Question about Canon PIXMA MX350 Wireless All-in-One Inkjet Printer
I am just setting up my new MX350 All-in-one printer and when I have plugged it in and hit the On button, the screen displays a printer error with the number 5100 on top. What do I do?
Error 5100 means that you have not removed all the packing tape and protective plastic. The manual is a but confusing. You must open the printer as if you were isntalling the print cartridges and remove the packing material from inside the printer.
Posted on Nov 18, 2010
Canon mx350 code error 6000
  • 6000 is displayed:
If any object is placed in front of the machine, remove it.
Open the Paper Output Tray gently, then turn the power off and back on.
  • In other cases:
Turn off the machine, and unplug the power cord of the machine from the power supply.
Plug the machine back in and turn the machine back on.
If the problem is not resolved, contact the service center.
Jul 04, 2012 | Canon PIXMA MX350 Wireless All-in-One...
System error E000
  • Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer"
  • Then press "Set" then press the "Right Arrow" button again until it says "Printer Reset"
  • Then press "Set" again, and the display will ask you "Yes" or "No"
  • Press the "Left" arrow for "Yes", then press "Set".
  • Now, unplug the power cord and wait 5 seconds and plug back in
That should clear the error. If it doesn't, get a new fuser.
Feb 29, 2008 | Canon imageCLASS D860 All-In-One Laser...
Error code 5200 on canon mx350. Any ideas? Thankyou in anticipation. Paul
Please try this web site
http://freeresetterprinter.wordpress.com/tag/resetter-printer-canon/ thanks
Sep 09, 2011 | Canon MX350 AllInOne Inkjet Printer
HOW DO YOU RESET YOUR PRINTER
  1. Press the "Fax Mode" button.
  2. Press the "Menu" button. The "Fax Menu" screen will be displayed.
  3. Press the down arrow button 9 times until the screen displays "Maintenance."
  4. Press the "Select" button. The screen will now display the Maintenance Menu.
  5. Press down arrow button 4 times until the screen displays "Restore Defaults."
  6. Press the "Select" button and a new screen will pop up. "Are you sure
    that you want to reset default settings to their factory settings?
  7. Press 1. A new screen will pop up that says the factory settings have been restored.
Mar 08, 2011 | Lexmark X8350 All-In-One InkJet Printer
I am getting a 016-310 error message on a dell 5110cn, I have powered the printer on holding the menu button and I receive a new error 003-342. Is there a fix for this?
Hit the "MENU" button, Scroll down to "Tray Settings", hit the center button "Paper type" will display, hit the center button again "MPF" will display, hit the center button again scroll to "Plain 1" then hit center button again.
Dec 30, 2010 | Dell 5110cn Laser Printer
Error u163 colour check appeared, Both cartridges are full Pls suggest
Press and Hold the STOP/RESET button and wait until it self restart.
Release the STOP/RESET button the the printer is restarting.
Dec 16, 2010 | Canon MX350 AllInOne Inkjet Printer
We have a Dell 3010 that will not print anything after trying to print card stock. We get error codes 024-969. Even though it had paper it says to load the mpf
http://en.community.dell.com/support-forums/peripherals/f/3528/t/19295553.aspx
Hope this has helped you... Thanks...
Jul 21, 2010 | Dell 3110cn Laser Printer
What does error Oxc05d0281 mean
This error message means" ink system failure " and to resolve this issue please follow these troubleshooting steps:
Unplug the printer and wait 30 seconds for power to discharge.
2. Plug in the printer.
3. Hold the CANCEL and OK buttons simultaneously, and keep them depressed while you hit the ON button. This resets the printer.
4. When the printer turns on, if you still get the error message, it's OK. Then perform the steps listed
1?Press and hold the “*” key
2?Press the “#” key and release both keys,Display should say “Enter Special Key Combo”
3?Press and release in sequence the “1”, “2” and “3” buttons
4?Press and release the right arrow button until the display says “System Configuration Menu”.
5?Press and release the “OK” button.
6?Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure
7?Press and release the “OK” button.
8?Display should say “Hardware failure status: Clear. Press OK to clear”.
9?Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
10?Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
11?Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
12?Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
13?Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
After you perform the steps listed above, when you are at the step at the end where you are pressing the cancel button until you get to the WELCOME screen, if at some point you see a message, “Inproper shutdown, hit OK”, go ahead and hit OK and the Welcome screen should appear.
One thing that is nice about this method is that it doesn't use up all your ink doing a recalibration.
The error message should not pop up so try to print a self test Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
all the best
Jun 04, 2010 | HP Photosmart 3210 Printer
The waste ink tank is near full
Hi
I found this in a forum you can try it see if it work for you.
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Also I found this.
First Clean and Dry the Print Head:
I used a cotton swab dipped in 70% isopropyl alcohol (rubbing alcohol). Do not use too much alcohol.
Then dry the heads, again using dry cotton swab. Be careful not leave any cotton threads on the print heads.
Then I padded dry the spongy Ink Absorbers (one for black ink and the other for color ink) using
Separate cotton swabs for each absorber. Do not displace the absorbers. Or you can replace the ink absorbers at this point if you do not want to pad them dry.
Then Proceed to the Waste Tank Reset procedure below:
1. Press the "menu": Key
2. Press "Copy" Key
3. Press "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading or select (-) as a short-
cut to the last setting.
4a. Press “Set” and the display shows:
Test Mode [1] – [8]
CF-FH3 :WLD-11-02
4b. Press “8” and the display changes to:
Test Mode [1] – [8]
Please wait
***note*** you have to wait until the display changes
Then the display changes to:
8: PRINTER TEST
[2]---[8]
5. Then Press the "3" button and the display shows:
8 – 3 : EEPROM Clear
*** the display scrolls to [0] : INK COUNT
[1] : 2PURGE FLAG
6. Press "0" button – for INK COUNT
7. Press the "Stop" button
8. Press Off then On to set new changes.
9. Printer feeds a blank page after it is turned on again.
This should Reset the printer and remove the WRONG CARTRIDGE error and save you a few dollars.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 05, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
HP Premium C309 All-in-One Printer error message "C2FE0065"
I had a similar error (not the same! C2FE0100), and cleared it up with the following procedure:
1) While the HP logo was displayed on the screen, I unplugged the printer. 2) Plug the printer back in. 3) Immediately open the printer so you can see the ink cartridges. 4) Press the power button at least once. If yours is like mine, you see the error just by plugging in the printer, but it takes a minute or so. Pressing the power button for me just caused it to restart the boot sequence where I could get the error again. 5) Wait a couple of minutes. You should see the ink cartridge carrier move back and forth several times, and the screen will display a message telling you the ink access door is open (or similar). 6) I let it move the ink cartridges around for several minutes, but this probably isn't necessary. 7) Close the printer back up. 8) About a minute after closing the printer, it told me that I shouldn't turn it off by unplugging it, and that I should use the power button. 9) I pressed the power button once, and it shutdown. 10) I pressed the power button once, and this time it turned on without any error messages.
I was able to print a photo via bluetooth from my phone, and a short document from my computer, so it seems to be working OK.
Jan 08, 2010 | HP Photosmart Premium C309A All-In-One...
Canon PIXMA MX350 Wireless All-in-One Inkjet Printer Logo
695 people viewed this question
old marine
old marine
