Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
The washer will start but will eventually have an "F1" error. This usually happens when water is running into the washer.
    President:
  • 1,554 Answers
This is a problem associated with the machine/motor control assembly and/or the pressure sensor system. Either the machine/motor control assembly is at fault or it is sensing an error in the signal from the air pressure sensor circuit. Unplug the machine for half an hour or so to forcibly reset the machine/motor control assembly and eliminate the possibility of a simple electronic glitch.
Remove the three screws from the rear of the console assembly, if unplugging the machine does not resolve the issue, then pull console towards the front of washer to hinge it open and remove console. The machine/motor control assembly is located on the right hand side of the machine that is enclosed in a casing with a clear tube/hose connected to it.
The clear tube/hose is the pressure hose. Check to make sure that everything connected to the machine/motor control assembly is properly attached and fully inserted and the pressure hose has no air leak, kinks, or moisture.
Turn off the water supply to the washer and disconnect the hot and cold water hoses from the rear of the washer then remove the end of the drain hose from where it is installed. Remove the eight screws from the rear panel and remove the panel.
Inspect the pressure hose for evidence of water then replace the hose (part number 353244) if water or moisture is present. Inspect the air dome hose connection port for lint or flashing.
Use a small round device such as a small screwdriver to ensure that there is nothing blocking the air dome outlet on the tub.
Replace the machine/motor control assembly (part number W10189966) if and only if verified that there are no issues with the air pressure system. Remove all the wire connections to the machine/motor control then remove the screw holding it to the console tray. Two plastic legs on the rear of the machine/motor control assembly are fitted into the console tray. Lift the front of the control assembly to pivot it out from the console tray. Reinstall the new machine/motor control assembly then secure it to the console tray and reconnect the wire harnesses. NOTE: It is a good idea to take note of the wire harness connections before disconnecting them to prevent messing them up upon reconnection.
Posted on Aug 26, 2010
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
https://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
Machine was running when power went out- now it says F1 It will pump water into machine but not out
Sorry F1 is a fatal error with the main control. You'll have to replace it or buy another washer
Nov 02, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
My washer stops &and F-20 appears on viewer. Whats wrong with my washer
water problem check screens in hoses and valves !! rrors F1, F11 and F20
  • Error F1 indicates a communication error between the computer and the washer. Unplug the washer for a minute and plug it back in, as this may correct the problem. Error F11 indicates a motor control error. It can be caused by improper voltage. Unplug the washer and check the connections. This may fix the problem. Error F20 indicates lack of water entering the machine. If there is no water in the washer, check that the water valves are turned on. If there is water in the washer, press "Stop" twice to drain the washer. Unplug the machine and check the hose connections.
Read more : http://www.ehow.com/info_12006668_error-messages-kenmore-he2-plus.html
Feb 21, 2015 | Kenmore HE2 Plus Front Load Washer
I have a Whirlpool Cabario. I keep getting an error code of F1. I hit cancel and then start several times and it resets itself and continues. The same thing happens when it is about to start the rinse...
Hi
Thanks for using FixYa. Error F1 indicates primary control failure and to resolve this you'll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Fisher Pakel dish drawer sends F1 alarm flashing. It usually happens when there is a drop or change in water pressure. Have had 3 repairs on this disappointing product. Only repair person for Fisher...
F1 is a flood fault ir happens when the machine detects water on the base of the unit, to clear this fault you can remove the bottom draw and use a towel to clean up the water this should clear the fault, But usually there is only water on the base if the lid is not closing properly, this can happen due to you putting long utensils in and the lid cannot pull down or you have faulty lid actuators witch is probably the case and they wont pull the lid down correctly, So if the lid wont come down properly water splashes over the top and floods the base. :)
Jul 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Nov 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error code on Kenmore Oasis He
I think there might be a recall on your washer call to see. I am not for sure that there is a recall but I a m pretty sure there is. So don't quote me on that. the f1 error code usually means that you have a bad board. f1 means that your pressure switch line is failing and this is all in your board. check your owners manual if whirlpool is not going to pay for this repair sometimes there are extended warranties in your manual
May 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
F1 error code
This was copied from a website called WORLD OF WASHERS....I just copied the whole paragraph......sounds like some $$$
Let me know if this helps.......mtg
I am new to this online blog stuff, so I figured an email would be best. I own a Kenmore Elite Oasis washer Model #110.27042602. Everytime we try to use the washer we get error code F1 flashing. This happens withins seconds of the machine first starting to fill and about ten times thereafter until enough water gets into the tub for balance, I assume. We have started pouring about 2 gallons of water onto the clothes in the tub by hand before starting the machine which usually works. About half the time the machine stops again between wash and rinse cycle as it starts to fill with water again.
In my online research, I guess its good we don't have error code F51, but this is a pain and 1 year warranty has passed. It appears I may need to get a new Machine Motor Control Assembly. Any thoughts????
Thank you,
Darrell S.
Darrell,
I'm probably not going to tell you anything you don't already know. You know you may have to replace the motor control assembly, so you have done your due diligence.
I found a thread related to your problem at the "Samurai Appliance Repair Forums" at ApplianceGuru.com. That link will take you to the discussion, in case you haven't already read it. The poster described a situation identical to yours, and I have also read of this problem at other sites on the web.
Contained within that thread is a link to a Service Matters (Whirlpool Corp.) tech sheet related to the F1 error code. This is the document any qualified servicer will refer to when addressing your problem. Here is a link to that sheet in case you want to have it on hand in the event of a service call.
The tech sheet calls to replace the control, but only after three other tests have been conducted. Everything I have read indicates the control will be replaced the vast majority of the time. I am not a technician, but I would say there really is no way around that.
Please keep in mind that this sheet applies to specific models and serial numbers within the Whirlpool line. There may be a separate sheet for your washer, but I imagine the end result is the same.
The million dollar question is how much will such a repair cost. I am seeing prices ranging from $150 to $200 just for the part. With labor, you will probably have at least $300 invested in this repair. I would encourage you to contact Whirlpool at 866-769-7260. I have read instances of other owners receiving satisfactory service in out-of-warranty situations via this number. Whirlpool knows these washers are ****, so they no doubt have a scripted procedure in place to deal with these situations. Be firm, but also be polite. Maybe drop the word "recall" and see what happens.
Apr 11, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
1,308 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
