Question about Whirlpool Washing Machines
Washer barrel dropped - Whirlpool Washing Machines
  • 92 Answers
Too loose
rate ; 0
Posted on Aug 26, 2010
Setting gas and air mix
Carb?
Each barrel will have its own mixture screw.
with engine running, slowly back out. Rpm should drop. Slowly screw in. Rpm should increase, then drop. Back out to peak rpm then another 1/3 turn. Do screw for each barrel.
Jan 19, 2016 | Cars & Trucks
I have a Samsung front loader washer and barrel seems to be locking up I pulled the drain line from barrel housing assy and found large metal pieces in the line
The bearings have failed and it's caused major damage to the rear outer tank and the drum. Might be up for a new washer unfortunately.
Sep 20, 2015 | Samsung Washing Machines
Trying to find year and manufacturer of a single shot 410 breakover shotgun. Serial number L5972 has serated area by notched site.
iver johnson single barrel champion shotguns with a single letter suffix to the serial number were manufactured between 1920 and 1929. it seem that most of the 410 were used quite a bit and very few are in excellent condition. the original finish was an oil finished stock, browned barrel and case hardened frame.
CHAMPION MODEL 36--------------------------------1909-1922
Single barrel; rebounding center mounted hammer; top lever operated break open design; gauges: 12, 16, and 20; barrel length: 28, 30, and 32 inches (features barrel and lug forged in one piece) bored full chock only; American black Walnut but* stock and fore-end; automatic extractors; weight 6¾ pounds; overall length with 30 inch barrel 45 inches; case hardened receiver (nickel available as option), browned barrel; automatic ejectors extra cost option; .410 bore, 24 and 28 gauges offered in 1913; 24 gauge dropped 1928; all gauges except 12 dropped after 1941; name changed to Champion single Barrel in 1917.
CHAMPION SINGLE BARREL---------------------------1923-1978
This is the same gun as the earlier Model 36 champion except that the smaller gauges are now built on the same frame as the large gagues. See above picture for specifications. The exact year production stopped has not yet been determined. Some of these single barrel shotguns have been seen with Canadian marking, these were most likely shipped to Canada and then marked as there is no evidence that Iver Johnson's Arms & Cycle Works ever had a manufacturing factory in Canada
Jun 01, 2015 | Optics
Water sound
Yes, it is normal. The top ring was filled with water to act as a counter weight when it is going to stop from fast spinning.
Oct 18, 2013 | Whirlpool WTW6400SW Cabrio Washer
How do i clean the washer barrel?
You can take 100ml of vinegar and keep the machine to temperature of 65 degree and start the normal program after this washer barrel will be cleaned completely
Jan 03, 2010 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
Washer won't drain. I washed a comforter and some of the ''stuffing'' came out and now seems to have clogged the washer because it won't drain anymore. I have cleaned out the hose, seems like some of the...
depends on what type of washer it is but it should have a filter on the front bottom of it ,some times they have a plastic cover over them just remove the cover at the bottom of the washer and then turn the filter and pull it out and clean.
hope this helps you
Jul 07, 2009 | GE WVSR1060A Top Load Washer
Machine locked up. Barrel quit spinning.
first you got to empty washer by manual,get a bowl on to the floor then pull the drain pipe out of the pipe that goes outside or from under the sink,empty washer this way then the door will open,as it wont open as a result of it having water in it,when you have done this make sure you check your motor bushes,im sure that they have worn,just replace them at a cost of £10.00,they are easy to replace.rgrds paul
Jul 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water left in barrel (not the tumbler)
If you can't see any water and just hear it, this is completely normal. This is a front load washer and has a special cover of the inner tub basket. This cover contains some water that has been sealed in at the factory to keep the load balanced while it is spinning.
Nov 25, 2006 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
20 people viewed this question
Dan Webster
Dan Webster
Sal De
