Question about Columbia All Sport watch
Set date - Columbia All Sport watch
SETTING DATE JUST ROLEX
After you unscrew the crown it is already in winding position. If you pull the crown, it will go to the date setting position. Further pull of crown will set it in time setting position. Try to pull the crown till you get it in correct date setting position and change the desired date. Do not use the date setting between 10pm - 2am, as this can damage date mechanism. The best way is to pull out crown to the time setting position and set the time to 6.30(anytime) and then push the crown in to date setting position and change the date to the previous day's date. Then again pull the crown out to the time setting position and advance hands forwards (clock wise) till hands pass 12.00 (midnight) and the date changes automatically to the desired one, then adjust the time, push the crown fully in and screw the crown on.
Jun 01, 2011 | Rolex Lady Datejust 179173SRJ Watch for...
How do you set the time on an Armitron 165 wrist-watch?
Hi wtgillo,
Hi there I see that you are in need of assistance setting time on your Armitron Wrist watch.
I would be more than glad to give you details on how to, Please see steps below.
  • Your Armitron Watch will have Four Button on the side of the watches rim.
  • Button on the upper Left is MODE.
  • Button on the lower Left is LIGHT.
  • Button on the upper right is DATE.
  • Button on the lower right is Alarm.
See Steps below:
*Setting the time*
  • Press and Hold down the Mode Button til the Hours flash
  • Then push Alarm Button to set the Hours
  • Press and Hold down the Date Button till the Minutes flash, then push D/Alarm Button to set the minutes
  • After setting the minutes on your watch, Press date till you get the month flashing push Alarm to set the month
  • Press the Date again till the Date flashes, then push Alarm to set date
  • Press the Date again till the Date on your watch flashes, then push Alarm to set the date
  • After setting everything push the Mode Button again just once to set everything or finalize your settings on the watch.
I hope that this will be of help regarding your query on how to set the time on your Armitron watch, I also included the setting of the time and date just for further details.
Have a nice day,
mvincentc
Apr 21, 2011 | Armitron Watches
Do you have directions for armitron mens pro sport watch 49/1000
Hi robinmsavage,
I will be glad to help you with your concern regarding your Armitron Wristwatch, what exactly would you be experiencing? cause I only put info on how to set time and date on the Watch.
Please see below steps:
See Steps below:
*Setting the time*
  • Press and Hold down the Date Button till the Minutes flash, then push Alarm Button to set the minutes
  • After setting the minutes on your watch, Press Date till you get the month flashing push Alarm to set the month
Thank you for choosing Fixya,
mvincentc
Apr 21, 2011 | Armitron Chronograph Sport #204345BKBK...
How to set or restart the fossil automatic ME 1030? Because the problem now is when the time turn at 12 at midnight, the date din turn..
sometimes during time set, the hands are set to change date at day time.
check it your date turns during 12 noon, if yes move the hands clockwise until you set your time and date on sync.
say you want to set your watch date:10th and time:10:15am
adjust your date at 9th
then move your hands clockwise until the date turns to 10th at the 12 thats the 12 midnight.
then continue moving your hands clockwise until you reach 10:15am
Dec 14, 2010 | Fossil MultiFunction Automatic ME1030...
I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
Dec 13, 2010 | Citizen Eco-Drive watch
Changing the date on a fossil watch- how do you do it?
Which Fossil do you own?
Analog Date Watch:
Date Setting
  1. Pull the crown out to position 2.
  2. Turn the crown either clockwise or counter-clockwise and set the date for the previous day. The direction that moves the date varies on different watch models.
Analog Automatic:
Time and Date Setting
  1. Pull crown out to position 2 and rotate clockwise to set time.
  2. Pull crown out to position 3; date will advance automatically. To set to required date, continue to rotate crown between positions 2 and 3.
  3. Push crown back to position 1.
Analog Digital:
Time and Calendar Setting
  1. Press and hold pusher A for 2 seconds to enter setting mode. Year will begin flashing.
  2. Press pusher A to select year, month, date, hour, minute, second, and then exit setting mode.
  3. Press pusher B to adjust digit.
  4. Press and hold pusher B to adjust digit automatically.
  5. If no pushers are operated for 30 seconds, setting will be returned to Normal Time Display.
These are the three most common Fossils. If yours isn't here please let me know which model you have and I'll get you the instructions.
Hope this helps.
Dec 12, 2009 | Fossil Watches
Set date
hello..this is not abig problem..just a sincronization one...ususlly I set the date around the 12 oclock in the night..the 0 hour..its easier...if you dont want to do this...well..then just count the hours ..remember you have the 24 hours /day..and remember the date is changing in the night around 12 oclock..
for instance...lets say..now you want to set the date..you count the hours until tonight at 12...you put it lets say...with 12 hours back..and wait the change in the midnight..
the easier way is to set it at midnight
oh...by the way..I saw watches which change the date around 2 oclock in the night..but this is a very small %...99% are set to do it at 12..
good luck
Feb 03, 2008 | Seiko SNA553 Alarm Chronograph
Setting the day and date
i am scared of putting to much force turning the crown
It is very hard or stiff ND CAN'T LIFT CROWN TO BR ABLE TO SET DATE AND TIME
Nov 22, 2007 | Rolex Day-Date President 118238 Wristwatch
How to change the date on cartier santos chronograph watch
There are two positions for the setting crown all the way out is to set time,one click out to set date.To set the date you must first set the time by moving the hands around clockwise until you see the date change(midnight) then continue around to the correct time.Then push crown in on click and set the date
Sep 24, 2007 | Cartier Santos W20056D6 Wrist Watch
Set the date
If you dial in the date before noon make sure you stop winding the crown right after the date flips. That will give the internal mechanism the most room to cycle and not flip at noon. If you are setting it after noon wind the crown just until the date you want starts to move to the following date, but stop immediately after so as to not flip over. That way the mechanism will be close to changing the date and should flip it at midnight. Make sense? Hopefully, good luck.
Aug 10, 2007 | Luminox Navy SEAL Dive 3103 Wrist Watch
Columbia All Sport watch Logo
20 people viewed this question
Top Columbia Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Columbia Watch Expert? Answer questions, earn points and help others
