Question about Flotec 1/4 Horsepower Sink Pump System
Pump will not shut off - Flotec 1/4 Horsepower Sink Pump System
  • 43,501 Answers
Either the float has gone bad or the float is stuck...
give it a kick or a slap and see if that dislodges the float...
If the pump continues to run, open it up and make sure the float has dropped...if it has then the float will need to be replaced...
heatman101
Posted on Aug 26, 2010
LG wm1832CW Front load washer , error code OE and shut down, drain cleaned pump ok, ?
Yes, could be that the pump has dropped down on the efficiency.
check this link for tips to reset or rework the pump
Click on Pump
Jan 15, 2013 | Washing Machines
Where is the fuel pump shut off switch located in a 2000 pontiac sunfire
GM doesn't use a fuel pump shut off switch, the safety system works like this, fuel pump is turned off if the engine oil pressure goes to zero with the key in the run position. Ford uses a shut off switch that is activated by an impact exceeding 3 G's (3X the force of gravity), it is called the fuel pump shut off inertia switch.
Aug 24, 2011 | 2000 Pontiac Sunfire
I have a 99 ford expedition and my fuel pump stop pumping Trying to find the fuel pump fuse do not have owners manuel Where is the fuel pump fuse
Here is the manual
FUEL PUMP SHUT-OFF SWITCH After a collision, if the engine cranks but does not start, the fuel pump shut-off switch may have been activated. The "Fuel Reset" indicator light will illuminate in the instrument cluster. The shut-off switch is a device intended to stop the electric fuel pump when your vehicle has been involved in a substantial jolt. 1. Turn the ignition to the OFF position. 2. Check the fuel system for leaks. 3. If no fuel leak is apparent, reset the fuel pump shut-off switch by pushing in the reset button. 4. Turn the ignition to the ON position. Pause for a few seconds and return the key to the OFF position. 5. Make a further check for leaks in the fuel system.
The fuel pump shut-off switch is located in the passenger's foot well, behind the kick panel.
Mar 08, 2011 | 1999 Ford Expedition
My ejector pump will ot shut off...it is empty what should I do?
The first thing I would do to protect the pump is to shut off breaker or unplug the pump.I'm sure you have already done this but most pumps will not run for extended periods of time without damage to the pump. I would make sure that the float is not rubbing on pit sides or has anything stoping it from shutting pump off. If you have a seperate mercury switch float then I would unplug it from pump and see if that will shut your pump off.
If you take the mercury switch out of the circuit and the pump continues to run then you need a new pump. Thank you.
Jan 19, 2011 | Home
I check all relay and don't receive direct electricity to the fuel pump and no start the car
You will never have direct electricity to fuel pump only when running then once you shut off ignition that shuts engine off fuel pump to automatically shuts off.I would change the fuel pump sit in car turn key Th start position do not crank engine if you do not hear a grrr,,,grunt sound i would say fuel pump not functioning therefore fuel pump malfunction replace.
Dec 19, 2010 | 1995 Mitsubishi Montero
Where is the reset button for the emergency shut off valve for the gas line
RESETTING THE FUEL PUMP SHUT-OFF SWITCH
After a collision, if the engine cranks but does not start, the fuel pump shut-off switch may have been activated. The shut-off switch is a device intended to stop the electric fuel pump when your vehicle has been involved in a substantial jolt.
If your vehicle is a sedan, the fuel pump shut-off switch is located on the right side of the trunk behind the trunk liner.
If your vehicle is a wagon, the fuel pump shut-off switch is located behind the service panel on the right side of the cargo area.
Use the following procedure to reset the fuel pump shut-off switch.
3. If no fuel leak is apparent, reset the fuel pump shut-off switch by pushing in on the reset button.
Hope this helps (remember to rate and comment this).
Sep 27, 2010 | 1990 Ford Taurus
Same Issue
the pump stop so will not drain spa dip # 4 may turn off for the delay but not sure if the pump will still turn off since this is new tech. good luck
Jul 05, 2009 | Jandy Aqualink Rs4 One Touch Control...
Hot tub pump stops and control panel says there is a flo problem
Yes a pump does have a thermal cut out. When the motor gets too hot the thermal cut out will activate and the pump won't restart until the motor has cooled.
If you were an electrician, or highly confident/competent with electrics, you could test the motor with a volt meter. Run the spa and as soon as the pump stops running, check the voltage at the pump. If there is voltage at the pump, then the thermal cut out on the motor has activated. Do not try checking this yourself if you're not competent to do so.
You could also do the same test at the spa pack if it's easier to do so, just locate the output to the pump.
What spa and which spa pack have you got?
Cheers,
Ian.
Apr 24, 2017 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Flotec 1/4 Horsepower Sink Pump System Logo
128 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
