Question about Refrigerators
Hello -- I have a maytag model PTB1551GR refrigerator which just suddenly quit working overnight. Is there any way to tell if there is any possibility to re-start it?
  • 10,515 Answers
Unfortunately there could be many reasons for the same. I could provide you with few details. Iwould start by making sure that there is nothing wrong with either compressor or compressor relay. These are more prone to damage due to storm and is mainly responsible for no or less cooling or if refrigerator quit working.
If you have experience in repairing appliances, could take all precautions necessary and use multimeter - You could do a continuity check on compressor motor and all combination's. An infinity value on multimeter would confirm bad compressor.
On the side of the compressor you will see a box (maybe a cover) remove the cover if it has one and then remove the wire harness. next you will see the relay with the capacitor mounted to it. give the relay a tug and pull it off the side of the compressor. once you have it off pull the capacitor off and then give the relay a shake. If it rattles the relay is bad. if the relay does not rattle the compressor is bad and you will need to call a service guy to replace the compressor.
Other option would be - Go to a local repair shop and get an overload and relay ( cost around $50 ).Replace it. If the problem still persists, then it is faulty compressor.
Compressor's usually have 5 years warranty on it.
Other than this, make sure the wiring is fine. There is no cut or damage to the wire.
Let me know,if needed further assistance,
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 26, 2010
Maytag french door refridgerator model number MFI 256 8AEQ is beeping, blinking lights on the front panel and the refrigerator is not keeping cold BUT the freezer is working...
thenit quite possibly is the control damper for the refrigerator . having it too full on the top shelf can cause this . but it might just be on the wrong setting also . what is the dial set on normal is 3 or 4 might need to go higher .
Nov 22, 2015 | Maytag Refrigerators
Maytag refrigerator model #MFD2561HEW - Water dispenses from side wall. SUDDENLY STOPPED WORKING. Have replaced water filter. STILL NOT WORKING. Any suggestions?????
Hello, Thank You for using FixYa. I will be helping you today. Your water tank is frozen! Itson the back wall of the fresh food section if you look behind the drawers you will see it. Use a hair dryer and heat it untill you get water out of the dispenser. This is a common issue with this model.
Thank You and please rate my answer if it was helpful..
Jun 09, 2011 | Maytag Refrigerators
I bought a maytag side by side in 2002; model # MSD2454GRQ, SN 18157432AL, REV # 18. Ice is forming at the bottom of the maytag freezer department. Overnight ice will form at about 1/8 inch and left has...
Defrost problem: 3 components. Defrost Heater. Timer (circuit board or motorized) & Thermostat.
Remove cover on the inside back wall (usually 6 screws). Note frost pattern. (bottom of evaporator coil)
Put refrigerator into defrost cycle and note the defrost heater come on, or not. (careful heater can glow red hot)... Unplug Frige and test defrost components. Replace bad component... Refrigerator should defrost every 8 hours. when the cycle slows or quits the freezer will freeze over the evaporator coil and no air flow = no cold air...
Nov 15, 2010 | Maytag MSD2756G Side by Side Refrigerator
This refrigerator just suddenly stopped working overnight, is there anyway to re-set it and see if it is still ok?
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">Hi,</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><br />As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><br />If your refrigerator is running but warm, then&hellip;</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><span style="mso-tab-count: 1"> </span><br />Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...<br /><br />Refrigerator Condenser Coil Cleaning Refrigerator Repair<br /><a href="http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning" target="_blank">http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning</a><br /><br />Refrigerator Troubleshooting Refrigerator Compressor<br /><a href="http://www.fixya.com/support/r3885294-refrigerator_troubleshooting" target="_blank">http://www.fixya.com/support/r3885294-refrigerator_troubleshooting</a><br /><br />Refrigerator Compressor Start Capacitor and Start Relay<br /><a href="http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor" target="_blank">http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span><span style="FONT-FAMILY: Arial; COLOR: black; FONT-SIZE: 10.5pt"></span>
Aug 26, 2010 | Maytag PTB1551GR Top Freezer Refrigerator
My maytag ice2o starting flashing on the digital panel can I reset it
Your high voltage control board went out, very commonproblem. Call maytag and tell them you know this a common problem amd you also know they are replacing the board out of warranty. Worked for me, to which I also asked they overnight the delivery. Simple ten minute fix.
Aug 24, 2010 | Refrigerators
Lce maker quit working? and Ideas?
The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component
Jun 10, 2010 | Maytag 19.8 Cu. Ft. Side-by-Side...
The ice maker quit working but I still get water from the door dispenser. It's a Maytag model MSD2456DEW
I know this is late but I will tell you that most times the water control valve on the rear of refrigerator is the reason for the ice maker not to refill. Yours uses a part number 61005626 dual water control. One side for dispenser and the other side for the ice maker. You may test the ice maker to insure that it works by filling with tap water. Let freeze and if it dumps the then ice maker will try to refill after each cycle. If the water control valve works it will refill. Let me know if you still need assistance. Thank You, Sea Breeze
Aug 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
Water Dispensor Quit Working
if you have water on the floor may be is the line if not water valve
Mar 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag refrigerator clicking noise and stopped working
Maytag has recall on refrigerator relay for certain models. Check https://repair.maytag.com/prjjck/refrigerator.jsp
Mar 16, 2008 | Refrigerators
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
