Need to fix the H5-01 on a Sharp SF-2440 copier
  • lbeaudin Aug 26, 2010
    I was looking for the code to fix it myself, I have done it before but I cant remember the code and my tech must be on vacation because I can't reach him. This did not help me very much.
  • 17,970 Answers
H5-01 is 5 continuous jams in the F-section and requires full examination of F-section and Left door assembly, for root cause.
It will need Engr/Sim codes to re-set the machine.
F-Section. Means the fusing section.
The service code H5-01 needs to be reset by a technician. So you may wish to call your local Sharp authorized service supplier.
Good luck.
Posted on Aug 26, 2010
  • 1 more comment
  • ZJ Limited
    ZJ Limited Aug 26, 2010
    Try this procedure to reset:
    Remove Jam in Fuser...
    Then enter tech mode = press program,*,clear,* enter 1 4 press start
    Turn machine OFF then ON
    Hope this work for your model.
    Thank you for trying but that did not work. Are you sure this code is for a Sharp SF-2540 copier.
  • ZJ Limited
    I don't know how much help I'll be, but lets give this a try. I'm assuming this model is an analog @ 40 cpm comparable to the SF2040 US model.
    Based on that, press orange Clear, Interrupt, 0, Interrupt, 26 on the
    numbers, Start, than look for a menu choice "AUDIT MODE", press that
    number then Start. The choices are usually '0' = off, '1' = on. Then
    Start, CA to exit simulation.
    Keep in mind that H5 indicates a heat problem in the FUSER. You need to call a Service Tech.
    I hope this helps.
We have a Sharp SF 2027 copier can we fix it
What is problem? I can help you.But you do not write any problem.
Mar 10, 2011 | Sharp SF 2020 Copier
Hello sharp sf-2027 error code F3
This is a paper feed tray problem. Check there is no paper behind the cassette. There may be a tray lift problem and this can be caused by paper being trapped behind it. reset the code once fixed by switching the machine off and on.
Good luck
Oct 10, 2010 | Sharp SF 2020 Copier
Error f1
How do you do. You should check join from the main of the charge to device сортера.If connections is checked and where are no mistakes in join no pay attention to mechanical possible damages, findings scrap papers and stranger subject in sorter device. Recall, pr what circumstance appeared the fault.Error code F1 for sharp copiers sf 2020.2030 Sub code 00: Communication error between main board and sorter. Sub code 02: Sorter transport motor drive.
Sep 23, 2009 | Sharp SF 2020 Copier
Sharp sf 2040 error code F1-02
If the sorter has a problem, disable that option by command 26 print 01 print and enter 0 enter.
Apr 05, 2009 | Sharp SF 2040 Copier
SHARP SF-7320 doesn't start
Also adjust your front door which acts as a switch.
Apr 02, 2009 | Sharp SF 2020 Copier
Melted exit rollers SF 2020 Sharp copier
Please.....do yourself a favor, and call a service tech.
Feb 27, 2009 | Sharp SF 2020 Copier
Sharp SF 2020, how to clear F code
GO ON LINE AND TYPE THE FOLLOWING:
SHARP SF2020 COPIER ERROR F CODE
ENTER
OR
WWW.SHARP.COM/COPIERS
ROD
Feb 10, 2009 | Sharp SF 2020 Copier
SHARP COPIER
Have you cleaned the optic's? what roller was replaced? Was it the drum unit? If not you may need to replace the drum unit.
Jan 22, 2009 | Sharp SF 2020 Copier
Diagnostic codes for Sharp SF-2014 copier
Sharp SF 2030 On power need enter operator key code, need reset.Please help.
Jan 06, 2009 | Sharp Office Equipment & Supplies
61 people viewed this question
k24674
jasbo
jasbo
