Question about Whirlpool 19.6 cu. ft. Upright Freezer EV200FXM
I have a Whirlpool EV200N upright freezer, 19.6 Cu. Ft.. It has a build up of ice on the inside at the bottom. It is nowhere near the drain hole.
  • 4,793 Answers
Syringe the drain with neat clorine bleach to clean it out just in case its blocked.use car deicer to clear existing ice (not hot water)and see what happens...
Posted on Aug 26, 2010
Buildup of ice on bottom (inside) , drain tube in pan underneath but is always dry.see no reson for ice build up
The drain pipe is most likely blocked. It is a plastic tube about 10mm diameter, as you've probably noticed. Try reaming it out gently with a wire hanger.
Sep 06, 2010 | Whirlpool 247 cu. ft. Upright Freezer...
Icing up
I've just had a similar problem. I fixed it by removing the large panel on the back of the inside of the freezer. I found a large build up of ice at the bottom of the freezer which seems to have developed because the drain hole at the bottom of the freezer was blocked. I defrosted the ice, cleared the drain and now the freezer is working fine.
Jul 23, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Ice in bottom of frost free whirlpool freezer
Most likely the drain (located behind the lower panel rear wall) is obstructed. You will want to clear out the ice build up and use a turkey baster with hot water to clear the frozen drain tube.
Jun 12, 2010 | Whirlpool 20 cu. ft. / 566 liter Upright...
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
My upright freezer has a small amount of water inside that freezes, creating an ice slide in bottom.
look at the bottom of your freezer, you will find a small hole or opening, it is a drain exit point of your defrosted water, try to clean it, maybe there is a small object bocking up the way or the hose all away down
Nov 06, 2009 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
My Whirlpool upright freezer keeps building up ice inside the bottom back wall. The fan starts rattling and freezer will not stay cold enough to make ice. If I take everything all out and leave it off...
Either your defrost timer, defrost heater or defrost thermostat has failed. All parts are located behind the lower back panel inside the freezer. Most likely are the defrost heater and defrost thermostat.
Jun 09, 2009 | Whirlpool 20 cu. ft. / 566 liter Upright...
ICE BUILDUP ON BOTTOM OF FREEZER, DRAIN HOLE FROZEN
There is normally a small filiament of metal which is attached to the defrost element and conducts heat down the drainpipe preventing ice build up. You can pour some boiling water onto this area and even wriggle a piece of plastic tubing down the drain pipe to dislodge any blockage. For future prevention, you can attach a piece of copper wire around the defrost element (in the absence of the original filiament) and extend it down the drainpiple
Mar 05, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Whirlpool 19.6 cu. ft. Upright Freezer EV200FXM Logo
528 people viewed this question
Top Whirlpool Freezers Experts
christian nielsen
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
