Question about HP D8597A Keyboard
The insert key does not allow me to type over an existing sentence. Does HP have this functionality?
I was having the same problem on a new HP keyboard. I found a solution for my issue in the WORD 2010 help menu:
"To change the overtype settings so that you can access overtype mode by pressing INSERT, do the following:
  1. Press ALT+F, T to open Word Options.
  2. Press A to select ADVANCED, and then press TAB.
  3. Press ALT+O to move to the Use the Insert key to control overtype mode check box.
  4. Press SPACEBAR to select the check box, and then press ENTER.
To turn Overtype mode on or off, press INSERT."
Posted on Feb 13, 2011
  • bluebuggie73 Apr 04, 2011
    thanks so much. I didn't realize how much I relied on the "Insert" key until I couldn't use it.
How to unlock keyboard?
press numlock button once
Mar 04, 2015 | Computers & Internet
Tip
Nokia N97- AMAZING FACTS!!!
d019b14.gif DID U KNOW???
…that by pressing any key on the top row of the keyboard (with the exception of Backspace) from the homescreen will bring up the Dialer?
…that by pressing the Shift key twice, this will allow you to type in CAPS LOCK but you can’t do this at the beginning of a sentence?
…that by pressing the Function key twice, this will allow you to type in SYM LOCK.
…that by holding the Sym key and pressing any vowel key or the ‘C’ or ‘N’ key, you will get accents above or below the letter? Pressing the letter key multiple times while holding the Sym key will cycle through the different accents (only vowels have multiple accents however).
…that the scroll key in the middle of the D-Pad functions like an OK/Options button?
on May 27, 2010 | Cell Phones
Keyboard typing automatically
This can be a few things.
1. Stuck keys, some keyboard can get dust, food, hair in them which cause the keys to stick. If you have a vacuum cleaner you can gently vacuum the keyboard to remove some of these obstructions.
2. bad keyboard, if after cleaning the keyboard the problem continues you may have a bad keyboard and it may need replaced.
If it is a desktop you can pick them up pretty cheap at almost any store that sells computer parts. If it is a laptop the keyboard can be replaced as well, but may need to be done by a computer repair shop or other professional.
3. virus, back in the 80s-90s viruses that allowed another person to take control over your computer where very common. Now days these types of viruses still exist but are not as common. You may need to update and run an anti-virus program or have your computer looked at by a computer repair shop. However, I would not do this until the first two solutions have been tried.
Further help can be provided if you let us know if full sentences are being typed, or just random letters.
Nov 11, 2014 | HP TouchSmart Computers & Internet
I purchased a ACER laptop last April. My problem am typing a sentence the curcer jumps backwards and starts typing in the middle sentence.
This is probably a software issue, I would reload the program you are typing with (e.g.Word) and try again OR it could be your palm resting on the touchpad causing this to happen, I always disable mine when typing (normally to do this you use the 'F' or function key (coloured blue or red etc) along with appropriate key on the top row.
Apr 04, 2014 | Acer Computers & Internet
When i type a sentence and make a mistake and want to add a new word into my sentence the space bar and any keys i touch type over my existing print. how do i correct this.
You need to toggle your overwrite/insert setting.
All you have to do is hit the "Insert" button on your keyboard. Hitting it once will set your type settings so that new text will be inserted instead of overwriting existing text. Hitting it again will toggle it back.
Mar 28, 2011 | Logitech 967437-0403 Keyboard
I have HP 510 note book. some keys, e.g. U, I, O, P, K etc are stuck in numbers. i cannot write a sentence. what should i do to make it function normally?
On the bottom left of your keyboard you should find a key marked Fn. On the top right of your keyboard you should find a key marked Num LK. While pressing the Fn key, press the Num LK key once. this should unlock the number keys and allow you to type letters again.
Good luck ;)
Feb 02, 2011 | Computers & Internet
What does the insert key do?
Press and the text you type will over write what ever you have on the screen. This is typically used in most applications to "type over" existing text without moving the other letters/numbers/characters around.
This is my example of how the insert key works.
hit the insert key and position your cursor at the "w" in works.
Now type WOW!!.
You should now have:
This is my example of how the insert key WOW!!.
Clever these programmers. :)
Keep in mind it depends on the application you are running also.
Have fun!
Oct 03, 2009 | Logitech Cordless Desktop EX110...
Cursor won't stay where I move it with the mouse
Hi, your first problem (and possibly second problem) sounds like it's the "Insert" function on your keyboard. I've seen this a lot. Find the Insert key on your keyboard. It's normally off to the right side with the Home, End, Page Up, and Page Down keys. When you have the problem, press the Insert key and then keep typing. It should toggle between the cursor moving with typing, and not. If this was helpful, please rate my response. Thanks!
May 15, 2009 | Dell Latitude D820 Notebook
Laptop keyboard issues
Is this a laptop? Some laptops will allow you to use these keys as the number pad/arrow pad as well in a certain mode. You will likely be able to turn off with a combination of the FN key plus one of keys F1-F12 (the function key will perform the action shown as a symbol on these keys).
If none of the symbols seems to indicate this mode. Try each combination and test to see which combination sets your keyboard mode back to normal.
Jan 05, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Six keyboard keys I don't know how to use
Insert: You press this key to toggle either overwrite mode or insert mode when you are typing documents. In overwrite mode, the characters will be replaced where your cursor is in the middle of a sentence and in insert mode, the characters will be added.
PRT SC: Short for print screen. You press this and the computer will take a snapshot of your computer's screen and copy it to the clipboard. Then you can open up paint or word and press CTRL-V to paste that snapshot of your screen as a picture in your document.
HOME: Takes your cursor to the very beginning of a document in a word processor.
SCROLL: Toggles the scroll function in a document.
PG UP: Moves the document you are looking at up a page.
PAUSE: Will pause a list being sent to your screen from the command window.
DELETE: Will delete whatever you have highlighted on your screen
SYS RQ: Check your notebook's information for this.
END: Will take your cursor to the end of the current line, paragraph, or document.
NUM LK: will turn on the numberlock function, allowing you to use the right side ofyour keyboard like a numberpad.
Thanks and please take a moment to rate as fixya.
Jul 06, 2008 | HP Compaq nx6110 Notebook
HP D8597A Keyboard Logo
652 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
