Question about Electrolux E23CS75SS Air Conditioner
Tell me Electrolux spit Air conditioner fan part name its fit of out side of room window.
    President:
  • 3,773 Answers
It is condenser fan. The motor has all info stamped on it.<br /> Call <a rel='nofollow' href="http://www.marcone.com">www.marcone.com</a> with your mod number<br /> <br /> If this was helpful please rate me.<br />Leo Ponder Appliance-Tyler,Texas<br /><a rel='nofollow' href="mailto:imufo2@sbcglobal.net">imufo2@sbcglobal.net</a>
Posted on Aug 26, 2010
Haier 5500 window unit, spits water into the room sometimes. Also, water "sloshes" around inside the fan area & is quite noisy sometimes. ? Thankyou for your assistance...
You will need to reposition the unit to where it will be tilted downwards slightly outside.
The water will then flow out the back and not spit into the room.
Jul 16, 2011 | Haier hwr10xc6 Air Conditioner
I'm not sure if this is the same model I have, but
hi ' most of window type aircondition produces noise not same as the split type , but i see you have problem of the water that spits to your room, may be you can check the mounting of the unit, the proper mounting is it must be a little slant making the water run to its drainage . the edge of the casing must a little bit dropped lower in mounting.
Jul 11, 2011 | Goldstar LG L1004R Window Air Conditioner
Water in air conditioner
A lot of the newer window units design the outside fan to pickup the condensate water and sling it onto the coil. The evaporative effect makes the unit run more efficiently. They ususally don't spit, but if the unit is running well, otherwise, I would't worry about it.
Jul 22, 2010 | Kenmore 6000 BTU Single Room Air...
(Tilted) Plasmaire spits water into room....
What your problem is is that water coming back into your face is condesation. Appearently there is a clog preventing your condensation water from draining out the back side of the a/c You can remove the a/c from it's sleeve, take it outside and with a pump sprayer (Type used for spraying insecticide) filled with water spray around the base of the a/c where the condensor coil sits (you should see a small drain channel in this area) If this drain channel is clogged water will back up and the squirrel cage will pick it up throwing it out into the house.. Good Luck on your repairs
Dave
Sep 03, 2009 | Kenmore 76100 Wall/Window Air Conditioner
Sears Plasmaire spits water into room
It's probably just holding water somewhere and getting thrown out. I've seen people drill holes on the bottoms to drain water quicker.
Sep 03, 2009 | Kenmore 75085 Air Conditioner
Droplets of water are coming from the vents and it's making a noise like something is rattling around inside. What could this be?
The problem with this unit is that the evaporator, or the part of the air conditioner that 'creates' the colder air is not draining correctly. Pertaining to a window unit, it needs to be installed correctly with the correct amount of tilt toward outside, to allow the evaporator condensation water to drain. You may also want to check to make sure there aren't any plugged drain holes in the air conditioner housing.
The rattling you hear is most likely the blower fan spinning against the held water inside the unit.
I hope this helps! :)
Sep 01, 2009 | Heating & Cooling
Panasonic a/c 'spitting' water out the sides.
your water pan is not draining and fillin up with water causing the fan to spray it around
Jul 12, 2009 | Panasonic Room Air Conditioner CWXC104HU
Frigidaire window unit spits water into room
To be honest with you this is a good and a bad thing. The bad thing is that it is spitting water into the room. The good thing is that the unit is running Great. The amount of humidity it is removing. is greater and faster than it can run down and off the coil. See if there is any possible way to deflect the water. i would recommend trying to attach a piece of screen door material. It will likely keep the water from going through it.
Dec 17, 2008 | Maytag M7D24E7A Air Conditioner
Air conditioning unit is spitting out water
unit need to be tilted to the rear as it is installed in the window for proper drainage of condensation water off of the interior coil
the fan on the rear will pick up the water and remove it
tilt it back a little
May 27, 2008 | Heating & Cooling
Heating & Cooling Logo
54 people viewed this question
Top Electrolux Heating & Cooling Experts
christian nielsen
ivan georgiev
ivan georgiev
Are you an Electrolux Heating and Cooling Expert? Answer questions, earn points and help others
