Question about JVC Car Audio & Video
I have a KQ-DV5105, but no manual and no remote. How to get a picture up from a DVD disk??
    Brigadier General:
  • 3,513 Answers
Hi
Please check the link bellow for the manual…
http://www.manuals-in-pdf.com/index.php?main_page=product_info&products_id=265652
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 26, 2010
I have a Coby DVD938 dvd player. I have sound and picture but the color on the picture is only in black and white. How do I fix this?
Make sure the video connections are in the correct ports If they are, get to the screen with the coby logo, make sure no disk is in the tray and reset the DVD player with remote:
Make sure you do not have a disk in the tray. Using the DVD player remote control:
  1. Press 'Setup'
  2. Press the right arrow 4 times
  3. Press the down arrow 7 times
  4. Press Enter
Jul 16, 2011 | Coby DVD938 Theater System
I am receiving no picture when I play the dvd
check cables.check for video mode on remote
Jul 08, 2009 | Televison & Video
No image on LCD Screen
my problem is that the disk almost got stuck in the DVD player, might have been a loose bolt or something. any ideas?
Apr 10, 2009 | Televison & Video
Sudden loss of picture, sound comes though ok
It sounds like the exact same problem that my son recently created. The only solution I've determined is to reset the player to it's default settings. Although it took a little while (since the video display was not present), I finally found the right combination of buttons to push on the remote and now the problem is fixed. Insert a disk, then push the following buttons: Stop, Stop, System/Menu, >, >, >, v, v, v, v, v, >, OK
After the above sequence of buttons, the main player screen should reappear on the tv.
Croce23
Jan 04, 2009 | Philips DVD727 DVD Player
Progressive scan mode
THis one should be easy--just read it in the manual--reset your video mode by removing any disks from the player, close the drawer, and then press and hold the "stop" button for five seconds. The green power button should flash red and back to green. Hope that solves it.
Sep 17, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD Tray won't open
The quickest way I've found is to just remove the upper casing, unscrew the disk holder and take the disk out that way. The disk holder will look like the silver part in this picture http://www.vintagecomputing.com/wp-content/images/nesdvd/nesdvd_03_large.jpg although your could be black or other color.
Jun 18, 2008 | Memorex MVD2042 DVD Player
No Disk
When I try to play a DVD, operation seems normal, the unit makes a slight noise like the disk is rotating and "Loading" is displayed. Then after about 30 seconds the message "No Disk" is displayed. Then just the Polaroid screen is displayed. I have lost the remote control but surely the unit will play using the front panel buttons. One thing, only the remote is named as having a Setup Button in the manual but the unit has no such button.
Apr 12, 2008 | Polaroid PDV-0813A
DVD tray will not open
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be taken apart to remove the disk.
Feb 25, 2008 | Dual Presidian DVD Recorder
DVD Tray will not open
Uhm..
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Dec 21, 2007 | Jwin JD-VD130 DVD Player
Vcr to dvd recording
As i recall, +r's will only format in dvd vr, the unit does not like high speed recording disks. switch to dvd drive - insert blank disk - if no format screen - goto (on remote) setup - onscreen menu - system setup - disc setup - new disk format - hit center button in ring on remote to change to vr or move up to reformat as vr. once disk is formatted, use record speed button on remote to set record speed 1,2,4,6 hr then switch to tape deck with tape in and stopped at begining, on remote hit dubbing, it will ask you confirm dubbing vhs-dvd .... toggle over to yes & hit center button... away you should go... c245 is a copyguarded tape.
Oct 09, 2007 | Sansui VRDVD4005 DVD Player/VCR
Car Audio & Video Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
