Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Lid will not lock and just click click click (trying to lock but can't)..then "lid" is displayed and then f1.. sometimes I can (after trying different things finally get it to lock) Something like this happened a little over a year ago...do these break yearly?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you’ll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 26, 2010
F1 and beeping
F1 means the drawer lid is not closing properly - (lid seal leaking) which caused water to splash out when you started the wash cycle. The flood circuit on base of dishwasher housing (under the bottom drawer) has tripped. You will have to find the source of leakage and also dry the base of dishwasher housing. Make sure the dishwasher is unplugged form mains socket when you work in it.
Jan 16, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 code
F1 is a flood sensor fault code. The problem sometimes comes from loading the machine above the top of the drawer. When the inside lid comes down before the dishwasher starts, it cannot seal completely and water can spray into the outer cavity. The water accumulates in the inner bottom where there is a sensor. The sensor protects the electronic components from getting wet by warning you of the water which you cannot see. The solution is to remove the bottom drawer and wipe out, then dry the compartment with a fan or a small space heater. Once dry, the machine will function as usual.
Jan 24, 2013 | Fisher DD603FCSS Dishwasher
I have a 2005 Audi A8L. Last week I got something out of the boot and then closed the lid, but instead of hearing the reassuring sound of the boot lid locking, there was none and the boot lid remained...
Hi Barry,
Sometimes, the locking mechanism closes while the lid remains open. Simply press your unlocking button on your fob, or in the vehicle. Then try to close the lid again.
Jan 22, 2018 | Audi A8 Cars & Trucks
The locking lid mechanism is malfunctioning. It clicks three or four times then the letters FL are displayed.
this is what I suggest to you.
F=means Failure
"L" persists in washer display Lid lock failure Replace switch, linkage, lock solenoid or control board.
good luck to you.
Feb 08, 2011 | Maytag Neptune FAV6800AW Top Load Washer
F1 code coming up on my Oasis HE washer
YES! Serious problem...more annoying than anything else. Wait until your machine stops at the spin cycle and displays "F1" again. We just had a repair tech out today and received a quote of $384+ to fix/replace the circuit board. Kenmore & Sears are fully aware of this problem and have issued a recall on a model that is one digit off of the model I have yet they will not do anything about this even though it is the same problem. These machines are huge dogs!
Jan 15, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Fisher Paykel DD603 Problem. Top drawer shows F1 and pump runs continuously. Lower drawer does nothing, no display. I think the Electronic Controller in lower drawer is fried and maybe the Mains Filter...
Yup, definately the bottom drawer controller, for some reason you can run a DD603 with no board in the top, so long as you have a board in the bottom, but not the other way around. This is the fault you get, constant F1 from the top drawer. If you are stuck try removing the display cable from the bottom controller, this may help, so long as you leave the chassis harness in.
Sep 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 Error on Fisher & Paykel Nautilus
It leaked before leading to this.
1- Unplug the power.
2- Dry out the leak.
3- Before taking off the lid seal, check if Lid actuator working by going to diagnostic mode. 4- Select LD.
5-Pull the drawer half way out so you can see the lid going down or not when you turn on by pressing lock button.
6- Press the lock button again to release the Lid.
7- Most the time it is a Lid actuator problem and your seal look good, then you replace the Lid actuator only.
8- If it is a problem with the Lid actuator and your seal look bad then replace all .
Jun 21, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Kenmore Elite Oasis HE getting F1 code. What does this indicate?
your board is confused and cannot read water level, very easy fix, pull off console(three screws on rear) and remove clear hose on right side of main control. blow into with your mouth and clear tube. reconnect hose and try, if F1 continues main control will need to be replaced, Sears is offering this for free if your unit falls within a certain serial number range, Also a biggie.....You must use he soap only with the oasis....no exceptions.....
Apr 25, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Fisher paykel dish drawer
The motor impeller is located inside the tub.
To remove/inspect:
1. Remove dishrack and filter
2. Twist the strainer lock ring counterclockwise to disengage.
3. Lift and remove strainer and lock ring assembly
4. Remove impeller, inspect for damage and/or debris in sump.
Hope this helps....
The F1 code is retained in memory as the most recent fault (may have happened awhile ago) and may not be related to the current issue.
However FYI
F1 code can be caused by several things:
1. Defective lid motor(s)...Each drawer has two lid motors that pull the lid tight to the drawer when the cycle is started. (this was very common on early models)
2. Something too tall was placed in the drawer preventing the lid from closing completely.
OR
3. (only seen this once) the drain hose developed a crack causing water to leak only when draining.
Jun 16, 2008 | Dishwashers
Error - LiD
Probably something wrong with the lid lock system. You should here a good sized click and the lid lock light should come on. If not, its probably a bad lock system. Good Luck!!!! Jim
Sep 03, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
296 people viewed this question
Dan Webster
Dan Webster
Sal De
