Question about Ariston Technologies Ovens
Hi i bought ariston cooker in sharjah where i used line gas it was perfect then i moved to dubai where i need to use cylinder the technician changed the nozzle but one nozzle is not proper because the vessels get stained at the bottom now i need to move to india (chennai) will i get technician to make it alright
4 Suggested Answers
SOURCE: NEEDED MANUAL FOR TECNIK COOKER
I have a manual if you e mail me your address to monica230157@hotmail.com, I'll photocopy it and post it on to you.
Posted on Jan 05, 2009
SOURCE: Ariston FB 82 C IX
Hi. Did you find this manual? I am in the same situation.
Regards, Steven
Posted on Mar 24, 2011
SOURCE: hi i need an i
http://www.buyspares.co.uk/delonghi/cooker-oven/dfs090do-c9t0dx001x/catalogue.pl?shop=delonghi&path=111489&model_ref=479299&illustration_ref=1108498
this is a link to the pdf of the manual also available to buy from this site for £2.50
Posted on Sep 13, 2011
Ec600dodlm cooker the main oven is only blowing out cold air
IS IT GAS OR ELECTRIC? IF ELECTRIC YOUR HEAT ELEMENT MAY BE GONE NEED TO REPLACE IF GAS THE PILOT LIGHTS MAY NOT BE GETTING ANY GAS DUE TO CLOGED LINES. ASK SOME ONE WHERE YOU BOUGHT IT TO SEE IF THEY CAN TELL YOU.
Jan 31, 2015 | Ovens
Got a fan assisted gas oven. Trying to bake a cake
Temperature control with gas ovens is not an exact science. However the control should be better than you say.
Have you tried reducing the set temperature to compensate for the 'overshoot'. It may be worth a try.
Jan 04, 2010 | Ariston Technologies Ovens
Used oven purchased in US to work in Trinidad and Tobago (Caribbean) Only LPG Gas is supplied here, it seems as if the gas type is not what the oven was designed for. Main burners fires up and then cuts...
Hi i was reading your problem go to the appliances parts store tell them you need a gas valve Regulator that will change it from lpg to natural gas its natural gas it needs on the the 10 psi i think it should go back on the 25 psi thats only Regulates the flow of gas to high an to low dats all..i can be reach babeboz2000@yahoo.com
Nov 14, 2009 | Blodgett DFG-100 Gas Single Oven
I have an Ariston oven (model;208587057) but no manual
Hi
Press and hold the two buttons with the casserole dish on (one is crossed out) and use + or - to change the time.
Hope that helps.
Jun 09, 2009 | Ariston Technologies Ovens
Ariston Oven power trip
Take off the back cover and check whether the terminals on the heating element are touching it. Normally caused by some earth leakage currents flowing from heating element to ground circuit.
Mar 01, 2009 | Ariston Technologies Ariston FO98P...
Problem gas cooker
Go on line to westing house.com and look up your model, go to the help page and ask for their assistance, gas is not something to fool around with, I suspect it is the orifice that have not been converted to propane, I had a similar problenm with the stove top burners, and the orifices needed to be changed to (converted ) to run on propane gas.Some times manufactures send the converter orfices but most of the time you have to ask for them if you are running on propane, most stoves are set up for natural gas not propane.Most of the time the store clerks don't ask you if you will be running on propane , you have to tell them and the professional who installs the unit needs to install the orifices. Please be careful! If you installed the stove your self, you need to contact a professional installer to correctly adjust these .
Jan 05, 2009 | Frigidaire FGB24S5A Gas Single Oven
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
Ovens Logo
37 people viewed this question
Top Ariston Technologies Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you an Ariston Technologies Oven Expert? Answer questions, earn points and help others
