Question about Canon PC-940 Black and White Copier
My paper keeps jamming in the drawer when I try to make a copy.
  • 52 Answers
Clean the feed roller , check the clutch that control the feed roller , check if there is no stack or any object in the paper way, the u can replace the feed roller
Posted on Aug 27, 2010
When im making copies it will run off 4-5 pages and the jam up, i keep un jamming it and it keeps happening any ideas whats wrong?
Sounds as though the feed rollers for that particular paper drawer/cassette is in need of replacement.
Mar 28, 2011 | Canon NP 6545 Copier
When I went to run the copy machine this morning it jammed. The paper jammed where it grabs the paper. I removed the drawer and got the paper out. Put the drawer back in the machine and it was fine. I...
This could be a faulty sensor, but as a no cost option it could also be a worn pickup roller.. just try to roughen it with some sandpaper... see if that helps..
Apr 19, 2017 | Canon imageRUNNER 210S Copier
Can't get top feed to sense paper and copy, it will copy from bottom
the reason for this could be that you have run the feed tires and seperation tires bald by only using the upper paper tray. i would suggest getting the feed tires replaced and that should fix the problem. you might also check behind the paper drawer to make sure that a piece of paper did jam and get shoved up behind the drawer and is keeping it from working
Jun 11, 2010 | Sharp Office Equipment & Supplies
Paper keeps jamming in the paper drawer 1 and the right side. I have switched to paper drawer 2 and the same thing happens. Drawer is set to letter size but keeps jamming. What's the problem?
It sounds like you have something interferring with the paper path... Look for any small pieces of paper in the paper path, staples, paper clips etc...
If you can't find any then a service call will be the order of the day!
All the best! If I can help further please contact me : johno@execs.com
Oct 25, 2009 | Canon imageRUNNER 4570 Copier
Toshiba e-350 paper jam
rebuild the fusing assembly
Aug 10, 2009 | Toshiba e-Studio 350 Copier
SF2030...post transfer, flat jam ... symptom occurs between 1-15 copies ... not consistant ... in addition when theexit switch is activated during the copy cycle, a jam is not indicated #!@?
FYI... The copier will show a jam for 3 reasons. 1 Paper never got to the sensor, 2 Sensor sees paper there all the time or 3 Paper doesn't arrive at the right time. Alot of times paper feed rollers are dirty or worn, often ignored and overlooked, and these will give intermittant jams that show up anywhere in the paper path, often looking like a differant problem. Sometimes sensors are dirty with paper dust and will show a jam when there isn't one, in which case a can of compressed air is good to blow them out. Question, is this jamming out of all drawers and bypass or just one drawer. This would help in eliminating possibilities. Good luck, let me know if you have more questions. Please rate this. Thanks
Jul 01, 2009 | Sharp Office Equipment & Supplies
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Error code on Ricoh FT5733 copier
Open ALL paper jam locations on the machine. The jam code only means the paper jam is somewhere BEYOND the paper drawer. Check ALL jam locations including duplexer, bypass, and ALL paper drawers.
Nov 12, 2008 | Office Equipment & Supplies
Can not copy from tray/drawer, but get copy from multi-bypass tray
Regular copy paper that I got from the Staples. Same paper in the paper tray/drawer as in the multi-bypass tray. Thanks.
Jun 25, 2008 | Sharp AL 1631 Copier
Canon PC-940 Black and White Copier Logo
16 people viewed this question
old marine
old marine
