Question about TallyGenicom Office Equipment & Supplies
OUR tALLY 8008 IS A NETWORKED PRINTER. FOR SOME REASON IT IS NOT PRINTING FROM MY COMPUTER. IT WAS PRINTING FINE THIS MORNING AND IS STILL INSTALLED ON MY PC. THE MESSAGE "THE DOCUMENT FAILED TO PRINT IS WHAT COMES UP ON THE SCREEN"
  • 119 Answers
You may need to clear out your print que and restart the print services. Open a command window by typing CMD in a run box. Type the following in the command window after it opens:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
There will be a delay after you hit enter when you type the net stop and net start commands.
Posted on Aug 26, 2010
Hi I have a second hand Tally Genicom 8008 and I can't get it to print anything. I've just downloaded a printer driver for it and am using it with an iMac with OS X Leopard. When I send something to...
First is worth checking the C (cyan) toner is not causing the problem with printing, the easiest way to do this is to print a configuration or test page via the menu on the printer to see if it will print. If the printer will print a page via its menu it should then be capable of printing from the computer system,
The Menu / Test Page can be printed in the following way;
  • Put the printer OFFLINE
  • Press the MENU/ENTER button
  • The display should read
The printer should print a page, if it does not it sounds like the cyan toner is empty and is stopping the printer printing.
If the Menu / Test page prints ok this indicates the problem may be connectivity or driver related.
The first thing I would say is there are issues with printing to the the 8008 from Mac's particularly with the Intel processors.
There are also issues with versions 10.4 and over.
Some suggestions,
  1. Print using TCP/IP, ensure the printer has a IP Address set and also the port on the Mac is set to the same IP address. (dont use Apple Talk)
  2. Ensure you have the driver for the 8008 (not the IP8008) the IP8008 driver will not print to the 8008 and vice versa.
  3. Try printing from a simple application for example Sticky Notes, just to see if the problem may be down to the size of data files.
Apr 06, 2011 | TallyGenicom 8008 Laser Printer
I don' t know de printer' s ip address. how I can learn it? the printer is tallygenicom 8008
You can print a configuration page this will show you the current IP Address set in the printer, this Can be printed in the follwoign way;
  • Place printer OFFLINE
  • Press MENU / ENTER button
  • The display should read TEST MENU (if it does not press > repeatedly until it does)
  • Press > until CONFIG PAGE is seen.
The printer will print out a configuration page this will show the network settings
Dec 01, 2010 | TallyGenicom 8008 Laser Printer
I need a linux driver for tally genicom 8008 colour printer. Does anyone have one? or know where to get one?
I have the same printer and run Linux Mint 13. Here's what I did:
Went to http://foo2slx.rkkda.com/ and followed the instructions for installing a Lexmark c500n.
Opened a browser and went to http://localhost:631 (the CUPS admin page).
=> CUPS for Administrators => Adding Printers and Classes
Add printer.
Follow the instructions until you reach a page with "Or Provide PPD File" at the bottom. Click "Choose File".
Navigate to where you unpacked the foo2zjs driver, there should be a folder in there called PPD: you want Lexmark-C500.ppd
Set what defaults you want do some printing.
When you have finished marvelling, perhaps give a thought to donating to the chap at foo2zjs for his hard work...
Jul 19, 2010 | TallyGenicom 8008 Laser Printer
Tally Data Recovery
I suspect you do not have a problem with a TallyGenicom 8008 more likely with a the Tally Solutions ERP system check the following page for tallysolutions contacts and support
http://tallysolutions.com/newwebsite/html/index.html
May 30, 2009 | TallyGenicom 8008 Laser Printer
Tallygenicom 8008 not recognised in xp
I do not think there was a driver version 1.5 for the 8008 I believe only one version of driver was released for the 8008 for XP this was version 1.00
I think your search for later driver will be fruitless.TallyGenicom went Chapter 11 and are no more, I think thwy were taken over by dascom (www.dascom.com) who now sell Tally Dot Matrix printers.
I think your best option would be to check how the pritner is connected.
If connected via USB ensure the printer is correctly plugged in, make sure you have the USB cable connected to the USB port on the printer NOT the network port (it happens!!)
Plug the printer into a different USB port on the PC in case there is problem with the particular port.
Try a test page from the printer driver once you have installed it, see what errors you get.
If the printer is networked, ensure you can PING the IP Address, in the printer driver ADD A STANDARD TCP/IP port to print to the printers IP Address.
Post any errors or specific problems you see, how the pritner is connected we may be able to help some more.
May 04, 2009 | TallyGenicom 8008 Laser Printer
SVC E9 ERROR
butta via la stampante e prendi una hp
Jan 17, 2009 | TallyGenicom 8008 Laser Printer
Tally 8008 not printing mac OSX 10.5.6 leopard
Found a solution. We connected 8008 printer to imac running Tiger & we can now print via network on any of our emacs running Leopard. Not ideal but at least we can now use the printers. I would still love a dedicated driver to work direct but I suppose this will do for now.
Jan 13, 2009 | TallyGenicom 8008 Laser Printer
Tally Genicom 8008
The residual image often occurs if the Transfer Drum cleaning roller is not located correctly in the printer, as this cleans the previous image of the transfer drum. In some cases where the printer has been moved or shipped, this cleaning roller may need to be relocated in the printer to ensure it is in contact with the transfer drum.
I believe the cleaning roller on the 8008 is located just behind the OPC belt, try removing this and clean the contacts at each and of the cleaning roller.
Ensure the cleaning roller fits back in the printer ok and give it a try.
Dec 10, 2008 | TallyGenicom 8008 Laser Printer
Tally 8008
SVC E2 error on the 8008 indicates a Main Motor Failure.
Jun 23, 2008 | TallyGenicom 8008 Laser Printer
50 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
