Question about Canon BJC 80 InkJet Printer
My printing comes out striped, like a zebra. I have changed print heads, cartridges and computers. I have done deep cleaning and test pages but nothing has worked. I even tried the holding down the buttons and putting the power cord in idea. It was working fine one day and just started zebra printing the next. - mikeprosceo
My 9500 printer is not printing one color and ive done the deep cleaning as instructed. how do i remove the print head so i can clean it?
Turn the printer on.
Lift the cover to expose the print-head mechanism.
The print-heads will slide to a position from where you can "unlock" the ink-cartridge from its holder, and then gently remove the empty(???) ink-cartridge.
Insert a new ink-cartridge (or refill the empty cartridge).
Close the lid.
Print a "test" page.
May 27, 2011 | Canon PIXMA Pro 9500 InkJet Photo Printer
I've changed printer cartridges but it is not printing a thing. Not a test print, not print head alignment nothing. I've done the clean the deep clean print head alignment and there is still no ink coming...
Please check the seating of ink cartridge. when you replaced it, it should make a little click sound confirming that the ink cartridge has seated properly. Please repeat the process once more. Also when you remove the ink cartridge check if the thin strip on the ink pad has been removed. If not then remove it before fixing it again.
Jan 11, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
Color is terrible, even with new color cartridges. Black & white prints out with "stripes" across the page. Almost EVERYTHING we print is illegible. Our printer is less than 1 year old, and we have ...
remove the cartrides, clean the printer head with cotton ear bud soaked in after shave (use only a mild men after shave) the after shave has a low content of alchol.
If the printer head is built in the cartride then clean the head of the cartridge, if the print head is printer based you may have to open the front pannel of the printer to access the printer head to clean it using the same method.
Dec 07, 2009 | Office Equipment & Supplies
Cannon multipass F60 scanner/printer striped color printing
What you have is a dried up color cartridge. You can try to use the <clean print heads> in the diagnostic tools section of you priner software. (usually, just try to print something & the window will appear) Sometimes you have to clean heads, then print test page like 2 or 3 times before it clears up. If that doesn't correct it, don't worry. Have your color cartridge filled (staples, office depot, & other stores do it cheap) - or - replace it with a new cartridge. You may have to run the clean print heads program after installing a new cartridge, but this will definitely fix your problem.
Jul 26, 2009 | Canon PIXMA MX850 multifunction InkJet...
Printing quality suddenly deteriorated
You could have printhead problems but I would offer that you do a deep clean and consider replacing cartridges with OEM
Nov 13, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Magenta won't print have done deep clean and head alignment cartridge new and functioning tested cartridge in blue slot and ink worked
It sounds like your print head my be blocked. On some printers they come with the cartridge, my canon has separate print head that can be replaced.
Apr 14, 2008 | Office Equipment & Supplies
Printing in stripes
Possibly time to replace the printer.
Mar 07, 2017 | Canon Pixma MP500 All-In-One InkJet...
Will not print black
first of all the most important auestion is have you used compatible ink cartridges or genuine ones, because the print head clogs up with compatible ones, i really doubt that the cartridge you installed is damaged because i haven't come across this and i am a canon technician, i know this model well
Nov 02, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon BJC 80 InkJet Printer Logo
55 people viewed this question
old marine
old marine
