Question about Minn Kota Maxxum 55 Freshwater Bow Mount Trolling Motor
I have a 5 speed forward minn kota only 3 speeds work ,I replaced the speed control box but have the same problem
    Problem Solver:
  • 19 Answers
Check the Relay's these will be found in the control module, Most likely totaly sealed, test or replacement may be required
Posted on Aug 26, 2010
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    What is amp. draw of minn kota 40pd? thanks
    Digital Maximizer™
    Digital Maximizer™. Up to five times longer run time on a single charge.
    Conventional speed coil technology wastes energy by delivering a constant, steady flow of power to the motor regardless of the speed setting resulting in wasted energy.
    Pioneered in 1985, Minn Kotas innovative Maximizer™ technology delivers the precise amount of power needed at any setting, along with variable speed control. Now, our advanced, digital microprocessing optimizes draw to extend battery life and reduce damaging heat. Get up to five times longer run time on a single charge.
    Would think you would have to ask direct, but standard practice is to run your Minn Kota from a separate battery anyway, so the draw is pretty irrelevant to main engine starting.
    your manual is here and states it has a battery level meter.
    http://www.minnkotamotors.com/Support/Owner-Manuals/PowerDrive-V2/
    Minn Kota Motors
    Jan 06, 2016 | Minn Kota Boating
    The motor has two speeds. Very fast forward and very fast reverse. The speed control is not functioning
    A lot of these units have 2 year warranty. Minn Kota web site list authorized warranty repair centers. The foot control unit most likely got water in the digital switch. If not under warranty any longer, open it up and see if any water bubbles in the sealed board where speed switch makes contact. If so you will need new foot control.
    Sep 30, 2010 | Minn Kota Powerdrive 68PD V2 Pontoon Motor...
    My Johnson Escape boat w/ Minn Kota engine stopped running
    I've had the same problem. It steams from the control panel. I took and ran a seprate ground wire directly to the motor. This is simple to do and takes 15 minutes. Starting in the battery compartment feed cable into the split-loom and continue feeding until reaching the control panel. Pull an extra 5 foot of cable and open dry hatch in rear by motor feed cable around and out to motor connections., Good time to replace rotary switch and circuit breaker. These also are trouble-some parts.
    Aug 01, 2010 | Minn Kota Boating
    Trolling motor stays on same speed no matter where I set the speed 10 -100. It is at a mid range speed.
    I just recently had a simialr problem. No speed control and motor only ran at 100. I talked to the minn kota tech rep and sent him my control board and he said it had a bad potentiometer...however, I had to buy a control board to fix the problem ($215). Hate to say it but sounds like you may need a new control board.
    Jun 24, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    I need a truster speed for a Minn Kota Endura 46
    Hi!
    Here is a scchematic with part numbers and service center listing as well:
    Endura 46
    Best of luck!
    Mike
    Jun 21, 2009 | Minn Kota Endura 30 Freshwater Transom...
    My Minn Kota 65AT motor has 5 speeds, but currently runs at the same speed no matter if it is on 1 or 5. Not sure what to do.
    take it to a Minn kota dealer and tell them your speed controller has gone out . Instead of 5 you have one speed. I hope this helps you by narrowing down the problem.
    Apr 30, 2009 | Computers & Internet
    Ran aground on lake,now stuck on high speed,can't lower speed
    My Minn Kota 55 powerdrive had the same problem except mine occurred while it was trailered in the yard. High speed only, everything else worked great. From what I could research the control module is a frequent problem. Took a chance and purchased a new control module and this cured the problem. Maybe this happening and running aground was just concidental.
    Apr 06, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Minn Kota Maxxum 55 Freshwater Bow Mount Trolling Motor Logo
    506 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
