Question about Dryers
Lg electric dryer dlex7177wm Drum not turning
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Lg dryer drum makes a scraping noise when turned on, what could it be?
The noise is caused by the drum support rollers that are faulty.
Please supply the machine model number.
Feb 13, 2016 | LG Dryers
Water is running out of the vent hose in back of the unit.
If I have to guess it may have been some time since this unit has been serviced and cleaned out. I have a feaing there is lent stuck in the vent which is getting wet from the exchust, then draining.
Dec 03, 2015 | LG DLEX7177WM SteamDryer Front Load...
How do you change the thermostat
https://www.youtube.com/watch?v=nYua4dRsdeI
Jul 30, 2014 | LG DLEX7177WM SteamDryer Front Load...
Lg dlex7177wm heating element
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
If the dryer doesn't heat, the element assembly should be checked for continuity. The heating element assembly cannot be repaired and must be replaced if defective.
This is a specialised job and should only be attempted by technically competent persons.
Mar 13, 2014 | LG DLEX7177 Dryer
Drum doesn spin
If this product is new, you will need to take out the carriage bolts located in the back of the machine.
Carriage bolts are meant for the shipping process to prevent the drum from moving while in transit. Most manufacturers use between 2-4.
Check your product manual for details on the removal of the carriage bolts
Jan 23, 2014 | LG DLEX7177WM SteamDryer Front Load...
How to change vent location in LG DLEX7177WM
See the procedure listed in this manual on page 34. The model is not the same but most LG dryers are similar in construction. Good Luck.
LG Dryer Service Manual
Oct 02, 2009 | LG Dryers
LG DLE2514w electric dryer has loud thud every turn
Most model dryers are supported at thge rear of the drum with a bearing configuration, but usually the front of the drum is supported by some lining pads or guides. These help hold the rotation of the drum concentric. It sounds like your drum is not spinning concentric. My guess would be that some new guides might need to be installed.
Hope this helps...
Sep 02, 2009 | LG DLE2514 Electric Dryer
Dryers Logo
73 people viewed this question
Top Dryers Experts
