Question about Frigidaire ATF6000ES Front Load Washer
Front loader will not spin
Yesterday the washer Frigidaire (MOdel GLTF1670ASO) Gallery Series stopped spinning. The water will come into the tub but the tub will not spin on any wash or spin cycle. Belt is intact? I have the exact problem , water comes into the drum, does not appear to agitate or spin,k will empty the water out, but does not spin
    Genius:
  • 3,422 Answers
You will have to get it repaired that's the only solution.
there being a bad connection wire between the motor and the control board.est the fuse(s) on the control board. If they are bad, then the control board is in need of replacement.
Goodluck,
Please don't forget to rate the solution
Posted on May 06, 2008
  • 3,037 Answers
Most likely it is the timer or the speed control board that needs to be checked and replaced. The motor is most likely still good. You can also check for lose connections.
Let me know if you have any other problems and I would be glad to help.
Thanks
  • Benjamin Patri
    Benjamin Patri May 07, 2008
    Please don't forget to let me know your thoughts about my solution.
    If your problem is fixed, please rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
    Master:
  • 555 Answers
The motor controller board is the most likely suspect, as it controls the timer. I would check that first. Might just be a blown fuse on that board.
  • 2,307 Answers
Check this website for more info on what could be wrong with your appliance.
  • Jaime Hernandez May 06, 2008
    You might want to check the door latch switch, the start up capacitors and probably a defective motor.
    Clcik here for more info.
    Genius:
  • 1,665 Answers
Did you check for any belt broken? You may remove rear cover.
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos May 06, 2008
    If your washer pumps out the water but doesn't spin, check these:
    • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
    • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
    • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
    • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
    • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
    • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
    • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
The machine is not draining and it is not spinning
Your machine will never spin if there is water in the tub. Remove the pump and clear the obstruction.
Jul 17, 2010 | Frigidaire GLTF2940ES Front Load Washer
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Jul 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF1670ASO is cycling fast and not spinning
Hi , try to check timer small motor .,also available in appliances store.
Feb 15, 2008 | Frigidaire GLTF1670A Front Load Washer
The problem is the door latch assembly. You can get it at your local parts supplier or oder it through repairclinic.com. Should cost $50-$55. My hubby is replacing mine now. Not an easy part to replace, but by all information I have gathered from the manufacturer and the parts department, this is a common problem and most likely the cause of the machine not spinning. It runs through all the rest of the cycles, but will not spin, even on spin only cycle. The good news... if you replace the door latch assembly once, the replacement part is much stronger than the original and shouldn't have to be replaced again.
Jan 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
248 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
