I have a oki b4600 printer that is giving me error 120 when i turn the power on. i have no manual to look up code. Can you tell me what this means? Thanks. Rick
B4600 error code 173
The thermal cut-off is defective on the fuser. The fuser assembly will need to be replaced. If your printer is less than a year old you can get it repaired thru OKI DATA.
Jul 08, 2014 | OKI B4600 Printer
Error 120
This error is a PU Board Fan motor error.
Check if the fan is properly connected, if necessary replace the fan.
Should fix the problem.
Jul 14, 2011 | OKI B4600 Printer
Err 120
Jun 25, 2011 | OKI B4600 Printer
I have an Oki B4600. I recently replaced the drum & toner. The print is very light and part of the page is illegible.No error message is displayed. Please advise
The problem is most likely with your fuser and will need to be replaced. Contact Oki tech support and see if your printer is still under warranty, you will need to give them your printer's model number and serial number. Sometimes the cheapest solution is to replace the printer all together.
May 19, 2011 | OKI Electric Industry B4600 Laser Printer
My OKI B4600 is displaying error 134
It means the printhead [laser] is "missing" - but usually it's just the data cable at the end of the printhead has popped out. Very common - we have hundreds of Okis at our corp and I've fixed this many times. Turn the power off, pull either the left or right plastic clip AWAY from the printhead, and carefully insert the data cable back into the connector on the printhead. Put one end of the printhead nearest the data cable back into its plastic clip, and make sure the spring is seated on its little post on the bar, and then click the rest of the printhead into the clip on the end opposite of the data cable, again making sure the spring is seated on its post. Turn the printer on - your error should now be gone.
Mar 01, 2011 | OKI Electric Industry B4600 Laser Printer
CAN ANYONE TELL ME WHAT 173:FATAL ERROR 2A14 MEANS?
Your Fuser is not getting to temperature. Make sure the printer is plugged directly into a wall outlet. If it is then you need to replace the fuser.
Jan 11, 2011 | OKI Electric Industry B4600 Laser Printer
Resetting image drum after replacing for oki b4600
On the printer press the menu button until you reach MAINT.Then press the item + button until you reach DRUM CT RESET. Then press select.YOUR DONE
Oct 03, 2009 | OKI B4600 Printer
Oki b4600 displays check image drum toner senror error
Try this:
Press Online
Press Menu repeatedly until MAINTE MENU displays. Press Select.
Press Item+ until DRUM CNT RESET displays.
Press Select.
Jul 01, 2009 | OKI B4600n Printer
Oki b4600 drum reset ?
On the printer press the menu button until you reach MAINT.Then press the item + button until you reach DRUM CT RESET. Then press select.YOUR DONE!!!!!!!!
Jun 19, 2009 | OKI B4600 Printer
248 people viewed this question
k24674
