Question about Pioneer DEH-1600 CD Player
How do you remove the Pioneeer DEH-1600 radio from the dash of a car is there a special tool or do you have to get up behind the dashboard
  • 57 Answers
Remove the trim plate(thin plastic strip around your deck) you will see on the center of each side slots for two thin deck keys these always come with a new deck. you you dont have them ask a friend who has recently bought a deck(any make should be fine) or go to your local best buy and ask for a set MAKE SURE YOU ASK FOR THEM FOR FREE unless the installer you asked has purchased his own universal keys they will give you them.
Posted on Aug 27, 2010
Pioneer DEH-P3300 and 94 Mazda
Hello ryan_jaime,
It's good that you have an aftermarket Mazda wiring harness. It will allow you to make all of the connections in a well-lighted and comfortable location rather than fumbling around behind the dash.
If you are somewhat skilled at soldering, the most secure, electrically conductive, and positively insulated splices are made with solder and heat-shrink tubing. You can get the needed equipment from any Radio Shack, Lowe's or even WalMart. Be sure to put the heat-shrink tubing on the wires BEFORE you solder them together. I had to say that! Because I've forgotten many times! But if the soldering route is not for you, get properly sized insulated inline crimp splices and the appropriate crimping tool. Match up each wire by function on the Pioneer harness with the corresponding wire on your aftermarket harness. Most of the time, the wires will be color-for-color matched. But make sure, sometimes wires for things like "illumination", "dimmer", "mute", etc may not be the same colors.
Disconnect the negative battery terminal while you are working behind the dash. After you have the harnesses spliced together, plug the radio end into your Pioneer, remove the old radio from the dash opening, unplug the antenna and wiring harness plug and plug the other end of your spliced harnesses into the vehicle plug and the antenna plug into your Pioneer's antenna connector. Slide the Pioneer loosely into the opening, but don't secure it yet. Reconnect the negative battery cable and test the receiver. If everything works, slide it into the dash opening and secure it. Use the rear support stud and rubber bumper if needed. Install the trim ring or separately purchased dash kit as required. Put the "face-fixing" screws in to prevent removal of the faceplate if desired. Reinstall any dash trim removed and you're finished.
Hope this helps.
Jul 08, 2009 | Pioneer DEH-P3000 CD Player
I need to know how to set the time on a pioneer deh-1600 radio
http://www.generalmanual.com/Players/Pioneer-DEH-1600-In-Dash-CD-Receiver.htm
1.press source button and hold until unit powers off
2.press audio and hold until clock appears
3.press -> <- arrows to select hours from minutes
4.0up and down buttons to change the time.
manual can be found at above link ,hope this helps
Harry
May 16, 2009 | Pioneer DEH-1600 CD Player
Pioneer DEH-1600 CD Player. Loose connection somewhere behind device as sound goes off and on when jarring stereo. How do I disconnect and pull out stereo to inspect. I have removed screws but stereo...
If the unit was installed with a cage (most likely if your car is an domestic) you will use two pioneer keys that are L shaped that came with your radio to remove it and it will slide right out. If it was installed iso din (if your car is an import) using the factory brackets the radio is screwed into the car you will have to disasemble the dash which varies depending on the vehichle. What kind of car is it?
Apr 22, 2009 | Car Audio & Video
Dashboard Removal 1995 Ford Taurus?
The dash is actually easy to remove just get fingernails ahold of it and start pulling around that lip . Dont get crazy just apply even pressure till you get it removed .
Jan 27, 2009 | 1995 Ford Taurus
1987 Volkswagen Golf - tach light out, no power to radio/CD player
could be just a blown bulb for the tachometer.check the wiring behind the radio .you may have to get special tools to remove the radio in any car parts/stereo store
Oct 15, 2008 | 1987 Volkswagen Golf
Clock
To set the clock on the Panasonic DEH-1600 car stereo, follow these instructions:
  1. Turn the radio off by pressing and holding the SRC button (under the label OFF).
  2. Press and hold the Audio button in the upper right corner of the radio. After holding the button for about 3 seconds, the clock will begin to blink (the hours).
  3. Use the up and down arrows to increase or decrease the time hours or minutes. Use the left and right buttons to toggle between setting the hours and/or minutes.
  4. When done, push and hold the Audio button again fir about 3 seconds until the clock stops blinking (hours or minutes).
Sep 02, 2008 | Pioneer DEH-1600 CD Player
How do I get it out of the dash
the radios come with 2 removal tools. you remove the trim plate then slade the tools in one per side... what kind of car? i may be able to tell you a different way of removing it..
Sep 05, 2007 | Pioneer DEH-P44 CD Player
Pioneer deh-1600
i know theres many of people out in this world using google or what ever and need this so here it is for pioneer DEH-1600
yellow- Batt/mem. 12v
red- ignition/acc. 12v
blue- power antenna
black- ground
orange- positive dimmer
purple-RR +
w/b - RR -
green-LR +
w/b - LR-
grey-RF +
w/b - RF -
white- LF +
w/b - LF -
Aug 26, 2007 | Pioneer DEH-1600 CD Player
Car stereo
Here is a link to your manual: http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070337_37850,00.html
May 17, 2007 | Pioneer DEH-1400 CD Player
Pioneer DEH-1600 CD Player Logo
195 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
