Question about JVC HD-56G886 56" Rear Projection HDTV
JVC HD-56G886 replaced lamp now direct tv picture in and out
Call your cable company, the lamp has nothing to do with the inputs, Maybe one of the connections is barely connected from moving the TV to replace the lamp.
Posted on May 11, 2008
How do I discharge a JVC hd-56g886 TV to change out the lamp
no need to discharge any thing just un plug tv pull out lamp assy. and replace clean dust out of the air filter and any whear else turn on and reset lamp timer in menu good luck ,butler
Oct 02, 2016 | JVC Televison & Video
JVC HD-56G886 tuner stopped working
My (unfortunate) guess would be the Tuner received a static discharge when you were changing the antennas... this time of the year is bad for static - if you're in a "Winter" climate.
Receivers have a very sensitive FET or MMIC amplifier right inside from the antenna connection to make it better for picking up distant stations.
However, this same "sensitive" amplifier is also prone to being destroyed by even a small static discharge... especially if the tuner had its power turned ON.
Sad to say, it's likely toasted... :-(
(I hope I'm wrong... but you have already tried all other possible solutions)
Jan 12, 2013 | JVC HD-56G886 56" Rear Projection HDTV
Jvc tv wont come on.
your lamp is burned out-easy and fairly cheap fix. Order a new lamp and install it according to the instuctions sent with the lamp.Dont believe that you need to take it to a service to have it fixed, this should be less than $150 fix-good luck
Feb 07, 2010 | JVC LT-42X579 42 in. LCD TV
Have jvc model HD56G886. heard a pop..picture went off...blue light over on/off switch blinks quikly. Lamp go bad?
lamp is burned out, reorder one online and install-cheap and easy, the lamp will come with instuctions
Jan 15, 2010 | JVC HD-56G886 56" Rear Projection HDTV
Have black dust looking spots on my screen.
Howdy;
Yes there is a way. The easiest for you would be to remove the back top of the TV. That will give acess to opt lense and mirror. But first check the Lamp and inspect the lense that the Lamp into. It does not take a lot to cause your concern. Use super soft cloth and wipe surfaces.
Good Luck,Big Irish.
Nov 22, 2009 | JVC HD-56G886 56" Rear Projection HDTV
TV was on and had a picture, and then nothing w/flashing power
Your lamp has blown. Time to get a new one.
the hyperlink button doesn't seem to be working, but just copy and paste this link into your browser. It is linked directly to your tv's replacement bulb.
http://www.discount-merchant.com/JVC-LCD-Projection-TV-Lamp-TS-CL110UAA-TS-CL110U-p/jvc-ts-cl110uaa-hd-56fn97.htm
Nov 11, 2009 | JVC HD-56FN97 56" Television
JVC HD DILA 56G886. replaced lamp and now it shuts down after 10
we found that it is an auto shut off system on the TV due to over heating. The lamp, if not cooled correctly shuts down. We added a mini fan in the back and it seems to work fine now.
Jan 25, 2009 | JVC HD-56G886 56" Rear Projection HDTV
Dark Screen
The lamps in these normally last about 3000 hours (if your really lucky). The bulb will start to loose it brightness as a matter of due course at about the halfway mark. It maybe that you are running the unit in the non economy mode that they are fading faster then normal.
The sets have a reputation for not being good with lamps though.
Have a look at the lamp though, make sure it has been off for at least an hour to let it properly cool and check for dust that has settled on it. Also if you wipe the lamp, make sure it is with a dry cloth, or allow plenty of time for any moisture to completly dry before turning it on if you use a damp cloth.
Apr 13, 2008 | JVC HD-56G886 56" Rear Projection HDTV
JVC 56
thrse television are ila? which i a projection lamp type tv. burn in is internal to optics and will rigure replacment of light engine
Jan 29, 2008 | JVC HD-56G886 56" Rear Projection HDTV
JVC HD-56G886 56" Rear Projection HDTV Logo
102 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
