Question about Kicker 06ZX750.1 Car Audio Amplifier
Kicker zx750.1 protection mode
I have a zx750.1 amp which powers a comp vx 12. when i first got it, something was rattling inside the amp. i had it hooked up anyway, followed the recommended wiring guages, and sure enough something was wrong with it. after it powered up, it almost immediately went into protection mode. i sent it back to kicker, and it was returned saying that there were no problems found with it (no more rattling either). i had it reinstalled.it powered up fine, the sub sounded good (probably listened to it for about ten minutes before leaving shop). on my way to work, it randomly went into protection mode again, but came back on after about a minute.now it will power up and sound fine, but after a couple minutes it will kick back in to protection,sometimes coming back on, sometimes not. any advice that a pro could offer to someone who has a basic understanding of car audio?
  • 156 Answers
Ok a few things to check here. So get a checklist lol.
Is the amp well ventilated?
When it goes into protetion mode is the amp HOT? like too hot to touch?
Do you have the GAIN maxed out? Turn it down
What are the gauges of your ground/power cables?
A bad speaker or speaker wire can cause this also.
Incorrect wiring of speakers like 4ohm speakers wired in parallel connected to bridge.
Inadequate alternator or battery in car
Does your system have a Capacitor? If not get a nice digital CAP they aren't too expensive.
Posted on May 06, 2008
  • 3,037 Answers
Well, check again for lose wires and make sure it is grounded good and let me know what you find, Make sure you check ALL of the wires.
I will be more than happy to help you when you get back to me on this.
thanks
Speaker blown?
disconnect the amp and do a "pop" test with a 9v battery, it should be clear and no rattle... if it rattles sub is blown
Jan 29, 2014 | Kicker Comp CVT 12 Car Subwoofer
Qsc hpr153i rattle
Please specify a bit more, does the rattle is physical(Enclosure structure) or electronically hear thru speaker(Power Amp Common Issue)? I have the solution for the amp issue, let me know.
Mar 20, 2013 | QSC Audio Products QSC HPR153I 12 SPEAKER
I have 2 10" Kicker Comp Subs
That amplifier is only rated at 150 watts at 4 ohms, or 300 watts at 2 ohms. Not a very strong amp to run 2 kicker comps. My guess is you have the subs wired wrong for your application. There are 2 types of subs, one is a dual 4 ohm, and one is a dual 2 ohm. Most people bridge these coils together and that cuts your ohms in half. For example. Lets say you have the 10cvr104 subs. Thats the dual 4 ohm sub. You wire the coils together in parallel, now its a 2 ohm sub. You have 2 of these subs running off of your amp, if they are hooked up in parallel, now you have a 1 ohm load, out of the amplifiers normal operation. Your amplifiers internals heat up really quick and there is a thermal overload, putting your amplifier into circuit protection mode. My suggestion for wiring your subs is as follows: for each speaker, wire the coils together like this- positive coil1 to negative coil 2 and negative coil 1 to positive coil 2. That is called running in series, and doubles your ohm load. Next, we need to wire the speakers together properly to hook up to your amplifier. For this, since the coils are hooked together, you only need to use one set of terminals from each sub. And take the positive from sub 1 and hook it to positive of amp. Take negative sub 1 and hook it to positive of sub 2. Take negative of sub 2 and hook it to negative of amp.
Aug 30, 2012 | Rockford Fosgate Punch 301M Car Audio...
MTX 12'' sub noise
Sounds like your sub is overextending itself, and possibly losing contact at the voice coil. Overextending will make a weird rattling sound, losing contact at the voice coil will make a popping sound.
Jan 12, 2010 | Car Audio & Video
Hooking up 6x9's to a amp
yes as long as u put in on the high pass filter (HPF)
Dec 07, 2009 | Kicker ZX200.2 2-Channel Amp - 140W ZX...
Amp turns off
what ohm is it running at? if you have all three hook up it parallel then its to low of ohms and it would be louder if you unhook your 10" sub as it moves differently form the 12"s and it cancels out some bass. but if you want it then you have to change the wiring around a bit. take the positive wire off a 12 and put it on the positive side of the 10 and then take the ground for the 10 and hook it up to the positive side of the 12. so you should have one wire from the amp going to the negative side of the 12 and one going to the positive side of the 10 and a jumper wire from the 10 to the 12. and if it still shuts off then you have bigger problems.
Sep 25, 2009 | Ultra Linear UL-2200D Car Audio Amplifier
Dropped/jailbroken iPhone doesn't charge or restore
Try hooking it to itunes then hold the home and power buttons for 6 secs. then release the power button and keep holding the home button until itunes sees the phone then restore.
Aug 04, 2009 | Apple iPhone 3G Black Smartphone
Amp keep blowing the 20amp fuse
There seems to be a short circuit inside your amplifier. It could be one of the amplifier mosfer/transistors or a diode that is connected nearby the power input.
May 06, 2008 | Alpine MRP-T220 Car Audio Amplifier
Goes into protection mode for no reason
if the amp is powering on the sub and playing and then turns in to protect mode it could be the amp is getting hot and its kicking into protect so you wont fry the amp
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Kicker 06ZX750.1 Car Audio Amplifier Logo
357 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
