Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mit 52525 from blinking green light to still green light.
From one day to the other my Mit. 52525 will not turn on... No picture! at first their was a fast green blinking light now just a still green light when I turn it on! I remeber the fan would turn on as soon as it would start... now does't even do that! I tried to reset several times... still nothing, just still green light ! Can someone try to help!!
  • 98 Answers
I replaced all 3 boards - PWB, FMT, and DM boards, all oem parts. A bad light engine can cause continous green blinks. Heck, any problem at all will cause green blinks. I have 5 - 52525's in my shop right now. I definitely would like to know the problem as well, as Mitsubishi Tech Support has been of no help so far.
Posted on May 15, 2008
  • Mitsubishi Master
  • 8,617 Answers
Bad capacitors 1000uf on the PWB, FMT and DM boards will cause those symptoms. All capacitors 9 in all need to be replaced
Posted on May 06, 2008
I have one of thos green blinking light and NO
The lamp light would be solid red if the lamp were out. The steady blinking green led is usually caused by failed capacitors on the DM board. You can get the V26 dm repair kit from www.tvrepairworld.com which should repair that issue. The kit contains the capacitors and the CD with detailed instructions.
Jan 12, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 with blinking green light problem
The #3 post worked for me. I first just did the capacitors and it did not work at first, but I got it reset. It worked for 2 months and lost power the other day in a storm and the blinking light came again and would not reset. I put in the switch and followed his directions and it work perfectly. Sweeet. The switch was easy. The capacitors were not hard, but very detail oriented. I work on copiers for a living, so I am used to taking things apart and back together. You must be able to solder and reassemble pretty well, or I would hire someone to do it.
Sep 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Can't get power to the screen
the chassis needs to be repaired. check out www.tv-techs.com
Dec 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
The 52525 is definitely going to either:
1. have the caps on the FMT/DM board replaced (not something I'd recommend you do yourself)
2. have the electrical chassis rebuilt (as sometimes, you can replace the caps and still have the problem).
wait time: 4-8 weeks
cost to rebuild: $400-$500
cost for labor: $200-$400
Oct 13, 2008 | Mitsubishi WD-52627 52" Television
Replace the 1000uf capacitors on the DM board. thats whats causiong the problem. If you need further help go to this link they have your service manual available for emailing after purchase and that will entitle you for free tech support and one of their techs can fix those sets in his sleep he will walk you through the repair which parts are only about 20 dollars to fix the problem.
http://servicemanuals.vstore.ca/
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
check the pico fuses on the reverse side of the DM , Just check them in circuit for continuity. let me know how you make out, and if you need any more advice lert me know
Mar 18, 2008 | Mitsubishi WS-48513 48" Rear Projection...
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
Feb 20, 2008 | Mitsubishi WS-48513 48" Rear Projection...
No problem, do self diagnosis test, read threads here or goto ctechnicians.com get error codes first and get back with me.
Dec 17, 2007 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
536 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
