the color cartridge. you will get an error message, but it will work.
Jan 19, 2010 | Lexmark Z2300 InkJet Printer
Lexmark z2300 eplacing ink cartridges
Go to www.lexmarkz2300.com. There will be instruction on how to replace the cartidges. you will b e able to print out the instructions after you fix the problem.
May 21, 2009 | Lexmark Z2300 InkJet Printer
The black cartridge is optional, so you should have to just replace the color.
Feb 24, 2009 | Lexmark X2350 All-In-One InkJet Printer
Lexmark x 3650 change ink cartridge but it still gives a message(
Hi Glesam,
The X3650 uses the No. 37 tri-color cartridge, i.e. 3 colors in 1 cartridge. Unfortunately, when one color runs out, the cartridge has to be replaced. When you change printer, you might want to consider a printer that uses at least 4 separate ink cartridges (black, cyan, magenta, yellow). This way you need to replace only the cartridge that runs out.
Rgds
S88
Dec 22, 2008 | Canon MX300 Office All-In-One Printer
"color cartridge replacement required"
This is common problem with lexmark cartridges they detect refilled cartridge you need to clean the copper contacts of the cartridge and then insert it if it still shows " color cartridge replacement required" message then you need to buy original color cartridge.........
Jul 15, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
