Voxson HD50 set top box owners manual so I can tune in to the new Channel 24 News
rockitman187
  • 2559 Answers
SOURCE: cant tune my Sony TV to channel 3
Go into the setting menu on the tv and go to channel setup,then select add channel.
please rate this solution
Posted on Feb 01, 2009
SOURCE: Thomson DTI550 set top box problem
Hopefully those of you who still own their DTI550 had it operational this last weekend and picked up the download that fixed this? If not, it should be repeated some time soon. So don't throw your 550 away yet!
Posted on May 13, 2009
SOURCE: Ferguson DV3 set-top box not finding BBC channels
I have solved the problem by selecting Manual Tune in the Menu. This means selecting each channel one at a time beginning at 21. The indicator shows the Signal Strength and Quality for each channel. If both show a green bar (strong on both counts) give it time to identify the new programs on each channel and add them. It will show how many found and added if you wait a few minutes. When each channel is done, move on to the next one. The last channel is 65 I believe but there is not much up the top end.
When I had finished going through this routine I found it had indeed added all channels I needed including BBC1 and BBC2
Posted on Aug 22, 2009
Testimonial: "Thanks. Channel 21 is possibly all you need for BBC channels in your area"
57 varieties
  • 1653 Answers
SOURCE: I have re-tuned my TU-CT20 Panasonic set top box
If you have all the cahnnels updated then you will have to manually edit the station list and change the order of the channels. refer to your manual for instructions.
Posted on Oct 01, 2009
SOURCE: tunning in all digital stations
Don't know if this was the problem, but I was trying to go through the tuner for the saterllite stations. I tried going through the VCR/DVD unit and now all the channels are tuned. Only problem now is how do I tape a channel through the VCR? I can't seem to tune in the VCR.
Posted on Oct 14, 2009
Will this model receive 7flix and other new channels? If not can we get a set box to get them
if your tv is already receiving digital stations the it will receive 7 flix
If you are already using a set top box it will get 7 flix and all the channel 9 station as well
all you have to do is use the remote to get the on screen menu up, (press the menu button) --navigate around until you get the auto tune in channel selection auto or manual---select auto tune and let it go and all the extra channels will be programmed in
Mar 10, 2016 | Televison & Video
Toshiba rd-xv47kb auto tune
Check that you have the arial plugged in correct input otherwise it will not tune up.
May 11, 2008 | Televison & Video
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
We dont have a manual and we dont know how to change the channel or set the time
To set the clock on the unit, have the TV connected to power but not on. Then press and hold Mem/Clck Adj on the TV (it's the third button from the right in the top row of controls). Use the adjacent Tune/Clk (up/down arrows) to set the clock for 12 or 24 hour time. Then press Mem/Clk Adj again to adjust the hour with the up/down arrows. Press Mem/Clk Adj again and set the minutes. Press Mem/Clk Adj to save the time. The original remote also has these buttons. Mem/Clk Adj is also labeled Set and is the furthest right button on the second to bottom row of the remote. The Tune/Clk buttons are the DN and UP buttons on the left of this row.
Use the Tune/Clk arrows to change the radio channels after pressing the radio button (second from the right on the bottom row). When you press the TV button (first on the right of the bottom row) to watch TV, then you need to use the Channel up/down arrows at the top and bottom of the ring control on the far right of the TV or the Channel + and Channel - buttons on the remote. On the remote, the Channel + button is below the timer button which is below 9 in the keypad section. Enter is below the Channel + button and Channel - is below Enter. Make sure that the TV is in the correct mode for your signal (ATSC for OTA and NTSC for analog cable) by pressing the TV mode button. If you are using a set top box, you will need to change the channels at the box.
Press the TV Menu button and then go down the list to Time to set the time zone for the TV. Press Enter to save the setting. Use the TV Scan button to get a list of available channels before trying to change channels.
The manual for the GPX KL868S is available from GPX at the product page: http://www.gpx.com/store/p/287-KL858S.aspx . The direct link to the English version of the manual is: http://www.gpx.com/owners_manuals/KL858S-IB.pdf .
I hope this helps.
Aug 22, 2011 | GPX KL858S 8.1 in. Under Cabinet TV
Hi. I now only get audio for channels 73 (Mate), 24 (ABC 24/7 news) 44 (Channel 31). I have lost audio for all other (forty-something)channels. I have a DGTEC DH-2000A set-top box. I have tried a rescan...
Ok here's the fix, you're only recieivng audio on HD channels because you've got your audio set on automatic or dolby ac-3.
Click menu on your remote, go to a/v settings, then audio and change it to MPEG-1.
Should sort you out.
Sep 28, 2010 | Televison & Video
Aug 21, 2009 | Televison & Video
UNABLE TO VIEW ITV CHANNEL 4 OR SKY SPORTS NEWS ON MATSUI TV
try tuning tv in another room, if it works it is then your cable or socket, try the cable next. If it wont tune its a faulty set.
May 26, 2009 | One For All URC-3445 Remote Control
Akai CT21W30AT Manual Tuning
It sets the channel according to the frequency they are on, If you don't have any channels below those numbers and are connected to Cable TV, you have a bad tuner
Mar 13, 2009 | Akai CFT2490 24" TV
Bush Digital Set top Box came with no instructions or warranty
Hi Marliene I have a user guide for this model and can email you a copy. Please send me your email address to gabiernacki@yahoo.com.au George
May 09, 2007 | Bush DVD2038 DVD Player
56 people viewed this question
 Grubhead
Grubhead
