It means it's time to get the oil changed. It should be at 100% after it is changed and it will decrease over the mileage you drive to let you know it's getting close to change.
The 2006 impala has an oil life percentage once oil is changed to reset the the meter turn on ignition do not start car push gas pedal three times meter will reset to 100%
Also, after you have had it change and it still says 0%. Press and hold the check button to reset the counter. (Note: Only reset the meter when you are sure that your oil life IS NOT 0%, this will help with false readings.).
