Question about Garden
Hilti tp800 parts diagram - Garden
3 Suggested Answers
  • 61 Answers
SOURCE: I have a hilti TP800 that will not hammer. no
TP800 are that takes me back. right hear we go...
as over people have sugested remove the 4 screws and the black plastic cap from the top of the machine. you should be able to see the con rod and the crank gear, and in front of the crank gear you should see the small gear which is the top of thr armature, you may have to scoop out some grease in order to see it. Check that the con rod is not broken. earlier machines had aluminium cod rods but the later models have plastic ones which were prone to breaking. this isn't to say that the aluminium ones never broke because they did and wow what a mess may made when they did. if your con rod looks ok, try this... keep your hands clear of the open gears, and put some glasses on. turn the machine on and make sure that the crank is turning. look at the small gear on the armature to see is it is wobbly. the small roller bearing at the top of the armature use to callapse causing them to wobble. this would strip both the gears. a good sign of this is metalic parlicles in the grease. this fault is very expensive as you will have to replace the armature, bearing, seal, and the crankshaft. ouch...BUT DONT DESPARE. if this looks ok, it must be the piston rings these are cheap, fairly easy to change and available, as they are still used on more current models. the part number for these piston rings (o-rings) is 13772. want to know how to change them?.. read on...The hardest part is removing the chuck as you must remove the retaining clip at the tip of the chuck. hilti make a special tool for this, but it is possible with a good set of circlip pliers, 2 flat screw drivers and 4 hands. top tip...Remove the rear handle assembly, just remove the 4 screws and pull it off, now the machine can be stood upright on a workbench. Wear safaty goggles and put a chisel in the chuck, this will help you not to loose the clip when it flies across the workshop, I hate it when that happens. once you have the clip off its easy from now on. and don't worry, there is an easy way to get it back on. ok, the clip is off. remove the washer and the plastic chuck cover. remove the circlip, remove the chuck sleeves, dont loose the 6 balls or the roller. now there is another large circlip which holds on the black plastic cover. remove them both. now you can see the 6 bolts which hold the machine together. remove them. remove the chuck.you will see a large o-ring around the cylinder, remove it. Now with a screw driver carfully split the cylinder at the point where the o-ring was sitting. carefully pull out the inner cylinder. dont loose the small plastic balls. if they fall out dont worry. put them to one side. inside this cylinder you will find the follower piston, just tap the clyinder on the workbench and it will fall out. replace the o-ring, smaer with grease and replace. The drive piston is probably still inside the red casing. Simply pull the con rod off the crank and tip it out of the casing. on early models this piston had 2 seals. 1 teflon ring over a green rubber O-Ring. on later models these were replaced with an o-ring, the same as the follower piston, the earier type may not be available in which case you may have to replace the pison as well in order to fit the newer o-ring system. once the seals have been replaced, smear with grease. place the piton inside the cylinder just far enough so the conector pin cant fall out of the drive piston. Replace the plastic balls into the detents in the cylinder. use grease to hold them in place. Replace the cylinder into the caseing but make sure that the cut out at the end of the cylider is facing down. This is where the armature gear sits. as you push the cylinder in ensure that the con rod is hooked onto the crankshaft. reassemble in reverse order. use grease to hold the chuck balls and roller in place. dont fit the rear handle yet..now for that clip that caused all the pain at the start of the job. PuT YOUR GOGGLES ON. stand the machine upright on the workbench and get somone to hold it. place the clip on top of the chuck body tube. get a block of wood and place it on top of the ring, and hit it with a hammer. this will knock the ring on 80% of the way, now tap it on with the hammer. refit the rear handle. your done,,,if you removed all the grease replace with a similar type. 70 grams (3 oz) in the crank case under that black plastic cover..
Well I hope that helps, its not as bad as it sounds.
good luck.
please leave feedback .
if you have any more questions please email me.
if you want a parts diagram i can email you a drawing of a TE804 which is virtually the same machine with a slightly different chuck.
paul@wysehire.gi
www.wysehire.gi
Posted on Dec 13, 2009
  • 123 Answers
SOURCE: I have a Hilti TP800 with a worn cord. Any tips on getting the two nuts off so the handle can be taken apart....
Just take a flat head screw driver and put it in on one side of the slot. Tap on the screwdriver in a counter clockwise motion. It usually does not take much to get the nut started after that you just spin the nut off. the rod will then just slide out the other side.
Posted on Nov 27, 2011
I need a parts diagram for a hilti hammer drill TE-56
Request the diagram directly from Hilti.
Feb 06, 2017 | Hilti Drills
What is the IP address for the OfficeConnect TP800
Open door trim,sprayed rust off spray through cam &its attached parts &try to close &open constantly
Dec 10, 2012 | 3Com OfficeConnect TP800 Networking Hub
Nov 23, 2011 | Hilti Drills
The transformer/control pack housed within the handle of the TP800 Hilti is suspect. This item has one side aluminium coated, and this housing incorporates a PCB. When the drill is energised it runs at a...
Billy-
Replacement parts are no easily found without going through one of Hilti's authorized repair service centers. Visit www.Hilti.com to find one near you - you may be able to purchase the part directly from the service center. Maybe its worth it you you to have them do the work as well - Hilti tools have a great lifetime warranty and service repair policy: Link
Hope this helps.
Regards,
DIYpro
May 09, 2011 | Hilti Hammering
Hilti te5 problems
go to Hilti.com and you can download a breakdown for this tool. Let me know if you need more help with the repair.
Mar 12, 2010 | Hilti Drills
I have a hammer drill UH-240A and need motor brushes. Where can I find them?
ive checked the hilti website and theres no brushes avaiable
this is a link to the exploded diagram and parts listing
http://www.us.hilti.com/data/techlib/docs/tool_schematics/sfs/UH_240_A.pdf
it looks as though you would need to replace the motor
heres the link for it
http://www.us.hilti.com/holus/modules/prcat/prca_fuse.jsp?RANGE_OID=31634
hope this helps
if it does please vote
Nov 09, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Need rear moter bushing for TE-17
Hilti has not carried parts for the TE17 for about 15 years. That tool was produced from the 60's up until the early 80's. The part you are looking for is an Oilite bushing that is held in the motor end cap. Even though the part is no longer available a good machine shop should be able to make you one.
Oct 25, 2009 | Drills
Parts for my hilti te 76
Call 1-800-879-8000 or go to Hilti.com for a schematic or call for assistance.
Sep 22, 2009 | Hilti Drills
Problem with Hilti JackHammer TE76
Yes there is but it is somewhat confusing to navigate. It is Hilti.com. If you can give me some idea what parts you are looking for I have that breakdown at work and will help you. It is the TE76. Let me know and I will do what I can or you can call their toll free number in the US at 1-800-879-8000 and ask them for help also
Jan 25, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Garden Logo
912 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
