Question about Panasonic Lumix DMC-LZ2 Digital Camera
Hallo, when I turn on my Lumix DMC-LZ2 the display is black, and the image appear only if I press or twist strongly the camera. In the review mode the stored pictures appear on the display without problems. Thank you.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 26, 2010
Is there a reset for the lumix dmc lz2
my camera works but it has a black screen fore a pick but show the menu and stuff
Nov 05, 2012 | Panasonic Lumix DMC-LZ2 Digital Camera
How do I get the date stamp to show up on the picture DMC Lz2
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Aug 14, 2012 | Panasonic Lumix DMC-LZ2 Digital Camera
My lumix camera will come on, but the display for the pifture is black, how do i fix this
I think most of these questions about black LCD's and black pictures relate to a stuck shutter. My Lumix LX2 has this. The screen is black and so are the pictures. On looking at the shutter through a magnifying glass I took a shot and I saw that the iris works fine, but the shutter did not open. I am sending the camera for repair at a reasonable rate from Clearer images here in the UK.This is the email: sales@panasoniclumixrepair.co.uk. Time will tell won't it?
Jan 13, 2012 | Panasonic Lumix DMC-LZ2 Digital Camera
Canon EOS 400d - See the image on the screen?
there should be a button on the camera that says "disp" this stands for display and when you hit that button you should see the image and if you hit it again it will go black again so you can control whether you want see it or not
Jul 13, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Problem with Panasonic Lumix DMC-LZ2 camera
hello baylie101, this message shows when the camera picks up a lens fault, if the camera has taken a knock or drop something could have went faulty in the lens. camera should be looked at by a qualified technician.
Jun 14, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
The camera itself.
shutter not openining. ccd flex not plugged in correct or it is faulty. main pcb fault. first turn the camera on then check if the shutter opens.
May 22, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Canon Powershot A70
There is a button on the back that can be pressed called Disp. (stands for Display). There are two or three settings it flips through each time you press the button. Press this button a few times to cycle through the choices in each of the playback and camera mode to see if this resolves your issue. Happy snapping...
Nov 23, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Panasonic Lumix DMC LZ2
My camera is a Lumix DMC - LS70 and the same thing was happening to me, the camera kept telling me to turn it off which never solved the problem and the lens never closed when the camera turned off. What i did was, i zoomed out as i turned the camera on (while it was in a picture taking mode) and it corrected itself. Try it and see what happens.
Sep 23, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Panasonic lumix dmc lz2
Is the image clear but just overexposed or is it distorted as well ? If it is the latter then you have a faulty CCD sensor outputting bad image and will get worse pretty quickly. Get a quote to have anew sensor put in but try to get it done free of charge . If you go this route the camera should go to Panasonic agent.
Sep 04, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Panasonic Lumix DMC-LZ2 Digital Camera Logo
21 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
