Question about Bissell Vacuums
Bissell 9300 m pro heat turbo 2x . i need the hose diagram for my machine please
I have had problems with the little red clips that squirt the water getting clogged, tiny little holes! I had to remove them and use a needle, then blowed them out with air compressor. I am also trying to find a diagram for this 9300-M model but cant find one.
Posted on Dec 24, 2012
  • 120 Answers
SOURCE: Bissell Pro-heat 2x model 8920
There is probably a bad solenoid in the machine that controls the water out to the floor, you would be better off taking it to a repair place because it is a big mess of hoses and wires.
Posted on Jun 29, 2009
reddevil6
  • 1673 Answers
SOURCE: Bissell Pro Heat Turbo 2X
Here are things to check when there is no spray from hose or nozzles.
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
Posted on Jun 03, 2008
SOURCE: Bissell Pro Heat 2x steam cleaner, problems!
I took the side plastic protectors off because my brushes stopped working. I found one belt almost broken (held together by the fiber to the interior) and when I moved the brush rollers, I found mucho dog hair on the ends. Your rollers might be removed and see if you have the same problem. IT just takes two screws on each end to do this, so if your belts are good, take a look at each end where the metal post goes into it. I have two dogs and their hair is just everywhere!
Posted on Jun 25, 2008
  • 120 Answers
SOURCE: My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
Posted on Jul 06, 2009
  • 85 Answers
SOURCE: bissell pro heat 2 9300-1
remove the tank the 2 red tips are most likely clogged remove them use a paper clip to clear them then run the cleaner tn the rinse cycle with the tips off this should remove all the build up (out side may be messy ) if that doesent work its probably the solenoid
hope this helps
Posted on Dec 16, 2009
How do you replace the tool hose on a Bissell Pro Heat 2X?
Here is the Instruction or User Manual for the 7910 and the 8910 series machines
Here is the Instruction or User Manual for the 8920, 9200, 9300, 9400, series machines
Here is the Instruction or User Manual for the 9500 series machines
Jul 03, 2013 | Vacuums
Bissell pro heat 2x manual
Sep 30, 2012 | Bissell Carpet Cleaner Powerbrush Deep...
Manual for a Bissel pro heat
Aug 05, 2012 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell Pro Heat 9300 brushes won't turn before and after replacing belts
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dfghsdf
Oct 07, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Jul 02, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Need to download instruction mannual for Bissell pro heat turbo 2...model number 9300-P05347C
heatman101
hgdjd
Jun 10, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a Bissell pro heat carpet cleaner, the water spray wont come out to clean the carpet.
Bissel proheat turbo 2x ipx4.
I don't have the instruction the this machine if you could help me with where to put the water and cleaning solution and how much, also how to use it.
Thankyou,
Please email me at carolynsst@yahoo.co.uk
Mar 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro heat 2x 9300-p
Thre is a water line that uou have to unhook, so you will need to take it apart to do that.
Jun 19, 2008 | Bissell Vacuums
• clogged heater
• defective pump
May 29, 2008 | Vacuums
Vacuums Logo
209 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
