Question about Canon PIXMA iP1300 Printer
I replaced ink cartridge black and color cartridge is empty. I cannot print in black, the printer do not recognize the cartridge
SOURCE: replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Posted on Mar 31, 2008
  • 37 Answers
SOURCE: PIXMA iP6220D doesn't use/recognize CL-51 cartridge
Take the photo ink out.
Posted on Aug 19, 2008
  • 69 Answers
SOURCE: Printing black only documents with Canon PIXMA iP4000 printer.
Has anyone messed with the color schemes? they may cause that to happen too.
Posted on Oct 07, 2008
SOURCE: How can I print in " Black ink only " NO COLOR ?
I JUST PUT IN MY PIXMA MP 210 A NEW COLOR CARTRIDGEAND HE WONT START PRINTING.ALSO I CANT SCANNING ANYTHING WHEN CARTRIDGE IS NOT IN IT.IS IT NORMAL?
Posted on Dec 24, 2008
SOURCE: PRINTING WITH BLACK INK CARTRIDGE ONLY; COLORED CARTRIDGE IS EMPTY.
Apparently, if you hold the "resume button" (the one next to the power button) for about five seconds after you get the message saying to replace the color ink cartridge the machine starts printing. I did this after I went to "maintenance" under "preferences" and changed ink to "black only." At first that alone did not work, but after trying the resume button for 5 secs it worked okay.
Posted on Feb 21, 2009
I replaced the color ink cartridge. Now there is an "E" flashing alternately with a "5". The alarm light is on steadily, and the black ink and color ink lights are flashing. How do I...
E5 is a Cartridge cannot be recognized error.
Reinstalling the cartridge could clear the alarm.
If this does not work,
Removed both ink cartridges.
Turn off printer and unplug fron electrical outlet.
Wait at least 5 minutes.
This will let the printer reset itself.
Plug printer back in and turn on.
Printer will cycle and an E5 will appear.
Installed back ink cartridges.
Jan 26, 2011 | Canon PIXMA MP150 All-In-One InkJet...
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
Emptied out both black and color ink cartridges. Replaced black ink only. Printer is not printing. Getting flashing E and 5 on printer. Does this mean the printer will not function until I replace the...
You should maybe replace the color cartrige even if it`s empty just so the printer recognize that it have both slots taken.Then try to print out in black/white.
Feb 09, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
Kodak 5100 Needs Both Cartridges To Print?
Unfortunately, you cannot used the printer if one of the ink cartridge is empty., compare to the other printers you can print a black text or gray scale if the color is empty or one of the cartridge is empty.
All kodak printers work the same both cartridges should have ink on ink before you can use It.
Nov 04, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
Can't Print with black ink because all color ink are empty.
yes you need to install all cartridge before printing any page ...I have also this model...but u need to install all 4 cartdge. before printing any page wheather color or blacknwhite..
Jan 08, 2009 | Office Equipment & Supplies
Epson c62 color ink cartridge says it is empty when i just refill
I use cheap replacement cartridges about 20$ for 3 color/5 black....the printer usually doesnt recognize the cartridges ink level but it still prints......do you use actual epson replacements? If you use cheaper replacements you might have gotten some with dud chips...prob the cartridges fault, not your printer
Jan 01, 2009 | Epson Stylus C62 InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Canon PIXMA iP1300 Printer Logo
67 people viewed this question
old marine
old marine
