Question about Goodman Heating & Cooling
I have a goodman 95% 90,000 btu variable speed furnace. I know it calls for 3inch diameter venting but can I get away with 2inch if the length is 25 feet with four elbows?
  • Goodman Master
  • 43,501 Answers
If you want to go 2 inch through the wall you can do that, but go with three inch from the furnace through the ell's and then reduce it down at the end, then you will be okay,,,,,2 inch all the way will probably give you nusiance trips of the pressure switch...
heatman101
Posted on Aug 26, 2010
Condensation water drips from top of unit
I WOULD CHECK THAT YOUR PVC PIPING IS SEALED PROPERLY.
Feb 22, 2015 | Goodman Manufacturing GMVC951155DX 95%...
Goodman Model GMV950905DX-an electrical surge burned out the transformer which I replaced, also replaced the circuit board. The variable speed furnace will no longer kick into high speed and it will l
If I remember correctly, there are dip switches on that control board that can be set individually. It is possible that it is just a setup issue. The switch positions should be explained in the installation instructions. I know that some Goodman and Amana two stage furnaces can be controlled by a single stage thermostat, but the dip switches have to be set properly. If the switches are set correctly the furnace will run in low stage heat for approximately 5 minutes and if the thermostat hasn't satisfied yet, it will kick in to high stage heat. I hope this points you in the right direction!
Dec 16, 2014 | Goodman Manufacturing Goodman Gas Furnace...
New goodman 80% gas furnace leaking condesation down exhaust vent
it could be condensation. or poor seal at roof. probably the seal at roof. also check the larger copper line is it sealed good? if any spot is not this will cause leaking when in cooling mode. maybe dripping from line onto vent.
Jan 28, 2014 | Goodman Manufacturing Goodman 60,000 btu...
BLOWER DOES NOT COME ON
I need to know if you turn on heat or AC ?
Nov 08, 2013 | Goodman Manufacturing Goodman GMS80603AN...
Why does furnace heat cut back?
You might try checking your return filter. The new filters (pleated 3 month, ie real expensive ones) cut back your air flow 35% from the amount the regular 30 throw away allow. When air flow reduces the temperatur from furnace increases and can cause inadvertant high temperature limits to trip. If you are using a clean return filter, next you need to physically observe the air inlet side of your cooling coil to see if it is blocking air flow due to being dirty. If you have trouble with seeing the inlet, you might need to get a professional to take the air handler apart.
Oct 29, 2012 | Goodman Manufacturing...
Very small amount of gas leaked from vent hole on gas valve for my Goodman 50,000 BTU furnace (LP gas) then stopped. What is the vent on the gas valve for?
Hello, peter, Maybe this will help you some.
http://home.howstuffworks.com/how-to-repair-gas-furnaces.htm
Let me know, Mike
Sep 27, 2011 | Goodman GMS90703BXA Heater
I'm considering installing a Goodman LP Gas Furnace:sizing? Ops?
Gerge, if you go to website www.energycodes.gov
you can do a heat load calc yourself. Basically, you figure out the sizes of walls, total area of glass. total doors to outside, ceiling area and types of building materials used. It is pretty easy and then you will know for sure. The contractor should be suppling you with one but if not use this, it is free!
Nov 03, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
50 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
