Question about Clarke Power Products Clarke 130EN Wirefeed Welder - 110 Volts, 130 Amps, Model# WE6523
What gas do i use for welding mild steel .I have argon and co 2 canisters
Argon for mild steel with solid welding wire or/ flux cored welding wire co2
Posted on Aug 19, 2012
Ive almost always used 75/25, argon to CO2 mixture without any problems, the main thing about welding is cleanliness, what your welding always welds better if it is clean. hope this helps.
Posted on Sep 04, 2010
  • dead_cell_6 Dec 02, 2010
    75/25 mix is most common to use.
    But if you would like to Achieve spray transfer you need to have 90/10 mix and have your volts above
    pure co2 is not very good for mild steels, but allows for deep penetration, one big disadvantage is it encourages oxide formation, which affect the mechanical properties of the weld also it makes alot of spatter
    Problem Solver:
  • 5 Answers
Can use argon/co2 mix or CO2 the wire usually has the gas named on the lable
Posted on Aug 26, 2010
    But if you would like to Achieve spray transfer you need to have 90/10 mix and have your volts above 25.
    Pure co2 is not very good for mild steels, but allows for deep penetration, one big disadvantage is it encourages oxide formation, which affect the mechanical properties of the weld also it makes alot of spatter.
    sorry i typed too fast in my first reply
Trying find out what i would have to have to start TIG welding with a Miller Bobcat 250 1992 year model
you will need a AC high frequency unit to weld aluminum. For stainless and mild steel just need a dry run tig torch, hose kit and 100% argon.
Sep 11, 2011 | Welding Tools
I have a lincoln sp-100 welder and despite having a good ground the weld quality is just not there. Any help is appreciated
Let's troubleshoot this one:
1) Make sure you have the right polarity for the wire you are using: Innershield wire (no gas) ground clamp must be on the + side. Solid Wire (gas use) ground clamp to negative side.
2) If gas is used: Mild steel welding requires Argon/CO2 mix 75/25 or 90/10. Using pure CO2 you will create a lot of sparks and a lot of fumes. Stainless Steel welding requires a Trimix gas of Argon/Helium and CO2. Aluminum Welding requires pure argon. Any use of gas requires a steady gas flow of no more than 25 SCFH. If you use more than that or less you will find porosity on the welding.
3) Your work piece must be cleaned before welding (no grease, dirt or paint).
4) Check your machine welding chart for wire speed and voltage.
If you still experience problems with welding quality, check you input power voltage, make sure it doesn't fluctuate.
Goooooood Luck.
Aug 30, 2011 | Lincoln Mig Welder Trigger Switch Magnum...
I have a lincoln power mig 255 and every time i weld little holes appear in the welds. what could this be?
Hi:
This could be a problem of gthe gas you are using. Make sure to use mix 75/25 argon/CO2 for mild steel welding, argon 100% for aluminum and trimix helium/argon/CO2 for stainless steel.
Also check your heat (voltage) 16-22 is enough for weld of most steels less than 1/2 inch.
Aug 06, 2011 | Lincoln Magnum 100L 10' 025035
Does welder need argon gas when using steal wirer
Hi:
If you are using solid mild steel core wire, yes you need a mix of gas Argon/CO2 75/25.
Only cored shielded wire do not required gas (also called innershield or flux cored).
Adjust your flow rate for the mild steel wire at 20 or 25 scfh, depending if you are welding inside or outside a shop.
Feb 05, 2011 | Clarke Power Products Clarke 130EN...
I HAVE A HANDLER 140 I PURCHASED NEW RECENTLY, THE WELDER FEEDS WELL BUT THE WELD WIRE ONCE APPLIED IS NOTHING BUT **** AND FALLS OFF THE METAL WHEN STRUCK WITH A HAMMER. i AM USING SOLID WIRE AND THE...
Newer welders as hobart and miller are set up from factory to use innershield wire therefore polarity is set up as inverse. Check inside your machine and check that ground cable is on negative side. Your gas must be mix argon/CO2 or pure CO2 (not recommended).
Other potential problem is wire not being a mild steel one. Check you have gas flow out of your nozzle.
That's all I can think of.
Jan 26, 2011 | Hobart Handler 140 Mig Welder
Not forming a continuous bead on the inside of a 3'' carbon steel. set amps at 85/ 90 argon at 10, what am i doing wrong. please help me
I need more info, you are Way too vague.
What type of weld are you trying to do? A Fill weld?
Are you trying to fill a V in-between two pieces of hard steel, (Carbon), that is 3 inches thick?
1. If you are, the electrode should be held at a 90 degree angle to the metal. Straight up, and down.
Moving the electrode too fast will cause a intermittent bead. Slow down. TIG welding takes time. It isn't like ARC welding.
If the electrode burns off to one side, you don't have the electrode in the correct position.
2.Too little heat, (Amperage) will make a 'Cold' weld, and you won't have the penetration that you need. Too much gas (Argon) will do this also. Too little gas, and you'll burn through.
Nov 08, 2009 | Welding Tools
How to quote stainless steel welding?
First, depending on where you live some shops(welders) will "quote you a price". check the yellow pages. Use a time and material guide. Material should be included with the price of the stainless...many times you could find a contract with the locaaaaaal gas co.(speciaiality type)e.g. helium O2 etc. good place to start.
Jun 19, 2009 | Welding Tools
Starts welding good then doesent
Hi, This problem has happen to me, My solution was a grounding problem. Take your ground cable, and put it on the table leg.
If this doesn’t work for you, please write back. Thanks,
Nov 17, 2008 | Miller Welding Tools
Mig Question
MIG stands for Metal Inert Gas welding, many times called Wire-feed.. Also referred as GMAW (Gas Metal Arc Welding). The "Metal" refers to the wire which is what is used to start the arc. It is shielded by inert gas and the feeding wire also acts as the filler rod. A semi-automatic process, it is fairly easy to learn and use.
Aug 27, 2008 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Clarke Power Products Clarke 130EN Wirefeed Welder - 110 Volts, 130 Amps, Model# WE6523 Logo
276 people viewed this question
Top Clarke Power Products Welding Tools Experts
Wade Mobley
Wade Mobley
Bill Boyd
Are you a Clarke Power Products Welding Tool Expert? Answer questions, earn points and help others
