Question about Westclox Audio Players & Recorders
Westclox toastmaster 66111 how do you change the day display to match the day of the week....
Instructions to set my westclox 70026
your user manual for 70026 is here on the Westclox website. Setting the calendar is covered on Page 2 there and you have to set the year first. using the Calendar settings after holding the Mode button for 3 seconds.
Westclox User Manuals
Jan 19, 2016 | Hardware & Accessories
How do i set year on westclox 70034 alarm clock?
You need to make certain that you have set the year right, otherwise it will show the correct day for say 2011, rather than 2013.
Jul 14, 2013 | Westclox LCD Dual Alarm Clock with...
How do I reset the date display? The date doesn't match the day of the week.
A very nice car...you really deserve to get a copy of the "owners manual" Many things to know about these quality sporty cars...
Jul 30, 2012 | 2004 Pontiac Grand Prix
I have 3 westclox clocks I have lost the instructions to set them. atomic clock Westclox 70026 cannot change the zone nor can I set the time to alarm
Manual on the link below.
If you would like to see the instructions, they are in .jpg format:
Front page of instructions:
http://www.poyntsource.com/New/Pathimages/westclox%2070026%20-%20page%201.jpg
Back page of instructions:
http://www.poyntsource.com/New/Pathimages/westclox%2070026%20-%20page%202.jpg
You might want to save these images on your computer in case the webpage is no longer available.
Oct 13, 2011 | Audio Players & Recorders
I have Westclox Atomic Clock, Model # 70026. I have lost the instructional manual. I only activate the alarm for 6:00 AM on Sunday, then I silence the alarm by pressing the Alarm on/off button. But...
Greetings.
According to the product manual, press the 'ALARM ON/OFF' button on the back of the clock until the bell symbol and 'Zz' disappear from the display screen. These symbols are between the hour and minute digiits, above the colon ( : ).
Good luck from Detroit, MI.
Jun 12, 2011 | Vacuums
Westclox model LTX271 instructions for setting day
mcdevito75 here, The stem on your westclox has 2 positions, First pull the stem out to set the time of day, keep cycleing the watch until you come to 1 day before the day you want. NOW! push the stem back in. NOW! slip a finger nail just under the crown and gently, gently kift the crown to it"s first position, it may take a little practice so be patient, once in it's first position you can change the DATE easily, change the DATE to 1 DATE before the DA you want, push the syem back in and pull the stem back out and set the day/date and time of day. Your watch is set and will change on time a little past mid nite.
Jul 22, 2010 | Bulova Watch
I need a drive belt for a Toastmaster 1148X Bread Box
If it looks like a drive belt on a vacuum, take the old one to a kmart and try to match it, if that doesn't work take the old belt to a bearing supply house, they should match one up, and worse to worse, like in our town, we have Hanna Rubber who will make you one, the manufacturer won't help you?
Nov 12, 2008 | Toastmaster 1148X FastBake Bread Maker
Westclox Travel Alarm
After selecting either TIME, DATE, or ALARM at the top of the screen, use the stylus to touch and hold the large time display. Hold it there for about 5 seconds and the clock will beep and the time display will start flashing. Then you can touch either the hours or minutes and it will increase by either 1 hour or 1 minute accordingly. When the DATE is selected, it shows the year in the large display. Again, holding the stylus on the year diaply for about 5 seconds will enter into the chqange mode. IN all cases, to exit the change mode simply select one of the other selections across the top: TIME, DATE, ALARM.
Jun 30, 2008 | Audio Players & Recorders
Westclox Monarch Alarm Clock - Model No. 90003
While holding down the snooze bar that says "ALARM" on it, hold down either of the "HOUR" button to set the hour when the alarm should go off or hold down the "MINUTE" button to adjust the minutes for when the alarm should go off.  Switch the "ALARM" to "ON" when done.
Apr 22, 2008 | Westclox Audio Players & Recorders
Westclox model 22717
Hi faulkquarter
I take it that the clock displayed with this problem if not a 22717 model. The one I have sighted is a digital clock. Generally, you need to hold down the "time" button and also press the "hours" and "mins" buttons at the same time to set the time. If this is not how your clock appears, please give me the button names and I can write a method of changing the time for you.
regards
Graeme
Apr 14, 2008 | General Time Corporation Westclox Bell...
96 people viewed this question
Top Westclox Audio Players & Recorders Experts
pawnpower
 Grubhead
Grubhead
ka4iup
ka4iup
Are you a Westclox Audio Player and Recorder Expert? Answer questions, earn points and help others
