Question about LG Washing Machines
I have a lg wd12650tp and when doing a wash it stops and the letters IE come up could you tell me what this could mean. thank you.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error IE water inlet error which occurs when correct water level (246) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 26, 2010
I have an lg wd12650tp and it has stopped full of water with the code OE showing. I've tried emptying the filter at the front but it still wont drain? Any suggestions? btw apparently the code means...
Hi.
Error 0E is drain error.
Access the drain pump, located behind the service door at the base of the machine, in the front side, right below the washer door.
Disconnect power before starting the procedure.
Open the door and undo the pump attachment. Have a container ready to collect a good amount of water.
If that does not fix the problem, then there may be a fault. Further blockage, faulty pressure switch and faulty drain pump are the faults that can trigger error code 0E.
You can find parts and diagrams for most models using the link below:
Where do I find parts and diagrams?
Please click here to read an article showing how to fix common drain problems.
Regards.
Oct 21, 2011 | Washing Machines
Can you tell me what it means when your machine stops and flashes 1E.
LG's 'IE' stands for 'Inlet Error'- water supply.
Check that the taps are turned fully on and that the hoses are not kinked or squashed at the back. If all is OK then it could be a problem with one of the water inlet valves and will require a service call, sorry ;-0(
Good luck,
John C
Please score this solution accordinly- thanks!
Apr 10, 2011 | LG Washing Machines
Our LG washing machine 5.5 Kg WD-85260 NP is having problem as it is showing IE on the screen and then stops. So we have to restart the machine again. What is IE?
IE on the screen of an LG washing machine can mean a lot of things.
1.It can mean that the washing machine can't fill up with enough water in 8 minutes time.
2.It can also mean that the water hose screens are clogged up with dirt and dust.
3.It can mean that you hoses are reversed. Your cold water hose might be connected to the hot water hose.
4.The water valves might not be screwed in completely.
If you need to reset your machine you can just unplug the machine and hold the start/pause buttons for a few seconds.
Jan 16, 2011 | Washing Machines
Tube material on washing machine
Yes it is fine. Plastic does not corrode.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 30, 2009 | Washing Machines
NEC washing machine won't spin. Letters OE flashing
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Jan 06, 2009 | Washing Machines
LG WM1285 WASHING MACHINE
hi Hills659.
this is all i could find out.
What does CL mean on LG washing machine?
LG Washer CL Code Definition (What does it mean?) = The CL Code on front loading LG washing machines simply means the CHILD LOCK feature is turned ON.
The CHILD LOCK feature on your LG washer is meant as a safety precaution so children are not able to change wash settings. CL is not an error code. It is indicating that the CL or CHILD LOCK feature has been turned ON and is active.
LG Washer Error Code CL How To Turn CHILD LOCK Off
Dec 17, 2017 | LG Washing Machines
LG FRONT LOAD WASHER ERROR CODE IE
LG has general error codes for all there appliances and the "ie" error code is for the water supply. You either have a kink in your hose, water vavle shut off, or the bad problem your pump is bad.
Jul 30, 2008 | LG WD-1045FH Front Load Washer
LG Washer / WM2487H*MA...2 days old. Wash setting...."Bulky/Large QUESTION:::When attempting to select additional "wash options" from the Option Buttons panel, I keep getting a display...
My LG Tromm washing machine just stopped in the middle of the cycle, It started flashing the letters LE, what does that mean. I have had it for 4 years and this has never happened.
Jul 27, 2008 | Washing Machines
LG Tromm 8/4 WD R8012
The manual suggests to shut the water off ,
remove the inlet hose and check the screen for blockage.
The ie message is the inlet water is insufficient.
May 22, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Washer
Greetings julie312,
The "IE" message can mean that water is not entering your dispenser. If you have traces of lime in your water or very hard water, your water inlet hose can become clogged quite easily. To clean this please do the following:
Turn off the inlet water tap.
Unscrew the water inlet hose.
Clean the filter using a hard bristle brush.
Replace filter and hose, tighten water inlet hose.
Your water inlet hose is found on the back of your machine. It is recommended to clean this every few months.
You can also find a link to your manual by following http://us.lge.com/products/model/detail/home%20appliances_laundry_washers_WM2277H___yes.jhtml
I hope this helps!
Thank you,
Dorothy
Go Ahead. Use Us.
May 14, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
100 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
