Question about ASUS P4P800-E Deluxe Motherboard
Lan card driver
.....cannot install the lan card driver into windows2003...
I need the software for ASUS P4P800 SE because i dont have any driver for may ASUS P4P800 SE board thnks
Posted on Jul 10, 2008
  • 2,351 Answers
Hi macubex,
In what manner did you attempt to install the lan driver?
Did you run the *.exe? Try a more direct method. First go to this Asus link. (Click on the link).
Look to the right & choose you're OS. (Win2003).
Click the + sign to the left of LAN. Create a folder on you're desktop. Download & save the file: ( into that folder. Uncompress the .zip file within the folder.
Next click the start button & slide up to & click on control panel.
Double left click on System icon. System Properties will open. Click on the hardware tab & than click on device manager button.
Scroll down to Network Adapters & click the + sign. There should be a yellow ! point. Right click once on the yellow ! point & slide up to & left click on update driver. Windows hardware wizard will open. Click in the circle, No, not at this time & click next. In the next window click in the circle Install from a list or specific location. Than click next. Remove the green check mark by clicking on it once, next to Search removable media.
Than click on the Browse button. Go to you're desktop & find the folder you downloaded & uncompressed the file
All you need to do is click on the correct folder & watch the OK button. (It will high light a bit when you click on the correct folder), than click OK & the lan driver should install. Once the lad driver installs, close all windows & restart the system.
When windows finishes loading, load windows update service & check for LAN updates & install it. (All done).
If this fails to work there could be a problem with the Asus integrated (onboard) LAN controller.
Good Luck!
Please let me know if this has helped.
Posted on May 06, 2008
How to install a LAN Card Driver
installing LAN Card driver either u need to installed manual or automtically .
1. automatically each vendor have its own driver for the lan driver card . so once u download the driver applicattion u just double click and follow the steps it will detect the lan card.
2. manualy u have to extract the the driver file and put it in specifict folder then u have to right click on my computer then click on management the click on device manager then right click on the Lan device which will be makrd yes yellow quesiton mark then u have click on update the driver and select browse my computer to install the driver and then give the path o exit extracted folder you will be done.
Sep 23, 2011 | Computers & Internet
If it is not onboard LAN card reinsert it after cleaning it's concact point with pencile eraser. And user proper driver for it. I think you don't have proper driver for your LAN card.
Oct 29, 2010 | Computers & Internet
Network problem
You've installed the incorrect LAN card driver. Please verify if Lan card attached is correct to the driver youve installed. thanks
May 22, 2010 | PC Chips PCChips P17G Motherboard - V1.0,...
My lan card drivers are not working. I have Intel D101GGC Motherboard. Please help in that problem. As soon as possible..
1st you check the Lan card driver is properly Installed.
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Click on the Network Adapter
  • See the Lan Card Driver.if it is not available then Install the Lan Card Driver.
  • You can install driver from this site Lan Card Driver
  • If Lan Card Driver is Install then check It is disable from the network places in the control panel.
Mar 05, 2010 | Intel D101GGC Motherboard
My dell lan card is not working,i cannot connect to internet.
Either the LAN card is faulty or the LAN driver is not installed and/or not configured properly or the LAN cable is faulty.
Check Device Manager to see if the LAN driver is installed, working and enabled. If not then re-install the LAN card driver.
If the LAN driver won't install or detect the LAN card then it maybe faulty and needs to be replaced.
Try a different LAN cable.
Is all the LEDs on in the modem?
Try rebooting the modem (power it off for 30 secs and power it up again).
Nov 14, 2009 | Dell Ethernet Card Network Adapter
Ethernet not work
Check in the Device manager to see if all the devices are enable and working.
The one with a yellow ? against that device requires a driver installation.
Is the LAN device OK?
How do you intend to setup your LAN, is it for Internet access or a home network?
I need more information on your problem, together with error messages.
Jun 24, 2009 | HP Pavilion dv6000z Notebook
LAN card not installing
u can use any brand . there's no problem in that . installation procedure is very simple. just buy a pci lan card. Insert it in the pci slot. Then switch on your computer , insert the driver cd provided with your lan card , then install the appropriate drivers.
Then, you can connect BSNL Broadband by connecting your ADSL modem with your LAN card.
Hope it helps..
Mar 06, 2008 | Computers & Internet
Windows2003 server networking problem
if the pc mother board came with a driver, install network driver/speed.make sure your network card are working very well and you can fastening the speed of the modem before querying it
Jan 31, 2008 | Microsoft Windows Server Standard 2003 for...
Do i have a lan card installed on my system??
Just check it in the device manager ,, goto device manager by right clicking on my computer... if u have network adapters then u have LAN ... and if u have lan u don need drivers it will be inbuilt ...
Nov 30, 2007 | Compaq 2Mbps Wireless LAN PCI Card for...
ASUS P4P800-E Deluxe Motherboard Logo
166 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
