Question about GE Dryers
Hi I have a Coinamatic GE electric dryer model CD9340DT029 which I will need to repair as the drum will not rotate, it tries to but won't so I think maybe the rollers etc are away. I can turn it by hand, but when I grip the drum there is free play - it just feels loose. Trying to find a parts diagram or any other info on this online but cant find this model anywhere, can you help advise on this. thanks David
  • GE Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Aug 29, 2010
Why is it now squealing when in spin mode
If your dryer is the kind with rotating drums, might be a bearing. You should disassemble it and check if can be replaced
Dryer Repair Replacing the Drum Bearing GE Part WE3M26
Dryer Repair Replacing the Rear Drum Bearing Assembly Frigidaire Part...
Dryer Repair Replacing the Rear Drum Bearing Kit Part 1 GE Part WE25M40
GE Dryer Repair Noisy or Screeching Rear Drum Bearing WE25M40
you can fine more youtube video tutoriala looking in google for terms
Youtube DRUM DRYER
Sep 02, 2015 | Dryers
Drum won't rotate
what is your model number is then we can get started then okay
Feb 05, 2013 | Zanussi ZDC5350W Electric Dryer
Dryer is frozen wont rotate when i hit the start button just makes noise then shuts off
The first thing I would do is try to rotate the drum by hand, there should be a little resistance at first, but once it begins to rotate it will rotate more easily. If it spins with no resistance it could be a broken belt or belt has slipped off. The noise I think your hearing is the electric motor trying to start up and may be locked up, and then tripping its thermal protection and shutting it down. These motors are durable but won't last forever, and are exposed to a lot of dirt and lint and can get packed in and around the motor affecting its operation. It doesn't sound like an easy fix to me other than a motor replacement. Hope this helps good luck.
Sep 09, 2012 | GE Profile Harmony DPGT750EC Electric...
My ge dryer model DRS483ED1WW won't turn on all it does is buzz when I try. I have changed starter switch that didn't work
does the drum and motor turn by hand freely. but i think its possibly the bushes in the motor. just have a look at motor and see if theres black carbon dust on it, you will get this on a motor anyway but not in excess
Jan 06, 2012 | GE DBSR453EBWW Electric Dryer
The dryer drum does not rotate. I have a Kenmore electric model number 110.62622101. It blows hot air but drum does not rotate
Dryer Repair - The dryer will not start
heatman101
May 15, 2011 | Kenmore 62622 Electric Dryer
Start button buzzes when pressed, dryer doesn't start.
I assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Apr 26, 2011 | GE DVL223EBWW Electric Dryer
Drum does not rotate
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Oct 21, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Front felt drum seal on ge came off---hard to repair?
Open the dryer door. At the top of the door opening, there should be two screws holding the top of the dryer down. Remove those screws and the top will rotate up, giving you access to the drum.
Nov 19, 2008 | GE DBXR463GB Gas Dryer
Dryers Logo
42 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
