Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
THE LID ON MY WASHER WILL NOT LOCK. IT IS COMING UP W/ A DU OR DL CODE ON THE SCREEN. YOU CAN HEAR IT TRYING TO LOCK BUT I WON'T LOCK.
  • 10,515 Answers
This is a door lock error code. You could try to disconnect the power supply for few minutes, say 15 minutes and then turn it ON and see if that solved the problem.If not, you need to replace the lock.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 26, 2010
Lid won't lock when going to wash.
Door Lock Failure
dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from
extending.
Machine/motor control detects open door lid switch when
attempting to lock.
Machine/motor control cannot determine if door
lid is in a locked state.
Door Unlock Failure F-83
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state.
Sep 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I am getting the code on my frontload washer F du, it is making a clicking sound the water starts to fill , then the code comes up..I am not able to find this code in my manual ..I am thinking that maybe...
The DU in the display is an error code for the door lid not unlocking. This is an indication that the lid lock assembly has failed or the control board is unable to determine if the lid is unlocked. This usually indicates that the lid lock assembly will need to be replaced.
http://www.servicematters.com/maytag_library/docs/16007803.pdf
Service manual above.
Jun 01, 2010 | Kenmore Elite 45986 Front Load Washer
Lid lock won't release ?
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
The display keeps flashing DL and I hear a clicking noise in the top of the washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Oct 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
''dl'' code comes on
the door lock switch has a solenoid lock to keep the door closed during cycles. if you tried to open the lid during a cycle then you may have damaged the lock and it should be replaced first.
if you still have troubles after that, then the control board may have an internal failure.
the lid switch costs about 30-40 bucks compared to 120-150 bucks for a board. try the lid switch first.
there is a test cycle you can run to check the lid lock if you want to do that also. but by starting a cycle it will do the same thing.
Jan 24, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I am getting an DL F code on my front loader
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Washer displays message of dl when trying to start washer
Hello bculwil Welcome
“dL” (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid
keeping it from closing. Press PAUSE/CANCEL once to clear
the code.
Or the lid lock sensor is faulty and needs to be diagnosed and replaced
Please remember to leave a solved rating before signing out.
Thank You Huum
Dec 21, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer flashing dl on the screen
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Washer keeps reading Du
sounds like lid lock failure clips each side just below top eadge of washer about 3-4 insches from outside edge use stiff putty knife to push clips in and release top should be able to acess switch from there swtich will need replacing
Apr 29, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washer DL error
F/DL is indeed a door lock error. I had this on my machine, did a lot of research and getting some idea of how it works. The code is generated when the CCU can't lock the door. Possible causes are door latch mechanism, connecting wiring, or the CCU. I could hear clicking from the CCU on my machine which indicated to me the CCU was trying to lock the door. It tries 6 times before setting the F/DL code. I tested the latch and wiring from the CCU - OK. The clicking I heard had to be relay(s) so I figured the problem was relay contact failure. I removed the CCU board, determined which relays were suspect (there are two for lock & unlock). I changed them both and saved myself spending $300 CA on a new CCU. The relays cost just over $2 each. I found replacement relays @ Electro Sonic (www.e-sonic.com; minimum $25 order plus shipping $7.50). Relay made by OMRON part # G5LE-14-DC12 replacment for original G5LE-1-VD 12VDC. I'm not impressed to have to change a $300 CCU because of a $2 relay failure. For me this was worth the try as I have some experience working with circuit boards. The relays would be a quick repair for anyone with similar experience. Hope this helps someone.
Mar 11, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
76 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
