Question about Honda Pressure Washer PSI 3000
The pressure only goes up to 700 psi - Honda Pressure Washer PSI 3000
  • tomsimmonds Aug 29, 2010
    if in the future I need to repair the bypass valve, where would I find it and what does it look like
    Problem Solver:
  • 18 Answers
You may need a new by pass valve or take it apart and greased also check your nozzle can be oversize
Posted on Aug 27, 2010
  • tomsimmonds Aug 28, 2010
    With the engine turned off, pour liquid TSP into the fresh water inlet until it comes out the other end
    at first just water that is already within the pump will come out but make sure you put enough TSP that it starts to come out the wand outlet.
    Then, let it sit for 48 hours and don't run it at all.
    This is how I fixed my no pressure problem
    tomsimmonds@yahoo.ca owner of Honda 5.5 with Comet pressure washer pump
What causes my booster pump to increase pressure even after I shut power and or water supply off?
something wrong here. your incoming pressure is 4 psi ( tank pressure to the pump and you use a pump to boost pressure to a maximum of 65 psi at which point the pump is shut off ( all taps close off)
yet with no pumps running the pressure goes up to 100 psi
Find where you are getting pressure in that is making the pump leak
if you have 100 psi to the pump when it is turned off, then it would not be turning on ( power on) as the shut off pressure is set at 65 psi and the line pressure is 100 psi
Sep 27, 2016 | Grundfos MQ3-45 1 HP Pressure Booster...
I have a new 1 hp utiltech pump and a new. Precharged tank with 34 psi in it now. When i prime the pump the pressure goes right to 25 psi and i can hear some water moving . When i open the shut off valve...
The 34 psi of the pressure tank sounds high, but it depends on what the cut-in pressure is set at in the pump pressure switch. Typically the pressure switch is for 20-40 psi or 30-50 psi. To establish what the pre-charge of tank should be , you need to establish what the pressure switch setting are (i.e 20 - 40 psi , etc.) Run the water and watch the pressure gauge and note at what pressure the pump comes on. The pressure tank needs to be pre charged 2 -4 psi below that cut-in pressure. So if the cut-in pressure is say 30 psi, then the tank needs to be pre charged to 28 psi.
To pre charge the pressure tank, turn the pump off. Drain the pressure tank of water to relieve all pressure in the tank. Then check the pressure of the tank at the air valve. Set the pressure to 2 psi below what the cut-in pressure is.
If you adjust the pressure switch, say from 20-40 to 30-50, you will need to go through the procedure of re adjusting the pressure in the tank. I hope this helps....
May 21, 2014 | Plumbing
Car starts then stalls after 5 seconds
sounds like you need to replace your fuel pressure regulator.
Apr 26, 2013 | 1996 Subaru Impreza
Why does the presure change from 10psi to 20 psi when i insert the filter. Once the filter is in the presure drops and the psi goes from 10 to 20.
Because the filter restricts the flow of water as it passes thru the element to be cleaner. As a result, pressure in the tank being read on the pressure gauge goes up and the return pressure you feel at the pool wall goes down.
Jun 20, 2011 | Hayward Pool & Spa
How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Aug 25, 2009 | Briggs & Stratton Garden
Tire pressure
5 to 7 psi depending on the terrain. oem stickers on fender says 5psi but were I ride it is very rocky and 7psi seems to work better to keep from smashing my rims as much.
May 05, 2009 | Sport & Outdoor - Others
Tire pressure sensor fault goes on while driving
Tire pressure always changes...
when you drive your vehicle for a long period of time the tires' temperature goes up along with the
pressure in your tires, the molecules in the air inside your tires get excited (hot)
when your vehicle is immobile for a while your tires' temperature goes down along with the
pressure in your tires, the molecules in the air inside your tires get compacted (cold)
This is the best time to get a true PSI reading from your tires....
the recommended tire pressure on most tires should be set at 35PSI
But there might be a problem with your sensors, I work with TOYOTA their sensors are set up to
where when the PSI on your tires drops below the 35PSI, the tire pressure light would then
come on.
You should also check if your spare tire comes equipped with pressure sensors, which in most cases
they do, depending on the type of tire the PSI on spare tires will usually range from 35PSI- 80PSI
you can check your owners manual for this, or simply read the recommended PSI written on the
tire.
Mar 05, 2009 | 2005 Mercury Mountaineer
Will a 1/3 hp compressor fire an 18 guage 5/8'-2" Finish nailer?
You compessor is ideal for a small spray gun however a pin nailer requires 80 to 100 psi and a small air storage thank to operate properly. The nailer may very well shoot a short nail into very soft wood at 30 psi, however there may not be enough pressure to push the piston back to top positon to load another nail and fire again. Good Luck
Jan 31, 2009 | Air Tools & Compressors
Loose oil pressure when engine slows down
That's normal in most cases, depending how low it goes. 40 psi approx when driving, 20 psi approx when idling ?
Jan 07, 2009 | 2001 GMC Jimmy
Oil pressure
At operating temp 171 - 181 F, with SAE 10w-30: idle @ 700 rpm 11 psi min, 1200 rpm 28 psi, 2000 rpm 43 psi, and 4000 rpm 57 psi.
Dec 16, 2008 | 1987 Nissan Maxima
Honda Pressure Washer PSI 3000 Logo
19 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
