Question about Lexmark X3480 All-In-One Printer
My printer keeps showing cover open when it isn't
  • LXK Chris
    LXK Chris Aug 26, 2010
    Maybe the cover sensor got stuck? Try to remove the cartridges from the printer. Close the cover. Unplug the power adapter from the printer. The power adapter is the rectangular black box behind the printer where the power cord is attached. Replug after 30 seconds. When the printer's ready, reload the cartridges. If problem continues, I suggest you contact Lexmark technical support to further investigate the problem.
Canon mp470 printer says cover is open when it isn't.
If the cover is closed and you have found the switch and tested it ok, try to unplug the printer and restart.
Nov 11, 2012 | Canon PIXMA MP470 All-in-One Printer
The printer cant print it keeps showing "!" or
The blinking exclamation point means that the cover to the printer is not closed all the way. Try opening and closing the cover to get rid of this error. If there is another picture like an ink drop or a sun that is also blinking at the same time then the error can mean something different.
Here is a link to your manual for your printer that includes troubleshooting erorr codes:
http://support.dell.com/support/edocs/systems/1710n/en/om/1710_en.pdf
Oct 14, 2011 | Dell 1710n Laser Printer
When i try to print on my Lexmark 2300 it keeps saying scanner unit is open, but it isn't. I've turned it off and on opened and closed the unit but this hasn't helped
It could be the cartridges in the carrier. Please follow the steps below to identify and fix the problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Unplug and re-plug the printer into the power outlet to reset it.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge. You may also try to insert a different known working cartridge to determine if the cartridge you are currently using is faulty.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 15, 2011 | Lexmark Z2300 InkJet Printer
I keep getting the " covers open " on my dell 926 printer. help
sensor or switch not working or sensing find and figure out why not working maybe dirty blow out with compressed air!!!!! :)
Jul 06, 2009 | Dell 926 All-In-One InkJet Printer
Replaced Drum still says "Replace Drum Soon". How do I reset on a Brother 7420?
Reinstall the new drum unit, keeping the front cover open. Press OPTIONS. Press 1 when the display shows REPLACE DRUM? 1.YES 2.NO ACCEPTED. Close the front cover.
May 28, 2009 | Brother MFC 7420 All-In-One Laser Printer
Cover open showing
I have this happen all the time. There is a flap type door in back that you have to open and shut.
Nov 18, 2008 | Office Equipment & Supplies
Lexmark x3480
This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located
Sep 24, 2008 | Lexmark X3480 All-In-One Printer
X3480 cover open message
Ajkill is right, although his description isn`t very exact. Take off the complete scanner part: (back hinges first, then the blue arresting lever at the front), disconnect the flat band cable and the power supply for the scanner part and take off the complete scanner part. You´ll see a triangular part that goes in a slot of the dark grey cover which covers the rest. It should press againt a white lever which itself presses a little black switch sitting on the printed circuit board. If this white lever has fallen off the switch is always in "Cover open" position. To get it and reposition it (if it isn`t broken) you have to take off the dark grey cover which covers all the rest: take off the front screws and carefully lever out the sides with a small screw driver. Good luck with the repositioning, it is very fiddely and to see how and where it has to go you best use a magnifying glass!  But I could manage it and my printer is working now again. And good luck with fitting it all together again without breaking anything!
Mar 19, 2008 | Lexmark X3480 All-In-One Printer
Lexmark X3480 All-In-One Printer Logo
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
