Question about Tools & Hardware - Others
I was given a ridged model TP1300LS Planer and the drive belt is broken. How do you replace the belt?
4 Suggested Answers
  • 4088 Answers
SOURCE: Belt for Powermatic 15" Planer (Planer Model M-0460213)
Order the first one through Powermatic, then order any new replacements from the number on the belt. Or you can measure the pulley belt width and use a metal tape measure to find the total length by running the tape (number side in) over each pulley rim. Then order as a standard hardware source belt. Make sure the motor is bolted down about midway in it's mounting slots when measuring.
Posted on Sep 07, 2009
rowdy45176
  • 2176 Answers
SOURCE: how do you install drive belt on makita model 2012
you roll it on, start belt on bigger pulley and then just turn pulley by hand and gently start it onto the smaller one. UNPLUG tool first though
Posted on Sep 19, 2009
  • 5603 Answers
SOURCE: Belt broken on AP13 planer thicknesser.
Here is a site:
http://www.localaccess.com/1942/ryobi/ap12.html
Find the AP13 belt there... wow...$30... ouch!
Posted on Nov 29, 2009
Belt on my dewalt dw680 planer slips and starts smoking
If the ball bearing of the armature was getting too hot by working with too hard woods may be the bearing of the armature can melting loss the drive belt have lost a little tension by it the housing and a bearing has to replaced in that case.
Feb 10, 2016 | Dewalt DW680K 3-1/4" Planer
Replace the drive belt
Do you mean replacing the cutter head drive belt?
With power off start the ribbed belt on the motor pulley, insert allen wrench into cutter head shaft. slowly rotate cutter head while feeding belt onto cutter head pulley. While rotating head, alternate between pulleys feeding it on one rib at a time. Softening the belt in hot water is NOT necessary to install the belt in this fashion.
Complements of
http://www.ereplacementparts.com/delta-22560-type-planer-parts-c-3275_3571_3579.html
Cheers
Billy of Hayward Delta 22 560 Type 1 Planer Parts
Sep 16, 2014 | Delta 12" Portable Planer Model 22-560 W/...
Planer problems
If you're looking at the planer from the infeed side, there's a belt guard on the right side of the head. Remove it and check the condition of the drive belt. If it's broke the motor will spin without powering the cutterhead and feed rollers. The drive belt is still available as part number 22-563 on sites like http://servicenet.dewalt.com/ and www.ereplacementparts.com. Just put your model number in their search box and find the drive belt in the breakdown.
Aug 01, 2012 | Masonry Tools
How do I replace the drive belt on my dewalt planer
Hi ladyccowboy1,
The drive belt is on the side with the handle (you might already know that :>)).
Take the top off, then remove the lifting gears. Remove the side cover. You'll see the cutterhead pulley that has ridges on it to keep the belt from moving in and out. Remove the pulley.
Change your belt and reassemble.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 24, 2011 | Delta TP300 Shopmaster 12-Inch Portable...
Drive belt for planer epn 7582 n to replace a broken one
if you need a part check tool parts direct. if you have the belt, pull the side off opposite the handle that raises and lowers it. you have to roll the old belt off and then you have to roll the new one on. it will be tight and hard to do. if it isn't, there is something loose and that is not good.
Aug 31, 2010 | Delta TP300 Shopmaster 12-Inch Portable...
Sep 07, 2009 | Powermatic 1791210 Model 15S Deluxe Planer
Replacing belt on bread machine
Where did you get the replacement belt ? My brother is looking for a belt for a similar model K6761 which uses the same belt (I think). It is about 24" around and 1/4" wide. It has (3) grooves inside and the backside has many notches. The motor has grooves, it would go on there. Where did you get the replacement belt ? thanks regus_patoff_2000@yahoo.com
Feb 02, 2007 | Regal Ware K6725 Kitchen Pro Bread Maker
Tools & Hardware - Others Logo
35 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
