Question about GE (PSS26MSRSS) Side by Side Refrigerator
My freezer is making a constant buzzing sound. I looks like a small amount of ice has formed on the back of freezer where the motor is enclosed. We removed everything and turned the freezer off for now. What is your advise?
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
Frigidare freezer making buzzing sound like a motor
You hear the evaporator fan that is probably rubbing on some ice buildup. Remove the rear panel in the freezer to confirm that there is ice buildup and post back to me.
Nov 17, 2012 | Frigidaire FRS23KF7AB Side by Side...
There is an almost constant clicking sound from the back of the unit. When the door is opened the clicking stops temporarily and then recommences. The icemaker is not working either and when water is...
Your evaporator fan is hitting ice build up, reach in and see if you have ice build up on the wall. If so you have a defrost problem other wise if its freezing good the is just a small amount on the frame just high enough to touch blades as the go around. You might try a hair dryer around thhe fan.
Apr 21, 2010 | Freezers
Buzzing in a full freezer with icemaker model no. 253.44133802
try cleaning vents/drain holes in whole unit this should allow more air to flow.also when did you last manually defrost whole unit.....
Feb 03, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frost build up in freezer, makes a buzzing noise.
The problem was fixed by replacing the "bi-metal" device. The fan was making a buzzing noise because it was hitting a build up of ice on the coils and behind the whole back panel.
The bi-metal device was bad and "bulging" out and not performing like a switch. It kept the compressor going all the time and never allowed the freezer to go into the "defrost" mode.
Oct 15, 2009 | Roper Refrigerators
Frigidaire Frig side by side making a loud buzzing noise
it sounds like the compressor, or something near it. it is generally the only moving part in a refrigerator other than the door, so would be my first guess. If it is constantly running, but staying cool in the freezer there may be a small leak somewhere or the compressor is losing power, and pumping slower.
Jun 15, 2009 | Frigidaire FRS26H5AS Side by Side...
GE GSS25WGMCC, Ice Forming On Freezer Interior Surfaces
i had the same problem and i replaced the defrost heater and it worked fine for about one month but now having the same issue. Most of the time from what I have heard it is the defrost heater (about $60 part). I might have another issue going on with mine like a defrost thermostat. Your defrost heater is right under the panel on the inside of the freezer section. remove white panel on back side of freezer section and remove two screws and two wires and replace it and you should be fine.
Apr 15, 2009 | GE Refrigerators
A loud intermitant buzzing coming from the back of the fridge
either the noise is coming form he ice maker fill valve( but if its of and still aking noise i doubt it. it also possible that the noise is coming from the compressor itself, overheating nad trying to restart in which case would give a slight "buzz" noise for 5secs or so then "click" off, and wait maybe 3 min to restart again. look for melted ice andperhaps your ice dream ont as hard as it should be???
Feb 19, 2009 | Amana DRB1901C Bottom Freezer Refrigerator
Ice forming on pipes in back of freezer
you could have a freon leak allowing the pipes to freeze up
Dec 31, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Nov 08, 2008 | Frigidaire FRS26H5AS Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
75 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
